Question about Motorola Mobility RAZR V3
Invalid Battery Hi I have a Motorola Razr V3 phone and it is approx 15 months old although it is rarely used with only about one or two brief calls made on it per week. I only need to charge it about every 6-8 weeks, but when I charged it fully last week it now comes up Invalid Battery. It still lets me make a call, but won't let me charge it. It is now out of warranty so the shop I bought it in couldn't help and said it must need a new battery. Surely after such little use it wouldn't need a new battery already, and how could I be sure that a new battery would solve the problem anyway? Any guidance would be appreciated
  • sunflower218 May 24, 2008
    I have been having the same problem with my Motorola Krazer. For months now there have been several problems with the phone: It freezes up and I can't turn it off, delayed reactions on pressing keys, and a lot more. In the 13 months that I have had this phone, I have never left it in the heat, and have not dropped it in water. So why am I having these problems? I have to say I am VERY unsatisfied with this product.
  • mghines Jun 21, 2008
    Have a motorola razr v3 worked for 4 months bought new from ebay now saying invalid battery. Bought the warranty from square trade but because the phone has a crack in the glass the warranty is void. Even thought the screen works perfect it is just cracked glass
Totally discharging the battery is the way to go. But what you can also do to use your phone in the meantime is this. Plug your charger into the phone withOUT your battery in. It will tell you "Unable to Charge." When it says this, put the battery in. It might tell you "Invalid Battery" a couple more times, but it did eventually say "Charging Battery" for me. After that, simply turn the phone on and it will return to normal. This is when you drain the battery completely. Once I did that, I did not get the invalid battery error again.
Posted on Jun 15, 2008
    Guru:
  • 155 Answers
My V3 also said Invalid battery to me so I took it out, cleaned all of the contacts and left it for a couple of days.
When I put it back in I then did not turn it on but plugged it in and charged it overnight.
In the morning it had charged and the problem seemed to be sorted. Fine battery wise ever since.
Hope this helps/works for you
Mowcius
Posted on May 14, 2008
Simple solution here...
...totally discharge battery, then remove battery from V3 for about 5 mins, then put back in and recharge for 12-14 hours.
Solved!
Reason, bat needs recalibration with phone.
Schermann
Posted on May 24, 2008
I took the battery out, cleaned the terminals with an eraser, then swabbed the terminals with alcohol and left it over night. I put it together and plugged in to recharge but the error keeps coming up "invalid battery."
Charlotteinkennesaw@yahoo.com
Posted on Jun 11, 2008
Motorola RAZR V3M phone won't recharge
first check the charger it must be faulty or if the charger is fine then u need to replace the charging connector
Aug 17, 2009 | Motorola Mobility RAZR V3
My RAZR *v3* Drains a good battery in 15 minutes
Go to your provider and have them install a current software version for your phone.
Nov 25, 2008 | Motorola Mobility RAZR V3
Invalid battery
Pull out the battery *while the phone is on*. Wait 15 secs then put battery back in and turn phone on. That should fix it.
Nov 13, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Battery in Motorola RAZR V3
I couldnt find anything that says that exactly but if it keeps happneing then most likely that is the case. There are no active recalls for that battery from motorola so most likely there is something on the phone a short or something that could cause it to overheat or overcharge thereby hastening the wear and tear on the battery
Aug 22, 2008 | Motorola Mobility RAZR V3
HELP WITH UNLOCKING MOTOROLA RAZR V3
You need to call ATT and ask for the code. They will usually give it to you in order to keep your monthly business.
Hope that helped...
Geno
Apr 04, 2008 | Nokia 6288 Cellular Phone
Razr Inop
you need to take the phone back and have it replaced for a new one.
Mar 19, 2008 | Motorola Mobility RAZR V3
Can't hear through earpiece
If the phone is under 1 yr old I suggest finding the nearest Motorola service center as it is under warranty. If its not covered you could replace the speaker yourself, although would require a small amount of soldering or replacing the entire LCD module which could be expensive. Let me know if you decide to give it a try I can help w/ disassembly. Good luck.
Sep 05, 2007 | Motorola Mobility RAZR V3
Motorola RAZR V3
the mainboard is gone and have to either be replaced or taken to a mobile service center close to you and hvae them use special equipment to revive it.
Aug 28, 2007 | Motorola Mobility RAZR V3
Keypad will not work
This happened to mine after I got the Razor wet - I pulled the battery and the sim card, blew it out with a can of compressed air and it worked for about 8 months. Then it got hot out in my car and started doing the same thing - blowing it out hasnt worked again-
Jan 22, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
1,142 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
