Question about Samsung Refrigerators
My refrigerator keeps dinging. It is not continual, it randomly makes a dinging noise. I may ding 10 times in a row then not ding for 30 minutes then ding twice etc. It is not the water filter. It has been replaced. A door is not ajar, it is driving me crazy. I called the repair 800# and they suggested I try to ignore it. Any ideas what the problem could be? I want my peaceful home back.
  • 958 Answers
SOURCE: refrigerator makes lot of noise
based from your story. the noise could be coming from the compressor as it starts. compressor usually vibrates a lot when starting. it would last from a few seconds to a few minutes then would normalize as it sucked all the evaporator pressure down to its normal readings. you can check the rubber mountings of the compressor,you may need to replace them. also check for some tubings that may be rubbing or touching as the compressor vibrates. tighten alllso those mounting bolst of the compressor. that should solve your problem. if everything is done and still the same, the noise could be coming inside the compressor which there will be no solution but to replace the compressor. the cleaning that you did helped it a little bit because the vibration decreased a little coz it was able to breathe a little.
Posted on Feb 13, 2008
Pyrhyc
  • 2028 Answers
SOURCE: Amana French Door Bottom Freezer Refrigerator making noise but not making ice
The noise you hear is the ice maker trying to make ice without a water supply. Check the line to make sure you didn't knock anything loose or kink it when changing the filter, and check for a plugged line. It could be that there is ice build up in the line, a defrost will cure that.
Posted on Jul 08, 2008
  • 10 Answers
SOURCE: door alarm continually dings
This model and the Kenmore equivalent still have lots of bugs... I've replaced the microprocessor board on mine twice -- thankfully under warranty -- costs in excess of $600,,,
my suggestions are:  1)  verify that the two door switches (at top seal area one each side) appear to be working OK -- push them w/ your finger and see if the the refrigerator light goes off  2)  either pull the plug on the refrigerator or open the breaker feeding it -- count 30 seconds and put power back to it -- it's a computer, every so often you have to "reboot" it because it it loses its mind now and then...  3)  you should be able to push (I think the left most touch pad) the touch pad key under the alarm to shut it off....  4) if all else fails, ??? can you afford not to replace it ???
Posted on Jul 27, 2008
New Kenmore / Whirlpool, 25 Ft. side x side. Has drumming noise when running. Checking showed that condenser coils rattle against compressor support rails plus the flimsey rails allow compressor vibration which resonates through out. Looks like Whirlpool cost-cutting crossed the line over to plain old cheapening the product. Waiting on Sears to come check it. Wish me luck. -JT
Posted on Nov 21, 2008
  • 172 Answers
SOURCE: Sears Bottom Freezer Refrigerator - Loud humming noise
That sound is usually your icemaker calling for water. you can turn off your icemaker by lifting the little arm on the icemaker. As the icemaker calls for water the valve will be activated and will hum. This sound is usually not very loud. If your valve is making that much noise you may consider replacing the valve. The part number for you water inlet valve is #2315533 The retail price is $60.18 . I do have these on hand and available to ship out today if you need one. Please just let me know. You may also consider replacing your filter if your refrigerator has one. Thanks and I hope this will fixYa
Michael Anderson
Anderson Appliance
(865)945-3808
Posted on Feb 17, 2009
Turn off the ding ding noise on a 2003 bonneville SSEI? The emergency brake has been disabled but the ding noise will not go away
Wait, you are driving a car with the E brake disabled? Perhaps you should remedy this very dangerous act and fix the ding at the same time.
Feb 12, 2015 | 2003 Pontiac Bonneville
Constant dinging sound whenever the key is in the ignition. all doors are closed, and still the ding, one every second, until the car is off. continues no matter how long the ride is. 45 minute trip and...
These can be annoying and hard to find, Since it's a 2 door , check the buttons that the door hits when closing. Snap them in and out several times and if you have it, soak them with something like WD40. Is a dashboard light on to give you a clue ? The ding might also be related to the seat belts. Make sure ALL are snapped into their sockets to test that. Last resort is cut or disconnect the wire that goes into the "ding" module. I would recommend a mechanic with a tester who can pin down the problem and it should not take more than a hour labor or around a hundred bucks.
Oct 20, 2013 | Ford Cars & Trucks
New refrig from lowes one week old. now makes ding ding ding ding ding noise 5 times? looked in manual no help
Hell Bill, I am happy to assist you! Sounds like you are referring to the temperature alarm. When the refrigerator is beeping or buzzing, it may be a warning sign of a possible malfunction or an unsafe, interior temperature. To silence the buzzer, you can depress the ALARM OFF button. However, if you have already done this, try unplugging the unit or flipping the household circuit breaker for about ten minutes.
If the alarm continues, it could possibly be experiencing a communication problem with the temperature control/board or wiring failure. I would recommend connecting with a professional appliance tech for a clear-cut diagnosis or the manufacturer directly.
Aug 01, 2013 | Frigidaire Refrigerators
When i turn the head lights on. Car makes a ding ding ding noice
ding ding noise remind you.your headlights still on when you turn off vechicle you dont need to turn on headlights on by switch if your car has the automatic day time running lights they on all the time lights have sensor on dash turn on headlights when it gets night time.
May 21, 2013 | Cars & Trucks
(door ajar) and dinging when turning corners to right!! help
check the little rod that sticks out the door jam and make sure its in the proper spot if it got knocked somehow it could be closed but it doesn't know it and will ding
Jul 19, 2009 | 2005 Kia Sorento
Keep switching between jet and express. making ding ding ding noise.
Please explain what your meaning of jet and express so I can help you better. LG refrigerators are hard to get parts for. But, I can help you. So I can help and will you look for the model listed above your post. Please confirm the model number, this is very important, Thanks, Sea Breeze
May 02, 2009 | LG LRSC26930 Side by Side Refrigerator
Door alarm continually dings
Jul 27, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
Refrigerators Logo
143 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
