Question about General Electric GSS22JET Side by Side Refrigerator
Ice maker doesnt work - is the green light supposed to be on or off?
Did you get your Ice maker fixed. I have the same problem... I freezer is around -20 and I think that is part of teh problem
Posted on Feb 18, 2011
yalmer
  • 549 Answers
SOURCE: Ice Maker
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Posted on Feb 13, 2008
  • 531 Answers
SOURCE: Ice Maker Not Working, water, frig, and freezer all working
i think is your water filter
Posted on Mar 31, 2009
Sea Breeze
  • 4654 Answers
SOURCE: the ice maker doesnt work, and in the day several times appears water in the floor, in the side of the door of the ice maker
Uplug refrigerator and remove the ice maker so we can look at the tube that comes into the back of the ice maker. It maybe the ice maker is calling for water but ice or a crack in the tube that delivers the water is being deverted to inside the freezer area. Also look behind the fresh food compartment door and see if you can send me the model number so I will be able to go over the correct model. Let me know, Thanks, Sea Breeze
Posted on May 22, 2009
  • 10865 Answers
SOURCE: Ice maker not working
If your ice maker has stopped producing ice completely, check these, in this order:
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
    In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Posted on May 30, 2009
Sea Breeze
  • 4654 Answers
SOURCE: GE Monogram icemaker is not working. The green
Your model uses a electronic ice maker. If the tray has srinking cubes and if you fill to top with tap water, let freeze and if it does not drop the ice the problem most ikely is the icemaker mode=> WR30X10093 The ice maker has a thermistor or thermostat built in and communicates with the circuit board inside to tell when it is time to cycle. You can try the water test and let me know but this is a typical failure with that type of ice maker. If this solve you ice maker problem please rate me. If not explain what you tried and we will try the second test. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, Thanks, Sea Breeze
Posted on Feb 11, 2010
I have GE Monogram Side by Side. Purchased back in August 2006. It has been pretty good except for the ice maker. After the first year a leak ruined our new wood floors. Recently the ice maker has...
The green light flashing is a fault code, usually for a no, or long fill situation, GE has nixed this electronic ice maker and returned to one that looks similar but is non electronic, while your ice maker is probably at fault you may actually have a separate issue causing the ice maker to display a fault code, such as a spent water filter, or low water pressure, or even a bad water valve on the fridge it's self. IM6 is the current replacement ice maker kit for previous ice makers. Pleazer Appliance...
Apr 17, 2014 | GE Monogram Side by Side Refrigerator
Ge ice maker green light blinking
Replace the ice maker. The light should be solid all the time.
Jan 01, 2014 | Refrigerators
Fim120 flashing green light
is there any pause in the blinking light if so count the blinks and the pause and the seconds blinks this will tell you the error code
Dec 11, 2013 | Franklin Chef 120lb. Ice Maker FIM120
The tree green lights stay on and the two red lights blink 3 times
The green light is blinking but the Ice Maker don't work, can you help me.
Aug 27, 2013 | Magic Chef 27-Lb. Ice Maker
The ice maker appears not to be working can not
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
May 31, 2010 | Liebherr KIKNV3056 Bottom Freezer...
GE Monogram icemaker is not working. The green light on the ice maker is blinking every second. I turn the ice maker off then turn on after a few second. The light stays green. After 10 minutes, I...
Feb 11, 2010 | GE Monogram ZISS480DRSS Stainless Steel
Ice maker not working flashing green
heatman101
dfdf
Jul 28, 2008 | GE PSS29NHP Side by Side Refrigerator
General electic gsh25jfta bb
According to the manual for your refrigerator:
Blinking green light indicates an ice cube is stuck in the icemaker. To fix - Turn off the ice maker with the on/off switch. Then remove all of the ice from the icemaker by hand and turn it back on.
I hope this helps.
Jul 19, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Ice Maker Problem
my ice maker stopped making ice. Green light is on. Drinking water is ok
Feb 17, 2008 | GE GSS20IEP Side by Side Refrigerator
General Electric GSS22JET Side by Side Refrigerator Logo
153 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
