Question about LG WM2277H Front Load Washer
The letters lecomes up when i put on the machine
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. LE error message indicates the control board has detected that the motor is either not turning, or has locked up for some reason. Monitoring the motor is the job of the Hall Effect sensor board which constantly determines the direction and speed of the motor and feeds that information back to the control board. If there is a problem between what the motor should be doing and what the hall effect sensor says the motor is doing, the 'LE' will be displayed and the cycle will be stopped. The hall sensor is rather easy to replace, and is covered by a seven year part warranty (in US). It only takes around half hour to replace it with a new one. Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 12, 2010
How do I change the size/font of the letters? Bold and underline too?
To change font and pitch, you need to buy a different printwheel. machines came with a prestige elite 12 printwheel. Prestige elite has small letters and 12 puts 12 charactors per inch. Letter gothic is larger size letters. Google search for ibm wheelwriter printwheel, also called a daisy wheel.
Mar 03, 2016 | IBM Wheelwriter 30 Series II Typewriter
Ready to stitch embroidery letters but nothing happens. The start/stop button and the number 10 design on the machine blinks. What is wrong?
Make sure the machine is on a solid, level surface. Also, it may not work if you don't have the correct foot on the machine.
Mar 12, 2015 | Singer Futura Xl-400 All-In-One Sewing And...
Embroidery problem
Hai, 1.You should thick and white or blank cover run a letters embroiderys. 2. After don't remove the frame. 3. Put on the embroidery cloth. 4.Marking. 5.Frame setting with smooth needles. 6.Put the frame. 7.Trace the machine after running and finshed the design.
Mar 23, 2014 | Brother SE400 Computerized Sewing and...
Singer futura
Click lettering frame icon, the lettering frame option pop up menu
shall appear you will see 30 choices of frame options inclusive d semi circle
Oct 06, 2013 | Singer CE-100 Futura Computerized Sewing...
I"m trying to fasten letters I cut from regular
How about using a tear away stabilizer or tissure wrapping paper? Sometimes the fleece is just to cushy for the machine. I would put some on the throat plate, and between the fabric and fleece, then tear it off. Good luck, I hope that helps.
Dec 27, 2010 | Brother XL3750 Mechanical Sewing Machine
How do I program my Viking 980 sewing machine? I can't find my manual & I think this machine can be programmed to stitch a word/phrase at one time, but I can't figure it out.
First touch the "P" button, the #1 will appear in the left digital window. Choose the first letter you want to sew and then push the reverse button, ( the button furthest to the left with the upside down arrow on it) that puts your first letter into memory. Then select your next letter and push the reverse button again. Repeat the process until your word is programmed into the machine.You can start sewing immediately by pressing on the foot control. Pressing the finishing button (Bullseye) before you start to sew, will make the machine tie off each letter so you can cut the joining stitches. Husqvarna may be able to make you a copy of the manual. They can be reached at: 1-800-474-6437 Good Luck
Oct 03, 2009 | Husqvarna Sewing Machines
Just made a floppy disk from quick font plus and now
1>Turn on machine
2>touch PROG (menu on top)
3>insert desired font disk
4>touch floppy icon
5>select font/font size
6>touch each letter consequtively until speeled (use "_" in menu for a space between words/names.
7>When done, touch REP (menu on top)
8> then start to sew by pressing start/stop
Nov 15, 2008 | Husqvarna Designer I
Brothers intellifax 4100
cassette is in front, put hand on bottom front of machine and pull, check to see if it is set to letter ( is the paper adjuster the part that can slide back and forth set to letter is there a switch in the cassette for custom and letter size? is it set to letter?
Dec 06, 2007 | Panasonic Panafax UF-585 Plain Paper Laser...
LG WM2277H Front Load Washer Logo
32 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
