Question about Nintendo Video Game Consoles & Games
Trying to get my WII set up to use with Netflix. can you help?
  • 395 Answers
Nintendo has a help guide on there web site at
http://www.nintendo.com/consumer/systems/wii/en_na/netflix/howto.jsp
to help setup netflix on the wii
Posted on Sep 12, 2010
I can't get connected to Netflix.All that pops up is error code 209826
Error code 209826. Is this with a Wii? Error code references "Problem connecting to the Wii Shop channel. Either a problem with the router or the Wii Shop may be temporarily
down. Try again later."
I recommend turning off the Wii completely. Check the wireless router and unplug the router, but do not disconnect the cable. Keep powered off for 5 minutes. Plug router back in, let all the lights power up and then turn the Wii on and attempt to connect again. Should the issue continue, you may need to go through the Wii network set up and verify that it is communicating with the router.
Dec 30, 2014 | Netflix
I can't get connected to Netflix. I keep getting error 51030
That sounds like a Nitendo Wii errorcode; assuming your using that to watch Netflix:
From the tech support website: http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51030&system=Wii&locale=en_US
Error Code: 51030
Unable to connect to your wireless network
Likely cause: Your wireless router may need to be power cycled, or the connection settings have changed.
How to fix: Power cycle your router; redo the connection settings on the Wii and try again.
  • Did this connection used to work but has suddenly stopped? "Power cycle" your router and modem. To do this, unplug both the modem and the router from the power outlet. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then plug in the router. Try to connect the Wii, Nintendo DS, or Nintendo 3DS online and test for proper response.
  • Erase your old connection settings on the Wii and set up a new one, as your router's settings may have changed since you last connected. We suggest following our guide to create a new connection file and start over. If at the end you still need help, you'll find contact information to reach our specially-trained representatives.
Click here for info on setting up your Wii: http://www.nintendo.com/consumer/systems/wii/en_na/getOnline/index.jsp
In other words; you Wii doesn't seem to be connected to your WiFi network anymore ...
Jun 29, 2014 | Netflix
Where's the activation code on nintendo wii?
How to get Netflix to work on a Wii
1.) turn on your wii
2.) press "A" (or any button to get to the wii menu)
3.) on the Wii menu, go to the bottom-left of the screen
4.) click "A" on the word "Wii" (when you highlight it, it should say "Wii Options")
5.) then click on "Wii Settings"
6.) on the contoller, hit the "+" button then click on "internet"
7.) then click on "connection settings"
8.) click on any connection setting (i just use the the one that says "connection 1")
9.) if you want to connect through a wireless connection, click on wireless connection (this will search for WiFi around you.)
10.) then go to "search for an Access Point"
it should find some access points, if it doesn't, then you'll need to buy a Nintendo WiFi thing (i'm sorry, i forgot the correct name for it)
11.) click "OK"
12.) click on an access point with a lock that's unlocked, or click on one with a yellow lock and put a password. if you see a red lock, you cannot connect to that access point.
13.) it will ask you if you want to save the settings. click "OK"
14.) then click "OK" again, to do a connection test (this could take about 30 seconds)
15.) UPDATE THE WII
16.) after that go back to the Wii menu by clicking "Back" until you reach the Wii menu
17.) then click on the wii shop channel.
