Question about Toshiba 62HMX84 62" Rear Projection HDTV
MY TV TURNS ITSELF ON AND OFF REPEATEDLY WHILE WATCHING IT
  • 3 Answers
I have a 62HM84 and had the same problem with no picture and the blinking lights on the front, then the tv turns off. read the above and bought a lamp and ballast from conn's appliance online. the lamp is easy to replace, 2 screws and slide out then slide the new one in from the side panel. But the ballast was the problem, not the lamp.
keep track of your screws and how things went together. i did not still not sure about one piece. you do not have to cut anything to get to the ballast, but it is a pain. you have to take off the entire back panel on the lower part of the tv. unscrew the metal support bar (flat). unscrew the other screws on the bottom. they are connect to a rolling metal tray that all of the exposed parts are sitting on. before pulling tray out, there is a black plastic piece on the left side that is in the way. unloop the wires around the hooks and unscrew the one screw. there is still one fat wire that is connected on the left side that i could not figure out how to disconnect so the tray did not come all the way out. double check for other wires that may prevent the tray from moving. i think there is another on the right side.
to get to the ballast, it is on the right side, as far back as you can reach. to get it out, unscrew the brown electrical connector from the side door opening. pull the out from around the metal shield as best you can. unplug the other two wires from the ballast. there are 4 plastic hinges on the corner of the ballast, push back to pull the ballast out. just do the reverse to get the new ballast back in and the tv back together. had a very hard time trying to get the new brown electrical plug back in. everything worked fine once i put it all back together.
Posted on Jun 09, 2008
I have a Samsung Plasma PN63A650 that has worked 4 8 years, until today. I turned it on, stays on for 14 seconds, then turns off for 8 seconds. Would not respond to remote commands either
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. ....Samsung E6030 led tv hv blinkin red light issue ... capacitors are looking good ...
Help PLEASE! Samsung Plasma Turning On/Off Repeatedly.
michiganstate.247sports.com > Topics
247Sports.comMy Samsung Plasma HDTV (approx 3.5years old) has some issues as of late. When Iturn the tv on, invariably, it starts to turn off and back on repeatedly.
Samsung Smart TV turning off - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have a Samsung plasma 60 inch model number PN60E6500EFXZA TV. It began to turn itself off every 5 minutes, for the past few days. I was able to factory ... Samsung TV Keeps turning off and on.
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
Samsung Plasma TV turns off by itself
Jun 22, 2011
My Samsung 50 in PN50B650 turns off by itself then on again ...
Apr 30, 2010
More results from www.cnet.com
Jan 13, 2016 | Samsung Televison & Video
Power surge knocked out power to my house. Was watching tv when it happened. Everything come back on, but now me tv keeps turning itself off and on repeatedly. It never really turns on.....
Hello, Unplug the tv from the wall and let set for 30 mins and then plug back in and try. If doesn't work you will have to take to repair shop or get a new one
Oct 25, 2015 | Sharp Aquos Televison & Video
Model KDL-50EX645. Why does audio fail and it shuts down continually?
Sony Bravia tv turns off and on repeatedly by itself - YouTube
? 1:32
www.youtube.com/watch?v=AuWhoi5--2o
Dec 5, 2014 - Uploaded by troubleshooterrors
Sony Bravia TV turns off and back on repeatedly by itself. Green light glows on Set top box continuously, and .
Oct 03, 2015 | Sony Televison & Video
My 50 inch samsung plasma tv turns off and on by itself. it also clicks while this happens.
My Samsung 52" plasma TV will shut off while watching TV. It will do it repeatedly and we have to turn it back on. Is it overheating and shuts down? How can this be fixed?
Oct 27, 2009 | Samsung HP-R4262 42 in. Plasma Television
TV turns off while watching it then turns back on after abt 1 min
TV needs new lamp as symptom shows existing lamp is weak and causing repeatedly on-off
Please replace lamp in TV, replacement procedure is written in user manual and it is not difficult.
Always buy Sony original lamp for TV safety.
Let me know if you need further help.
Thanks.
Sep 22, 2009 | Sony Televison & Video
It turns itself on and off repeatedly
Try this:
Unplug the tv let sit for a minute while you replace the batteries in the remote and cover the IR remote sensor on the front of the TV. Cover it with a piece of black tape or a piece of aluminum foil.
Plug the tv back in and turn on.
If it no longer turns on and off by itself then you have IR interference from some other remote operated device in the room.
If it does continue to turn on and off with the IR sensor covered then it is the internal wiring/processors and will need servicing.
May 12, 2009 | Sanyo DS27510 27" TV
TV TURNS OFF BY ITSELF
Sounds like the Startup Relay is dropping out, you will need to replace it.
Mar 28, 2009 | Sharp 32L-S400 32" TV
Turns off by itself!!!
The flyback transformer are damaged .
May 26, 2008 | RCA TruFlat 27F520T 27" TV
Powers on and off randomly
one of your tubes are bad...call tech
Nov 26, 2007 | Toshiba TP55H60 55" Rear Projection...
Toshiba 62HMX84 62" Rear Projection HDTV Logo
104 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
