Printers
Problem for HP Printers
Generic problem for all HP Printers
After clearing a paper jam,
By ljsager on May 14, 2008
After clearing a paper jam, I continue to get an error report saying: Paper jam, open the print carriage access door. clear the jam and then press ok to continue. I've done this repeatedly. Any suggestions, other than throwing it out the window?
Solution #1
posted on May 17, 2008
Somewhat Helpful)
waynechurch
Rank: Guru
Rating: 87%, 318 votes
One of the paper flags is either stuck down or broken (from the area of the jam)
Was this helpful?
Yes
No
Solution #2
posted on Jul 10, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
After you've unplugged the printer for at least 120 seconds and plugged it back in, during the power up the printer gears and feed mechanism perform self checks / LISTEN VERY CAREFULLY FOR CLICKING OR WHAT SOUNDS LIKE CLUTCHING / if this is occurring you could very well have shards and paper slivers in the gear teeth.
Those shards prevent the mechanisms from rotating and this seizing reads out to the HP as a paper jam.
HP's are underpowered and those tiny shards are enough to seize up feed mechanisms.
This typically occurs right after a real paper jam and the user had to rip out the jammed sheet since and it those shards that can foul up the mechanism.
the only gears you need to check are the ones you can see since it is those same gears that drive the rollers that feed sheets.
Use pliers to manually turn the mechanism yourself, it any rubber roller you grip with the pliers has any resistance when rotating, then check the drive gears connected to the roller and look for shards and slivers while you manually rotate the rubber rollers.
Clean em out with any instrument sharp enough to and reset the device to see if the jam error is cleared.
Follow this link for graphical instructions:
http://www.amazon.com/gp/customer-images/view-large-image.html?imageId=22103071
Popular Solutions for Printers
Questions and Unsolved Problems for Printers
Answer
I've read that inkjets are best for home photos. But I really want a color laser printer ( fax not... (More)
Answer
Is c4200 stil availabl eto buy?
Answer
When documents are inserted into the top tray to be scanned to email, it doesn't work. Scanning a... (More)
Answer
When i am trying to scan the pages won't pull, i have to feed them one at a time
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