18.) then click on start shopping
19.) then click on channels
20.) then click on netflix
21.) wait for it to download
22.) then go back to the wii menu
23.) then load up the netflix channel
24.) they're going to give you a password, go on a computer and (if you have a netflix account) go to www.netflix.com/activate or http://www.netflix.com/NRD/Wii?mkwid=s0BEmMX1Q&mqso=80025460
25.) then loggin and type in the code from the wii into your accound
...Now you can watch Tv or movies on your Nintendo Wii
Aug 19, 2012 | Nintendo Wii Console
I dont know how to download netflix on my wii
Connect your Wii console to the Internet A broadband Internet connection and access point are Follow the steps below to get connected.From the Wii main menu, use the Wii Remote to select the "Wii" button. Now, select "Wii Settings" to access the "Wii System Settings" menu.Using the arrow on the right side of the screen, scroll to page two and select "Internet. Select "Connection 1: None"(Don't see "None" in Connection 1? Click the Connection 1 button, then choose "Clear Settings.") Click on Wireless Connection" and then "Search for an Access Point." Select "OK" and the Wii will display all the wireless networks it finds. Select the wireless network that is yours. (If you're not sure which is yours, or you don't see any wireless networks,The Wii console will run a connection test with your wireless network when the test is completed. You should see the following screen: The connection test was successful - Then you're almost done! After your connection test, the Wii console will check if there is a new Wii System Update available. Once you select "Yes" and "I Accept," the Wii will begin to download any available updates.Once the Wii finishes downloading any updates, you will return to the main Wii menu screen. You will now need to download Netflix Instant Streaming for Wii from the Wii Shop Channel, then connect your Wii console to your Netflix account. Please see the step-by-step information below to finish the process and start watching Netflix content on your Wii.Download Netflix Instant Streaming for Wii from the Wii Shop Channel Now that your Wii console is connected to the Internet, you can download the Netflix Instant Streaming for Wii from the Wii Shop Channel. Once it's downloaded, you'll use it to stream movies and TV episodes with your Wii.
1 Select the Wii Shop Channel on the Wii Menu.
  1. If you have not previously accessed the Wii Shop Channel, you will need to read and agree to the User Agreement.
  2. A screen will appear asking you if you want to link a Club Nintendo account to your Wii Shop account.
    • If you have a Club Nintendo Membership, enter your User Name and Password, then select "Link" on the right.
    • If you do not have a Club Nintendo Membership, leave the fields blank and select "Do not link" on the left.
  3. Select "Wii Channels" from the Wii Shop Channel main menu, then select "Netflix Instant Streaming for Wii." Select "Free 0 Wii Points" to begin the download.
  4. Once Netflix Instant Streaming for Wii has finished downloading, it will be added to your Wii menu.After Netflix Instant Streaming for Wii has been added, the next thing you'll need to do is connect your Wii console with your Netflix account. Continue reading for more information.Connect your Wii console to your Netflix account Before you can watch TV episodes and movies streaming from Netflix, you will need to connect your Wii console to your Netflix account.On your WiiIf you're not already on this screen on your television, select Netflix Instant Streaming for Wii from the Wii menu. (Don't have this option?) On this screen you will be presented with a code; remain on this screen during the activation process.
  5. On your home computer
    Using an online device other than your Wii console - such as a PC, Mac, or Web-enabled phone - go to http://www.netflix.com/wii. (You will need to log into your Netflix account if you're not already logged in.)
  6. Still on your home computer
    Enter the code displayed on your television into the box on the bottom Netflix Web page, then click "Activate Now." (The code is case sensitive.)
  7. Back to your Wii
    Netflix will now attempt to activate the connection to your Wii console. This may take several minutes. When the process is complete, the Wii will automatically display your queue. (The screen on your computer will not change. Wait for the screen displayed by the Wii on your TV to indicate the activation has finished before going to another Web page.)
  8. And finally, watch TV episodes and movies streaming from Netflix on your Wii console by selecting the Netflix Instant Streaming for Wii on the Wii main menu
Aug 17, 2011 | Nintendo Wii Console
Trying to hook it with netflix keeps giving me an error code 51420
  1. From the Wii's main menu, select the Wii icon along the bottom left of the screen.
  2. Select "Wii Settings".
  3. Click the left arrow to get to Wii System Settings 3
  4. Choose "Wii System Update"
  5. Choose "Yes" to connect to the internet and perform a Wii system update.
This should remove the error and allow you to watch Netflix.
Jul 23, 2011 | Nintendo Wii Console
Hi! I am trying to connect my Wii to the internet in order to watch Netflix on my tv
Connecting to wireless network
1.Power on your Wii console and press the A Button on the Wii Remote to reach the Wii main menu. Use the Wii Remote to select the "Wii" button.
2.Now, select "Wii Settings" to access the "Wii System Settings" menu.
