Question about Gigabyte GA-8SIML Motherboard
Getting one long beep on start up....boots up but black screen
  • pepsi674 Sep 12, 2010
    no luck with that either
  • Gigabyte Master
  • 27,725 Answers
The beeping sound is the post system searching for your hard drive and other connected devices
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
good luck
Posted on Sep 12, 2010
  • 3 more comments
  • Brian Sullivan
    Brian Sullivan Sep 12, 2010
    i had a similar problem with my computer xp pro with an elite group motherboard pulling my hair out with this problem of continuos restarting and fail to find my hard drive replaced PSU stayed connected but no screen then replaced leads from motherboard to hard drive (BINGO)
    replace all the leads that attach to your hard drive including electrical extensions IDE,SATA and the ones that attach from your motherboard to hard drive
  • pepsi674 Sep 13, 2010
    no luck with that either...thinking my motherboard is fried....i boutht it used....worked when i got it...then i removed some ram...to put in another comp to test....and hasn't worked since...
    PS....i did replace the ram....tested ram that is
    PS....i did replace the ram....tested ram that is.
Toshiba will not boot
It needs those things to start up. If you reinstalled them in the machine and it won't start up you need to check some things:
Does the screen flicker when you power it on or does it stay completely black? If it stays completely black, then the connection from the screen to the computer itself is lost. Normally it is caused by a broken cable.
If the screen flickers and then goes black, then check the following:
Does it beep at you? If it does, then the amount of beeps is important. It will state in the users manual what that numbers mean.
If it doesn't beep, then my best guess would be that there is something wrong with the power distribution in the machine.
Sep 07, 2014 | Computers & Internet
Beeping on start up
How old is laptop?... this indicates a failing HDD... back up all data and documents immediately and run repair disk in windows as chkdsk on boot cycle
Jan 10, 2013 | Toshiba Satellite Computers & Internet
Dell insperion 5030 screen black and beeping
This POST code means there is a problem with the RAM.
Reseat the RAM and if the Dell still does not boot up then -
If it still does not boot up then could be faulty. Remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you.
Sep 08, 2012 | Dell Computers & Internet
My pc boots, the the screen is completely black.
If you can see the bios screen at the boot . After that your screen is black.
The OS might be corrupted I suggest you to reinstall the OS by using the re-installation Disc.
If you are getting any beep sound then the error codes of one long beep & 2 short beep Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information.
If you don't see the bios screen & beeps, there might be problem with the screen or the VGA chip in the motherboard.
If so I suggest you to contact the service center near by.
I am sure this will be helpful for you.
Rate my solution
Regards
May 31, 2010 | Gateway ML3706 Notebook
When I power on screen shows Compaq boot screen then flashes to black then back to boot up screen. I cannot go any further. Please help.
Regarding with problem basically some part their failed. You need to check the RAM and HDD. Reset the CMOS battery remove the CMOS jamper with in 5 seconds and put it back. If you loss the first try you also recovery, to recover load the windows CD and boot up repair the windows until it is done. Good luck!
Regards
nicole
Oct 03, 2009 | Compaq Presario R3000 Notebook
3 beeps then black screen after boot
Depending upon the BIOS manufacturer, 3 beeps usually mean you have RAM problems, the RAM may need reseating to get proper electrical contact or the RAM may be faulty. Reseat the RAM module/s then reboot the computer. If this didn't solve the problem, remove the RAM and insert it into another computer to test the RAM, if this is not possible, take it to your friendly computer shop and get them to test it for you.
Jun 09, 2009 | HP Pavilion dv2000t Notebook
When I turn it on I get three beeps and nothing else
The 3 beeps are correct diagnosis for the screen problems.
reboot, keep tapping F8, till you get to
the start up screen ( black dos screen )
Try the last known good first at the top, let it roll.
If this fails, try safe mode, let it boot up, then try a system restore,
start,all progz, accessories,system tools,system restore, try go back in time.
If you cannot get into the "black" start up screen at all, your video card, has failed.
because you should get minimum of VGA graphics in safe mode.
if you do, then the video driver is corrupted and needs updating
Regards
Richard.
Apr 24, 2009 | HP Pavilion dv6000z Notebook
Gigabyte GA-8SIML Motherboard Logo
93 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
