Question about Fisher and Paykel Dryers
Very high pitched squek when dryer is on. Often small items get stuck in the upper left side of the "rim" of the dryer and leave a dirt/oil mark.
    President:
  • 3,074 Answers
You will need to pull the front panel off, as it sounds as though the drum is not riding on the roller/coasters. Unplug machine, open dryer door and on the inside of the door there are screws remove them. with a flat tip screw driver gently pry up on the top corners,as these are clipped from the inside, the panel should move out towards you if not there may be two screws on the bottom corners, slide the panel forward and disconnect the door switch. set panel aside and lift up on top of dryer it will rise 90 degrees and stay up, pay close attention to the belt how it is ran as you will need to take it off, the drum can now be lifted up and out, the coaster/rollers are mounted on the rear, they should be round. hope this helped tim
Posted on Sep 12, 2010
Just replaced high imit thermal fuse. The dryer belt squeks after 30 minutes on high manual mode. It seems the dryer is running much hotter than usual maybe causing the belt to squek. Any idea???
You may possibly have a bad temp control stuck on that caused the hi limit to open in the first place. That may be why you have a hotter than normal dryer. Temp controls are usually near the hi limit. A round disk with either 2 or sometime 4 wires hooked to it. Also check for a possible block vent keeping the hot air from venting outside.
Mar 20, 2015 | Dryers
Dryer is making a high pitch squealing noise.
GOD IS GOOD !!!!
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
Sep 29, 2014 | Dryers
My Euro-kitchen range hood's fan/motor is making a high pitched sound after it's been on for a few minutes. What should I do first to try to fix it?
A high pitched sound is usually a bearing that went dry. Lubricate the upper and lower bearing with a Zoom Spout oiler. http://www.apwagner.com/index.php?main_page=product_info&products_id=1547461
You can get this at nearly any Appliance Parts Supply source.
This oil is a 76% paraffin based oil used for motors, armatures, dryer drum rollers etc.
DO NOT use regular oil... or a 3 N 1 oil. The fan motor will eventually lock up if you do.
While your doing the lubrication... check the fan blade tips for wear marks or gouges to make sure they are not striking anything.
Thanks for using FixYa.
Kelly
Apr 21, 2010 | Euro-Kitchen 198B2-36 Stainless Steel...
I own a FP dryer model DE08-US1, and it is making a high-pitched squeking noise and smells like burning rubber--please help.
I suspect your drive belt is slipping or a worn bearing, you need to have this checked by a Qualified serviceman. Get a firm "Quote" before proceeding.
Jan 31, 2010 | Dryers
Constant high pitched noise emitting from furnace
This is probably a dry bearing in the vent motor. Those motors run at high RPM's and can make a deafening high pitched squeal if they become dry and need oiling.
Some of the motors have oil cups on them for dripping oil into and others;s are much more difficult as you need to guess where the bearing is and try to drip oil down into them or run the oil to them.
Any light weight small motor oil ike a sewr machine oil will work.
Many hardwares have small oil bottles with extending spouts made just for oiling motors for just a couple of bucks...
The other thing that can cause this is if the blower wheel is coming loose and has moved to the side and is hitting the side of the blower housing. Take the bottom cover off and check for play or movement side to side in the blower wheel. Spinning it with the power off by hand may give you a clue as you will hear it scraping the side of the housing.
Heatman101
Dec 29, 2009 | Goodman GMS90703BXA Heater
High pitch squeal
IT IS MORE THAN LIKELY A STUCK DRUM ROLLER OR IDLER PULLEY. I HAVE SEEN IN WORST CASE SCENARIOS WHERE IT HAS BEEN THE MOTOR ITSELF WHEN SUBJUCTED TO LOTS OF LINT AND DUST FROM PLUGGED VENTING. I WOULD CHECK THE FIRST TWO AS THEY ARE THE MOST COMMON. DO NOT OIL THEM.
Dec 28, 2008 | Maytag MDE2600 Electric Dryer
Dryer leaving brown streaks on clothes
the brown streaks and holes will be when they get stuck the dryer is still turning and it will be friction marks if it is getting stuck between the inner and outer drums than check to see if there is any wobble in the inner drum by opening the door and placing your hand at the top of the outer rim of the panel and place your fingers to the top of the inner drum pull your fingers towards your hand if there is any movement than the bearings are gone which will need replacing once done then this will eliminate the problem if there is no movement check to see if there is a seal missing from between the inner and outer drum u can find this out by checking with your fingers than calling the manufacturer to see if there is supposed to be one there
Aug 19, 2007 | Hotpoint NBXR463EBWW Electric Dryer
Brown marks on clothes
This is a pretty common problem with these Frigidaire dryers. Crice hit it right on the head when he said the clothing is getting stuck between the guides and drum. The upper and lower felt guides need to be changed. This is not one of the easiest jobs. The top and front panel have to come off and the guides are glued on with high temp. adhiesive. The old guides have to be scraped off. Part numbers for the upper and lower guides are 5303937139 -(upper) 5303283286 -(lower). Catriver...post back
Jan 13, 2007 | Frigidaire GLER642A Electric Dryer
Open Questions:
Dryers Logo
89 people viewed this question
Top Fisher and Paykel Dryers Experts
Tim Whalen
Craig Butler
Craig Butler
Virgil Watts
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
