Question about Alpine MRP-M450 Car Audio Amplifier
I removed the remote wire to change the amp position, and when I hooked it back up, the power light came on for a brief second and then faded out. Not to come back on again
  • 291 Answers
The remote wire might have touched ground... make sure you still have voltage on the remote wire with the radio turned on....another test is jump the main red wire to remote also..
Posted on Sep 12, 2010
  • Alpine Master
  • 637 Answers
Verify that you still have 12 volts on the remt.
Posted on Nov 25, 2014
I have 12 volts constant on my power wire coming from my battery but when I connect the p.cont. wire to the amp the voltage drops out. The green indicator light comes on for a split second then fades away...
Your P.cont is not hooked up to a correct power source... Make sure that you dont have it possibly hooked up to the power antenna wire by mistake. The p. cont. (remote turn on) should always send constant power one the key is turn on in the vehicle.
Mar 18, 2011 | Kicker Car Audio & Video
My amp blew the 20 amp fuses. Replaced and they blew as soon as the radio kicked in. Took the back off to look for any burnt connections or blown open/expanded capacitors or resistors. It smells like...
Remove all the wires from the amp including the remote turn on wire. Once you do that, after about 30 seconds the amp will reset. Hook the power up first, then the ground then the remote. Turn the unit on and check for power WITHOUT the speakers hooked up. If you get no power by now it's a good chance that the amp is cooked. If you do get power, try hoking up your speakers first on one channel then the other channel and then bridged. If it cuts out or off when you touch the speaker wires to one channel or the other, then that channel is no good. Hope this helps.
Mar 17, 2011 | Kenwood KAC-728S Car Audio Amplifier
I have this hooked up and works fine with the key on, but when i start the car, sub light, amp and sub dont come on.
You have connected it to the wrong power wire - one that is only active in service mode - first key position.
You should draw a wire directly from the battery (don't forget to add a 40 amps fuse on the wire) to the amps. If you don't want them constantly operational (you will have to manually shut them down) install a relay on the wire with the command coming from a wire from the instrument key position - second position of the key. Use a voltmeter to identify the wires.
Oct 15, 2010 | Rockford Fosgate Power 351M Car Audio...
My amp turns on but stay in protect mode
check your wiring, is it properly grounded? is your remote positive wired to your ignition's positive line?
Jun 10, 2010 | Car Audio & Video
All wires are hooked up but no lights come on, is
Hi Wex,
Wires being hooked up is fine. With no lights coming on the question becomes one of power.
Ground needs to be grounded.
+12VDC should have +12VDC
Remote should also have +12VDC when the stereo is on.
Check these with a volt meter. Negative lead on the ground terminal, Positive on +12V then Remote.
Both combinations should read +12VDC.
Next check the fuses if any that your amp has. Make sure they aren't blown.
Comment back if this doesn't point you in the right direction.
Mike
Dec 08, 2009 | Infinity Car Audio & Video
My kenwood amp wont turn on all the way i just hooked it up to my truck. the blue lights and the fan come on but the red light wont come on to power my subs
REMOVE THE RCA INPUTS AND DISCONNECT THE SPEAKERS, THEN POWER THE AMPLIFIER UP WITH THIS NO INPUT, NO SPEAKER LOAD CONDITION. IF IT STILL DOES NOT POWER UP, VERIFY THAT THE POSITIVE AND ESPECIALLY THE GROUND CONNECTIONS, ALONG WITH THE REMOTE CONNECTIONS ARE 100%, THEN TRY AGAIN. IF STILL NOT POWERED UP, MEASURE THE REMOTE WIRE VOLTAGE TO INSURE THAT IT IS NOT LOWER THAN 11 VOLTS. IF YOU CANNOT MEASURE IT, THEN DISCONNECT THE REMOTE LEAD FROM THE AMPLIFIER AND TEMPORARILY INSTALL A JUMPER WIRE FROM THE POSITIVE POWER TERMINAL TO THE AMPS REMOTE TERMINAL WHICH WILL FORCE IT TO TURN ON. IF IS STILL DOES NOT POWER UP, THEN IT WILL HAVE TO BE SERVICED. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Nov 20, 2009 | Kenwood KAC-7203 Car Amp
Basslink Powerlight comes on then fades quickly
check to make sure your remote wire is hooked up to your amp turn on that runs straight out of the stereo not your power antenna also make sur you have a clean ground(no paint or rust) and also check your connections make sure you have a strong connection to all wire hook ups.......you should check to see that your remote wire has no tears in it or small rips or cuts because that can interrupt your current to and from the amp and radio
Jun 25, 2009 | Infinity BASSLINK Car Subwoofer
Kenwood kac-x1r flashes code e-03
HI DUDE EVERY REMOTE WIRE THEY HAVE FUSE NEAR THE BACK OF PLAYER TRY TO CHANGE IT .... R...TRY UNPLUG UR AMP .. AND ..FIX IT BACK
Apr 16, 2009 | Kenwood KAC-X1R Car Audio Amplifier
How do i intall my amp?
first you need to run a power cable for the battery to where ever you are going to place the amp DO NOT hook the cable to the battery until the very last just wire it to the amp for now.next you will want to ground your amp hook the ground wire to the amp and the other end to a solid piece of metal in the car this is very important if you don't get good metal on metal contact you'll blow a fuse. If you can hide it well strip back a bit of carpeting and use sand paper to remove all paint from the metal and drill a hole for a screw. once that is finished you will need to run a remote wire from the amp to the car stereo usually these are the blue wire on the harness in the dash. once that is hooked up run the rca cables (reds and whites) plug in to amp and then in to back of cd player. once this is all hooked up and fully secure hook the power cable to the battery make good contact and if everything is grounded right you should get the lights on in the amp. Next step hook up the speakers run speaker wire from the amp to your speakers make sure negative goes to negative and positive to positive or you'll get clipping and it will sound like ****. that's pretty much the jist of it. if you have any questions let me know.
Mar 08, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
AMP turns ON then turns off
The power antenna wire only supplies 12vdc when the radio is on. When CD or other sources are selected, the power antenna wire goes to 0vdc. The remote turn-on wire provides 12vdc whenever the head-unit is on. If your amps are powered on only when the radio is turned on, I would bet that you have the power antenna wire connected and not the remote turnon wire.
Sep 11, 2006 | Ultra Linear UL-2200D Car Audio Amplifier
Alpine MRP-M450 Car Audio Amplifier Logo
198 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