3.Using the arrow on the right side of the screen, scroll to page two and select "Internet."
4.Select "Connection 1: None"
5.Click on "Wireless Connection" and then "Search for an Access Point."
6.Select "OK" and the Wii will display all the wireless networks it finds.
7.Select the wireless network that is yours.
8.Select "OK," "Save Settings," and then "Yes."
Download Netlix
1.Select the Wii Shop Channel on the Wii Menu.
2.A screen will appear asking you if you want to link a Club Nintendo account to your Wii Shop account. 3.If you have a Club Nintendo Membership, enter your User Name and Password, then select "Link" on the right. 4.If you do not have a Club Nintendo Membership, leave the fields blank and select "Do not link" on the left.
5.Select "Wii Channels" from the Wii Shop Channel main menu, then select "Netflix Instant Streaming for Wii." Select "Free 0 Wii Points" to begin the download.
6.Once Netflix Instant Streaming for Wii has finished downloading, it will be added to your Wii menu.
  1. On your Wii
  2. On your home computer
  3. Still on your home computer
  4. Back to your Wii
  5. And finally, watch TV episodes and movies streaming from Netflix on your Wii console by selecting the Netflix Instant Streaming for Wii on the Wii main menu.
Jul 11, 2011 | Computers & Internet
Setting up wii for netflix
Netflix Instant is available for streaming on your Wii gaming console by early spring 2010. If you have a Netflix subscription you can watch movies and episodes easily on your TV through your Wii console. This article will detail the important things you will need to make sure that you can watch Netflix from the Wii.
Difficulty:Easy Instructions Things You'll Need
  • Netflix subscription
  • Nintendo Wii gaming console
  • Broadband internet
    • 1 Check you Netflix subscription. The minimum subscription plan to watch Netflix instantly is the unlimited 1 DVD at a time plan or otherwise the $8.99 plan. This plan allows to watch movies instantly with unlimited monthly hours.
    • 2 Check internet bandwidth on your broadband connection. According to Netflix the minimum bandwidth requirement is 1.5Mbps. Netflix recommends for watching movies instantly a 3.0Mbps connection. Check with your internet service provider to confirm that these download speeds.
    • 3 A wired connection to your Wii console. An ethernet connection to your Wii console would be preferable. Unfortunately the Wii console does not have an ethernet port but a USB port. A USB LAN Adapter can be found at most computer supply merchants or online from Wii or Amazon.com. The ethernet connection is an ethernet wire from your home LAN router connected to your USB LAN adapter. The USB LAN adapter is then connected to the USB port on the Wii console. This connection will be how Netflix provides the movie streaming feed to the Wii.
    • 4 Sign up at the Netflix website for the Streaming Disc. Netflix will send a specially programmed disc to setup the Wii for watching the movies. When the disc arrives Netflix will provide instructions on how to install onto the Wii gaming console.
Read more: How to Setup Netflix for Wii ' eHow.com http://www.ehow.com/how_5893624_setup-netflix-wii.html#ixzz1OybxaAO2
if this help you please rate me sir thank you so much...
Jun 11, 2011 | Nintendo Video Game Consoles & Games
I just signed up for netflix and am trying to hook it up to my wii to watch movies. The wii is properly connected and hooked up, and we have a wireless internet connection in my home, however when i go to...
Error code 51030 means you Wii is unable to connect to your wireless network.
Try unplugging your modem and wireless router, then plugging them back in after a couple minutes.
While you're waiting for your modem and router, delete your network setting from your Wii, and set them back up once your router and modem are back up.
Your wireless router's setting might have changed and your Wii might not be able to properly connect.
May 08, 2011 | Nintendo Wii Console
How do I set up for nesflix
Netflix on your wii is a great feature. You set up netflix by going to the wii store channel on the wii console and downloading the netflix channel to your wii. You have to have internet set up on your wii first. Then after you have the Netflix channel downloaded you can go to it and set up your netflix account through that channel.
Apr 27, 2011 | Nintendo Wii Console
Video Game Consoles & Games Logo
112 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
