Question about Sony VAIO Notebook
THe power is on but I can not see screen at my laptop. What happen ??
  • 2,567 Answers
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced.
Posted on Sep 18, 2010
Black screen but i didnt hear any beeps
Dear frnd,
its looks like Operating system problem. some times its happens that you power on and its display nothing except a black screen. you need to re-install the os but before it you have to confirm that your display screen is working. for that check the display in dark place so that when you power on its screen going to slightly white if its happens than its screen is ok if its doesn't than you have to change display screen cable inside of the laptop.
Jan 15, 2014 | Dell Inspiron Mini 1012 Netbook...
Laptop black screen
what i would try doing is trying another charger this happened with my laptop when i was using my friends charger but make sure the voltages and amps are lower than the current charger you have
Nov 23, 2013 | Apple Gateway P-7811-fx Gaming Laptop Core...
Laptop black screen crash
I would guess you have a faulty power lead. They're not usually too expensive to replace - about 20 pounds in the UK. I'd try this as soon as possible as you don't want to damage your PC with a faulty power supply.
Nov 05, 2013 | Apple Gateway P-7811-fx Gaming Laptop Core...
Hi I have a serious problem with my laptop, sometimes the laptop will blink to a black screen and won't do anything. The laptop is still on but won't do anything so I am forced to hold down the power...
there might be a problem with your charger maybe it is giving in some extra power that your laptop is unable to handle...try charging it with another charger
Oct 27, 2013 | Apple Gateway P-7811-fx Gaming Laptop Core...
I have hp laptop #hp g60_120us . around 2 years. lastnight. i hibernate it .went to do something, the laptop not working anymore when i press on. the screen showing lot of red retangle sqaure from top...
- Shut down the laptop by pressing down the power button. - Remove the power input to your laptop. - Remove the battery and put it back after about 2-3 mins
Please report your observation
May 18, 2010 | HP G60-120US Laptop
My laptop fell down and now my screen does not display anything
try to press and hold Fn and F8 - this is to toggle screen setting to ext and back to LCD on laptop. if nothing happens turn off computer by pressing power button, unplug the ac adapter, remove the battery. remvoe residual electricity from computer by pressing power button 10 times. just plug again the ac and leave the battery out. Pres and hold the letter D and while holding that press the power button once and release both of them. it will perform the built in self test on the lcd. if nothing happens, turn off computer. press anf hold Fn and while holding it press power button. it will perform diagnosis on computer. if still nothing happens need to repalce motherboard and LCD.
Mar 03, 2010 | Dell Inspiron 6000 Notebook
Laptop will not power on. When laptop lid was
System board has failed you will have to replace it.
Feb 23, 2010 | Compaq Presario 700 470024-192 Notebook
Laptop Screen is Blank
there is a hole on the back usually goldish inside take a pen push it in there hold for a couple seconds and press the power button
Jan 26, 2008 | Toshiba Satellite M35X-S349 Notebook
Samsung V25 Laptop When it is powered up nothing is showing on the screen although the power light is on and you can hear a noise. This has happened before and it just came on.
One way to make sure the system is still working, remove the Batery, then plug the power adapter only and turn the computer back on, normally if the laptop goes into Hybernation mode and the battery is low on power this can happen. If that fixes the system then you can do a safe shutdown and re-install the battery and turn your laptop on and it should come on, the fact that you mentioned this has happened before makes me believe it is Hybernation issue. Good Luck.
Jan 07, 2008 | Samsung V25 CXTD 2000 Notebook
Laptop dark screen
The laptop will reduce screen brightness when on battery to reduce the battery consumption. It should happen every time. You can adjust brightness with the fn+f10 but it will be dimmer when running on battery.
Aug 15, 2007 | HP Compaq nc6220 Notebook
Sony VAIO Notebook Logo
23 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
