Question about Bose Lifestyle 12 System
System has no power. i have confirmed that the power supply is good.
  • 1 more comment
  • ianaus Sep 12, 2010
    Sebin
    How do I check the power supply code. BTW, I'm in Sydney Australia. Have had no power problems since i bought the system over 10 years ago. Yesterday, the radio reception was very bad. I moved the antenna and powered the system down. It wil not power up now.
    Ian Scoines
    Sebin
    Ian Scoines
    Sebin How do I check the power supply code. BTW, I'm in Sydney Australia. Have had no power problems since i bought the system over 10 years ago. Yesterday, the radio reception was very bad. I moved the antenna and powered the system down. It wil not power up now. Ian Scoines
  • 712 Answers
Have you checked the status of the power supply code?Sometimes the code in some positions may not transfer power to the system.
Posted on Sep 12, 2010
  • Sebin Punnacheril
    Sebin Punnacheril Sep 18, 2010
    To check the power supply code, replace the power input code with a new one and see if the system is powering up.
  • Bose Master
  • 19,396 Answers
Hi.
To start the Lifestyle has two parts that are independently powered. If there is no power to the acoustimass (subwoofer), and there is voltage in power cord, then the internal power board in the sub woofer is shot.
If the music centre (the one with DVD) has no power, but the adapter has regular voltage, then:
If there is no power at all, the music centre is faulty. Problem is in the initial circuit connected directly to input. There are a couple of resistors directly on DC line that may fuse. The connector pins may also break.Testing is done at component level.
If the music centre has led on, then the problem is often the data cable from acustimass. If there is any problem with cable and connectors the music centre will stay in standby and not start to prevent eventual damage.
How do I power up or turn on this type power supply made without an SPST switch?
well some of them run from a digital control switch but almost all hp compaq power supplies have a power switch on outside of box please provide s/n or service number for this to confirm
May 28, 2012 | Compaq (243890-001) 250-Watt Power Supply
161071-001 Manual
The power supply is very inexpensive and can most likely be bought from any of your computer retailers, Amazon - Just make sure to confirm the right model type of power supply.
Feb 20, 2012 | HP/COMPAQ - 161071-001 (161071001) Power...
The fan of power supply is not running
The power supply is very inexpensive and can most likely be bought from any of your computer retailers, Amazon - Just make sure to confirm the right model type of power supply. BEST to have it tested before replacing it. To make sure that is the issue..
Nov 11, 2011 | HP (152769-001) (152769001) 250-Watt Power...
When i turn my computer on, all fans are confirmed working, but it only runs for a few seconds and then turns off. I have confirmed the heat sinc is properly in place, I confirmed the system is not...
The fans are controlled by the motherboard, not the power supply. Normally the fans will not run and or run to where you can hear them unless the temp reaches a certain point within the case. The computer will warn you if it is overheating.
Mar 20, 2011 | Sparkle Power SPI Power Supply FSP300-60PN...
Computer won't power up. How can I confirm that it is in fact my Bestec ATX-300-12EB3?
The quickest and easiest method.
Beg or borrow another power and connect it to your computer.
Feb 11, 2011 | Gateway Bestec ATX-300-12EB3 305w Power...
When the board is powered,it goes off.
hello cyokwueze
usually when a system turns off within a few second it indicates either a faulty motherboard or power supply.
based on what i have seen in the past i tend to say it is the motherboard. what you need to do try a different power supply and if it is still the same it confirms a faulty main board.
good luck
Feb 09, 2011 | ASUS P5GC-MX/1333 Motherboard
I've just installed a psda400 Diablotek power supply on an older compaq. On power up, no fan and red flashing light. Any ideas?
Get another power supply from another company. I purchased a Diabletek PHD450. It failed out of the box (verified by using known good supply). This was in July 2009. I got a RMA and they returned the same dead power supply with the same problem. After several calls I got another RMA. I returned the supply. UPS confirmed delivery. they still have not sent a replacement. It is now April 2010. When I call the support number on their web site I am given another number - no one is ever there. NEVER AGAIN - DIABLOTEK IS DEAD.
Feb 26, 2010 | Diablotek 400-Watt Power Supply
Computer wont boot have steady amber light on the start push button nothing on monitor
check you power cable and extension socket for steady power supply. if it is ok, consider plugging it into another outlet. if that fails, check your memory card. if you have more than one card installed, consider taking one out and restarting with one. if it fails, swap it with othe on and the othe out. if it fdails, take out the C-MOS battery from the motherboard and replace it after 2 or more minutes. restart the system.
Jul 23, 2009 | Computers & Internet
Computer won't start
The power supply is fried partially, or the motherboard went poof.
Dec 19, 2008 | Antec TruePower 2.0 550W 24/20pin nVidia...
Power Source/Supply
Confirm the wattage(how many watts e.g 150W) needed by your system from your manual.Make sure the wattage of power supply you are buying exceeds it or is equal.
Jul 15, 2008 | Computers & Internet
Bose Lifestyle 12 System Logo
174 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
