I have a monitor 2400 kerosine heater. When I turn it on the burn cycel starts then a clicking or nocking sound comes from the pump or fuleline in the rear of the heater. Then it stops the burn cycle and put's up a code E 13, What should I do?
  • 944 Answers
E13 error code is usually about cleaning the fuel filter.cleaning the fuel strainer will easily solve the problem.Check page 23 in the manual.I have attached the manual below.It could be a dirty fuel filter or the small strainer located inside of the heater that is restricting the fuel flow.Also by the flame rod being dirty or touching the burner ring. fuel filter It is on lower right hand side.Check the manual diagram for where it is located.
Click here to download the manual
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 12, 2010
My daughters 2400 kerosene monitor will light, burn for about 2 to 3 minutes and then go out. The flame starts as a nice blue then goes to orange then looks red and goes out. Please help!
Susan, I suspect you have air in the lines, you will probably have to bleed line at pump. 2nd link explains how to.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://monitorproducts.com/wp-content/uploads/M2400OwnersManual.pdf
https://ca.answers.yahoo.com/question/index?qid=20070208183218AAEiYdr
monitor heater repair help
Thread Monitor 2400 e13 error code
Mar 05, 2016 | Cars & Trucks
Repair manual for a Monitor 2400 kerosene heater system
I just bought a use Monitor 2400,it will run and then start to beep,has E 14 on it, What does that mean? Don't have the manual for it.
Feb 02, 2012 | Heating & Cooling
Gas smells of kerosine
I have the same issue. According to the furnace repairman the duct for the fan inside the unit is rusted out causing it to burn very dirty and produce that smell. In my case the furnace needs to be replaced. Hopefully you're more lucky than I. Hope this helps
May 21, 2010 | Rinnai Vent Free Gas Heater/
Monitor 2400 Kerosene heater service
Check your filter in the fuel line outside if you have one. Also check the strainer in the fuel sump.
Feb 02, 2010 | Heating & Cooling
Lights and runs for 30 seconds then goes out and trips overload switch
Check to see if the pump is leaking some where.Then clean the pump out if there is no leak.Are you burning kerosine?K 1 will give you no problems,but diesel will cause a lot of problems,some reddy heaters can burn both,and some you can not,so look at the warnings.
Oct 17, 2009 | Reddy Heater-30-55,000 BTU Variable
We have a monitor 2400 kerosene heater, it will start up and after a few minutes at most it shuts down and starts beeping and many times has a message "error 13"
Next time you try to start the unit listen to the pump on the lower right side of the unit. Just before the E13 message if you hear a thumping noise, you have a fuel problem. If you don't hear a thumping and there is a flame you have a problem with the inside of the burner. I would say since it's a 2400 you have a fuel problem. Low fuel, no fuel, dirty filter or blocked flue pipe.
Tom Hawkins
hawkins111@gci.net
Jan 19, 2009 | Heating & Cooling
Fuel Question
Yes but would have to be modified!
Dec 16, 2008 | All-Pro Forced Air Kerosene Space Heater...
Reddy heater won't stay on
What is the model number? Could be a number of things, depending on which technology is used on your particular 55,000 btu heater.
Nov 19, 2008 | Reddy Heater-30-55,000 BTU Variable
Have a mpi monitor flashing a e13 code
I have a propane monitor heater just installed 2 months ago and I get an e 13 code and the heater won't stay on???
Oct 19, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
Clicks but wont fire
make sure the high voltage lead to the sparkplug isn't touching anything metal on its way to the plug. the clicking may be the high voltage discharging to a metal part, not the plug. those wires age during use.
Dec 01, 2007 | Reddy R70ET Utility Heater
Heating & Cooling Logo
48 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
