Question about Maytag MFD2560HES Bottom Freezer French Door Refrigerator
Fan at top in back of inside
Fan not turning ,how do i get cover off inside to check fan
    Problem Solver:
  • 9 Answers
Instructions for this are available at www.AnyoneCanFixIt.com which will show you step by step how to get to the fan to fix the problem of a warm refrigerator but the freezer is still cold.
Posted on Jul 05, 2008
How to change the inside bulb in a ge spacemaker microwave that has a top vent fan
My Spacesaver bulb replaces from the top. You have to remove 2 screws that hold the upper vent cover. W/ cover off you will find a phillips head screw about the center that holds the bulb cover. Remove the cover screw & lift up & remove the cover, then replace the bulb, the cover & screw then put the vent cover & it's 2 screws back. There may be some variance but they are all similar.
Mar 16, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
The fan on my oven is turning very slowly instead of spinning why is this ??
It could be that the fan cover has become covered in grease etc on the inside of it which is restricting the fan. The fan cover is easily removed. There is a self tapping screw in each corner. Remove those and the cover should come off. The screw holes are offset, so you shouldn't be able to put the cover back upside down but be aware the cutout for the thermostat sender should be at the top.
It could also be the fan bearing seizing causing the fan to run slowly. Once the cover is removed you can check this but DO NOT run the fan for any length of time with the cover off as the heating element may overheat.
Apr 06, 2011 | Stoves 720EF Electric Double Oven
The fans are not working. Would like to have part number to the fans.
The fan replacement is not hard, but it is fiddly.
You need to pull out the battery case to remove DC power. To do this - front display cover off by pushing up the plastic tabs inside the bottom front of the cover and tapping the top of the cover to release the top tabs. Undo the screws on the metal plate which hold the battery in place. Take off the UPS outer metal case cover using a Torx screwdriver. Undo the 4 screws on the back holding the steel fan cover. Using needlenose pliers or a very small screwdriver, carefully remove the fan connector from the back PCB board. This connector is fragile and tends to break easily. Pull out the fan. Note the location of the 2 screws on the inside fan cover. I use a NMB-MAT Model 3610KL-04W-B50 12 volt DC replacement fan that I order in specially from any wholesale electronics shop as you want the maximum CFM out of the fan. You need to cut the existing fan leads and solder the existing connector leads to the new fan lead, using heat shrink tubing. The connector goes back in only one way- note the dimple on the side. The leads can be a little longer on your completed fan assembly. The fan manufacturer's label should face the back of the UPS.
This solution is for a PW9120-1500. I assume your UPS is PW9120-3000 or larger. Check the model of the existing fans.
Feb 24, 2011 | Powerware 9120 UPS System
Need to replace the fan on a powerware 9120T 1500VA
You need to pull out the battery case to remove DC power. To do this - front display cover off by pushing up the plastic tabs inside the bottom front of the and tapping the top of the cover to release the top tabs. Take off the metal case cover using a Torx screwdriver. Undo the 4 screws on the back holding the steel fan cover. Using needlenose pliers or a very small screwdriver, carefully remove the fan connector from the the back PCB board. This connector is fragile and tends to break easily. Pull out the fan. Note the locaton of the 2 screws on the inside fan cover. I use a NMB-MAT Model 3610KL-04W-B50 12 volt DC replacement fan that I order in specially from any wholesale electronics shop as you want the maximum CFM out of the fan. You need to cut the existing fan leads and solder the existing connector leads to the new fan lead, using heat shrink tubing. The connector goes back in only one way- note the dimple on the side. The leads can be a little longer on your completed fan assembly. The fan maufacturer's label should face the back of the UPS.
Jan 20, 2011 | Powerware 9120 UPS System
Fans wont start no cooling then. after few minuts projectot is swithing off. Is not searching even for sources
Take the top off and check to see that all of the fans are plugged in to the main board. There should be a wide plug for the main double fan and a smaller plug for the fan at the rear of the optical engine. If they are plugged in, leave the top off and turn the projector on using the remote. Check to see if all fans are on. If all of the fans are on, look thru the little **** in the top of the main board to see if the colorwheel is spinning. If all are working, shut the projector down and check the wiring from the double fans to make sure they are routed thru the notch cut into the top of the fan housing. The 2 wires should be side by side passing thru the notch. If they are on top of each other then this could be causing downward pressure on the fan housing when the top cover is in place causing the fans not to spin. Also the 2 fins inside the top cover that look like tail fins on a plane can be snapped off and discarded because they have always just gotten in the way when putting the top back on and really serve no purpose. Now, if the small fan in the back works and the double fans do not, I would try and replace with new fans because that would be cheapest. The same goes for the small fan in the rear. It is always cheapest to see if the fans themselves are bad first. If you know the fans are good for sure then unfortunately the main board has to be replaced. Also, if the clorwheel does not spin freely that will cause the projector to shutdown as well. Usually when the colorwheel doesn't spin it is because there is a screw or plastic debris from a broken part of the top or bottom case lodged underneath it. This also could be a problem for fans not spinning too. If the foot of your projector is broken a piece of the shaft could have become stuck between a fan blade and the fan housing or any plastics on the projector that have broken for that matter could become lodged. A good way to tell if there is something loose inside is to shake the unit before you take the top off. Read this again and again to make sure you understand how easy this could be to fix if the wires are not routed the right way or if a piece of plastic is stuck somewhere. It could be that simple. Good luck.
Nov 08, 2010 | InFocus ASK Proxima M2+ Multimedia...
How do I replace the cooling fan in benq pe8700
There's more then one fan inside the projector. I think I counted 3 when I opened mine up. Two are easy to get to, the other is underneath. on theleft side looking from the front. You have to take off the back surround cover in onder to remove the top cover. The top cover slides back and lifts up. Be careful because there's a wire harness running to the top cover control panel. Disconnect it then you have access to the fans. Wish mine was that easy to repair.
Feb 24, 2010 | BenQ PE8700 Multimedia Projector
My freezerator fan broke. I have the part but not sure where the fan motor is located. Is it in the top or bottom section and do I take the back off or remove the inside back panel to fix
If it's a side/side it's usually on the top behind the rear cover inside the freezer and you will have to remove at least part of the cover.
Oct 23, 2009 | Freezers
A/c turns on for 10 minutes
If it was start up capacitors, it wouldn't start initially every time. Do me/you, a favor, and remove your filter inside (return air) , and if it's a ducted system, remove entire plastic cover inside. Take a flashlight & look way up where filter covers in hole & take a good look at cooling fins on evaporator (front of AC). Look for restrictions such as dust etc. That dust will turn just like mud on there due to condensation mixing with dust, and block off flow which could cause unit to freeze up & compressor to kick out. If your real ambitious, and find lots of dust there, taking cover off roof unit would be next, and check same there at back end (condenser) coils & cooling fins.Get back to me after inspection from inside. Could still be electrical but lets check that it has proper maintenance & best chance to work properly by doing this first.
Jul 13, 2009 | Dometic Rooftop RV Air Conditioner
Noise intermitently from top ( freezer section)
in the back there should be a small cover with vent holes in it,that holds on with 2-4 screws,take that off and you will see the fan.REPLACE the fan motor,it may or maynot come with a fan blade,the motor alone is about $60.00,get the model number from inside the fridgerator
Apr 18, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Maytag MFD2560HES Bottom Freezer French Door Refrigerator Logo
75 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
