Question about Universal Kreepy Krauly In-Ground Pool Cleaner
Is not moving and I have cleaned and check the hoses for blockages and cleaned the filter.
  • 990 Answers
You need to check the flapper to see if it is stuck. Then if you still have your suction guage. Check to be sure you have enough suction at the end of the hose. Check the hoses for leaks, make sure you don't have a clog in your impeller and your plumbing is tight and the lid "O" ring on your pump is good and seated well. Also if you have a skimmer plate be sure your front hole in the bottom of it is plugged off solid. Good luck.
Posted on Sep 12, 2010
Primo water dispenser water stream low
check for blockage at the inlet. hose may have blockage. also if you have ability to move machine away from wall and access rear panel, you can look at the filter that the inlet hose is attached to.
Feb 12, 2015 | Washing Machines
Vaccum seems to cut off after short use like its hot,,once it cools off i can use again
Check filter. Clean if needed. The filter should be cleaned when it appears dirty. Simply remove filter, rinse thoroughly under warm running water until clear, then allow to thoroughly air dry. The drying is very important. Additional filter cleaning instructions are on page 13 of the manual.
Check the pleated exhaust (HEPA) filter. If dirty, cleaning is necessary. Instructions for removal and cleaning are on page 14 of the manual.
Check hose, wands, and power nozzle for blockages.
Hose: detach at both ends. The ends of the hose are the most common areas for a blockage. Check visually and clear as much as possible if present. If not visible, hold one end up and drop a coin in. Lift the end until the coin falls through. If it doesn't, there's a clog.
The easiest way to unclog a hose is to use an air pressure hose, or a canister vacuum that has an exhaust blower that the hose can be held too. If enough pressure, it will blow the dirt out. Make sure to put a plastic bag around the loose end to hold the dirt.
Visually check wands and power nozzle. The bend in the power nozzle connection is another common place for clogs. A wooden spoon handle, or similar blunt object, can be used to push the debris back toward the brush to clear a blockage here.
If none of these are the problem, contact a vacuum service center, preferably Hoover, for assistance.
Manual:
http://www.hoover.com/pdfs/manuals/S3865.pdf
Thank you for providing the brand and model info. It helps a lot.
Mar 05, 2011 | Hoover Platinum Cyclonic Bagless Canister...
MY VACCUUM HEAD WAS CLOGGED I REMOVED ALL GUNK FROM AROUNG ROLLERS AND CHECKED BELT IT STILL WONT PICK UP HELP
check to make sure the filter is clean and also check for a blockage in the hose where it bends down to the floor sweeper, ( use a bent coat hanger to clean out any blockage in the hose ).
c...
Jan 28, 2011 | Vacuums
I have a Hoover Wind Tunnel Self propelled 12amp. There seems to be very little suction. I have cleaned the hoses and filters but still not much suction. any ideas? thanks.
Make sure all filters are cleaned out and entry ways are clear of all debris. Remove hose and check for blockage. Usually the low suction can be remedied when all filters are cleaned. Hope this works for you.
Jul 17, 2010 | Hoover Self-Propelled WindTunnel Bagless...
Replaced the o2 sensor twice and the fault code still says a problem exists with it. what else is related that i need to have checked?
Have you checked the air filter to ensure it's clean and free of debris? The O2 sensor determines how much air is moving through it. If their is a blockage at the air filter, then it will show an error also. Check to ensure that the filter is clean, replace if necessary, and that the hose supplying air to the O2 housing is free of any debris.
Let me know,
Chip
May 31, 2010 | 1995 Cadillac DeVille
Clean Filter?
There is a filter at the rear of the washer.
Remove lower rear panel.
Remove large black hose from bottom of drum.
Remove and clean filter in inside hose.
Remove hose onto pump and check for blockage oe obstruction here as well.
Please rate my solution.
Thankyou.
Jan 27, 2010 | Hotpoint -Ariston Aquarius WD645 Front...
Aquarius hotpoint wf541 wont pump the water out at the end of the cycle
You need to clean the filter.
Remove lower rear cover of washer.
Locate and remove large black hose fastened to bottom of drum.
Remove and clean the filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well
Hope this helps with your problem
Dec 28, 2009 | Hotpoint Aquarius WF000 Front Load Washer
I get a message saying check outlet pipes. If
If you need to clean the filter, then remove the lower rear cover.
Remove large black hose fastened to drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here, and check inside the pump as well.
Hope this helps with your prob, Good luck.
Thankyou.
Nov 26, 2009 | Hotpoint Ultima WD72 Front Load...
Drainage
This normally shows blockage in hose , assuming you have checked and cleaned filter.Glass sherd was the problem with mine , first time then second was block outlet hose cause by backup of garb.Glass was in system at least 4 months before it moved in outlet hose and stopped full drainage.
Mar 21, 2008 | Whirlpool 24 in. ADP5962 Free-standing...
Universal Kreepy Krauly  In-Ground Pool Cleaner Logo
124 people viewed this question
Top Universal Pool & Spa Experts
Bill Jordan
Are you an Universal Pool and Spa Expert? Answer questions, earn points and help others
