Question about Nikon Cameras
I have Nikon N4004, and it won't take any pictures, only one time did it when I pushed the exposure button, but it took pictures rapid, like about 4 or 5, now it won't take any.
  • 291 Answers
SOURCE: Over-exposure with AF Nikkor 70-300 telephoto
If you are shooting objects outside with a telephoto lens, the background can influence the exposure settings if it is center weighted with a large area. The D70 sets this in the setup menu, under item 11 (Center wtd). Check to see if it is set to one of the lower settings. When you shoot general area shots or use it indoors, the exposure weighting won't be such a factor.
This problem would show up mostly when you shot high contrast shots for instance, if you shot a person outside with a bright sky in the background. Changing the exposure weighting to a small center weighted area will cause the camera to set exposure based on the person rather than the background. This will make the sky more overexposed, though.
You may have to experiment a little with the setting to get it to expose the way you want. Try both higher and lower settings before you decide what you really like.
This, by the way, is the last major area where digital cameras can't do what film does. The range of light that digital can shoot is much more limited than film. Normally, in shots where there isn't such a large range of light objects to dark objects, digital is great. For that small percentage of shots where there is a large contrast difference (think about a sunset), digital isn't able to duplicate what film does.
Posted on Aug 26, 2009
SOURCE: Nikon D60 is taking very dark pictures!!
elis - did you ever solve this problem? the same thing is happening with my d60 and i don't know what to do!
Posted on Jan 06, 2010
akangpepen
  • 133 Answers
SOURCE: Nikon d3000 autofocus issue
you should change the focus lock to AF-S, instead of AF-C
Posted on Jan 03, 2011
dddriver
  • 107 Answers
SOURCE: Nikon coolpix S3000 won't take a picture when the
Assuming you have new batteries and the camera lens cover is opening when turned on. Try switching to any mode other than automatic, turn off the flash, and press the shutter button. Many cameras have a safety feature that prevents the flash capacitor from charging if the case is opened. This is to lessen the chance of electric shock. They usually use one or two of the screws along the perimeter of the camera to complete a circuit that lets the processor know that the case is closed. Verify that all the screws are in place along the perimeter of your camera, and that there are no gaps along the perimeter seams. If you're missing a screw, try using one of the others to replace it.
If they're all there, next thing to check is the batteries. The brand that you're using may have reached its shelf life, or just may not have sufficient power to charge the flash capacitor. Try a better brand, or better yet rechargeable NiMH batteries.
If the above didn't help, then the flash tube or its circuit is probably at fault. In this case, would then recommend professional repair. This repair is somewhat difficult, requires some soldering, has some danger of electrical shock, and goes beyond what I'd like to describe here
Posted on Jun 13, 2011
Testimonial: "Many thanks, the camera is fairly new but just out of warranty. I have tried all your suggestions but still no luck. Off to he repair shop!"
ZJLimited
  • 17970 Answers
SOURCE: every thing seems Ok except
Soun dlike a problem with CCD (Charge Coupled Device) sensor; when a picture is taken, the CCD is struck by light coming through the camera's lens. Each of the thousands or millions of tiny pixels that make up the CCD convert this light into electrons. The number of electrons, usually described as the pixel's accumulated charge, is measured, then converted to a digital value. This last step occurs outside the CCD, in a camera component called an analog-to-digital converter.
In order to correct this issue, the repair facility needs to replace the CCD. This is not something you may do on your own; this, isn't a good new, but hope helps to solve it.
Posted on Jun 14, 2011
Too much brightness when using s6800
I do not know the S6800 model specifically however, nikon cameras all generally work in the same way. Somewhere on your camera, probably a button or in the menus, there is an exposure compensation setting. The symbol Nikon uses for the button is a "+/-" enclosed in a circle (often half black on white/white on black printing). Press the button and you will either see a zero, a positive or negative number or a a scale with zero in the center with positive numbers to the right and negative numbers to the left.
If the exposure compensation is not at zero, set it to zero. Your exposures should now be correct. If it is already at zero, set it to a negative number to reduce exposure and darken the picture and to a positive number to increase exposure and lighten the picture. Let me know if this solved your problem.
Jul 31, 2014 | Nikon COOLPIX S6800 Digital Camera Black
Somehow my camera, a Nikon D60, is now displaying 4 smaller pictures on the monitor vs the full screen picture I just took. How can I change it back? I cannot find an answer in the instruction manual,...
You pushed the wrong button! On the left side of the LCD display, there are four buttons. One is labeled "ISO" and the other "QUAL". In the viewing mode, these buttons are used to allow you to scan multiple frames at one time. Each time you press the ISO button, it increases the number of images displayed. Each time you press the QUAL button it reduces the number of images displayed.
Oct 04, 2013 | Nikon D60 Digital Camera
When i took a picture with my nikon d70 the the outcome is quite bright where to adjust. i'm a beginner
1. You could lower the ISO setting. 2. You could lower the "exposure compensation" setting. It's the button that's half-black/half-white with a plus and minus. There are many other ways but you really should carefully read your instruction manual and experiment.
Oct 29, 2010 | Nikon D70 Body Only Digital Camera
Exposure inconsistency with 18-200mm on my Nikon D300
A plus-or-minus one-third stop is perfectly normal if you're handholding the camera, especially when metering a high-contrast subject such as a lit lamp. If you really need to lock the exposure, use the exposure-lock button or set the camera to manual.
Sep 22, 2009 | Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR...
Small black squarowing up on all my pictures on Nikon D80
Have you checked that the exposure compensation isn't set to anything other than zero?
Sep 18, 2008 | Nikon D80 Digital Camera with 18-135mm...
Error. Press shuter release button again
I was taking pictures, then when I pressed the shutter release button, it took a long time. Then the error message came up. I tried pressing the shutter release button again, nothing happens. Still the error message. Please help me
Sep 08, 2008 | Nikon D40x Digital Camera
All white pic is shown on LCD when used in Manual Mode with delayed shutter timer
You are massively overexposing the picture. Manual mode means you have to set the exposure manually. You need to adjust the settings so that the light meter reads somewhere around the zero mark.
M mode is most useful for flash photography where you want a certain level of ambient illumination in the picture as well.
If you want some control over the camera but don't want to worry about exposure too much, use A and S modes. The manual will explain all of these modes.
Aug 31, 2008 | Nikon D40x Digital Camera
Nikon n4004 top cover
There are two screws on the right side that are hard to find. One is inside the battery chamber and the other is under the small cover surrounding the shutter release button. The cover is held in place by 2 sided tape. Pry it up carefully starting near the strap lug
Dec 17, 2007 | Photography
Looking for a user manual
http://www.butkus.org/chinon/nikon.htm
Sep 21, 2007 | Photography
Button for exposure
Nothing to fix - this is a major switch problem Contact Nikon technical support team for advice but I fear it is new camera time
Jun 22, 2007 | Nikon Coolpix 5700 Digital Camera
Cameras Logo
97 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
