Question about Samsung Heating & Cooling
Hi..we have switched on AC yesterday night after 3months. Water started to drip from the front. What could be the reason and fix to the problem?
    Problem Solver:
  • 19 Answers
Clogged drain condensation drain pipe. They use to recommend white vinegar for cleaning, but they now say even it can damage lines for being to strong. The sell a product Zest at home depot, it's like orange and environmentally safe made with oranges or something.
Anyways use that stuff.
I would first check the outside pipe for an obvious blockage like grass, dirt or dead animal. Then right by your indoor unit will be the start of the same pipe, if the leaking is there, then that's it, if it's somewhere else could be in the unit which you will need a repair man, nothing easy inside the main unit except lots of shocking things.
Open the pipe inside and try pooring some cleaner in , wait a bit then turn back on and see. If it's a bad clog, what I did was to take a long hose, run it in the house to the pipe. I put folds in the hose to do it alone, or have someone outside to yell to turn it on. Put the hose against the pipe inside flush as possible and that should force almost anything out. Be sure to have a couple towels ready cause it's nearly impossible to not spill some water doing it this way.
Posted on Sep 12, 2010
Why wouldn't water circulate through the radiator
You are spot on. Bad water pump. It is also probably the reason your timing belt was frayed. The water pumps of later model cars usually drip some through a "weep" hole in the bottom when they are going out as a kind of warning "Hey, you gotta get me a replacement soon!" But unless you live where no air conditioner is ever needed, or used, most people think it is the drippings from the AC. Get that pump replaced ASAP and when done, do a compression check on all your cylinders to make sure there was no head gasket damage from overheating. Good luck.
Apr 22, 2014 | Kia Sportage Cars & Trucks
How to find a oil leak in a 2008 Yamaha V-Star 250
Hi, Anonymous due to the magnitude of yesterday's solar flare my night and x-ray vision optical devices have become inoperable so you will have to be my eyes, to find the source of your oil leak, start at the point where you see oil and trace its path going up and forward, if there is too much oil present then buy a spray can of engine degreaser apply it to the affected area then rinse off with a pressure wand or garden hose, use compressed air to blow off excess water or just let it drip dry, take your bike for a 5 mile ride and check for the leaks. For more information about your issue please click on the blue links below. Good luck and have a wonderful day.
Star 650 Neutral Switch Oil Leak Fix
Engine Crankcase Pressure and Engine Oil Leaks
Yamaha XV250G Supplementary Service Manual
OEM parts for Yamaha
Yamaha VIRAGO XV250R Owner Manual
Jul 28, 2012 | 2008 Yamaha V Star 250
Split AC whole unit turnig off at each compressor start up!
Dirty coil wash outside unit with water and change indoor unit filter
Jun 08, 2017 | Heating & Cooling
Where is the drain hole on goldstar window ac my ac keeps dripping water inside the house
Hello, make sure the unit is tilted toward the outside a bit, if it is level the condensate will collect in the front and start dripping inside the house. Also, if the unit has a drain make sure it is clean so the water can drain out properly.
Jun 07, 2011 | Goldstar KG6000R Window Air Conditioner
Hi, our 2003 focus wont start. The engine light, the ignition light and the oil light are all on. We have checked the battery and all the fuses but nothing there seems wrong. We've only had this car for...
could be the belt tensioner is bad. That will loosen the belt so the car battery goes weak and will make a bad noise. Could have gotten a defective alternator.
Mar 07, 2010 | 2006 Ford Focus
AC unit dripping water and won't cool
The coil is likely froze up due to dirty evaporator plugged ,air filter or low on freon .Tom
Jun 18, 2009 | Heating & Cooling
Samsung ac model aw25ecb7
hi! bill,
water drip it should be outsidethe house,beside there is a spout on the basin of your ac unit and hose to drip off outside the house,all you gonna do insert a piece of wood or metal on front side of basin, in between basin and the wall,just small piece object to elevate the basin to outside wall,the water will not stored in the basin.or make a spout, drill a hole 1/4" size at the corner at the backside of basin out side your house,be carefull not to drill condenser tube or the fan blade,insert a plastic hose 3/16" and weld it by glue gun.and end of hose put it an empty bottle so that the water drip will not scattered outside your house.regards and don't forget to rate me,thank's a lot
Apr 29, 2009 | Samsung AW0503B Air Conditioner
Water Leaking
Dear Customer,
The likely reasons for a leaking AC are...
1) Improperly installed.
A window air conditioner must be slightly lower at the rear than the front. This allows the water being removed from the room to drain to the back of the machine. A difference of one inch is sufficient. This is always the first thing to check. Many are improperly installed in the haste to get relief from the heat. If installed too low at front the water will flow into the room rather than outside. If installed too low at rear, water can roll out front edges before has chance to exit towards rear drain.
  1. Icing up.
    Water being de-humidified can turn to ice if there are problems with the cooling system. There are many reasons for an air conditioner to produce ice. Remove front grille while machine is operating. If ice is present on the cooling coil you will probably need service. For more information see our other article: Why window Air Conditioners Ice up.
  1. Air leakage around air conditioner.
    If warm air is able to enter around the air conditioner it will encounter cooler, dryer air. When they meet condensation will occur. If water leaking from front of air conditioner inspect to see if dripping from body of machine, or water droplets clinging to front area. To test, operate machine for 30 minutes and then use flashlight to check under front edge of base. Small water droplets here indicate an air leakage problem. Add foam insulation to stop warm air from infiltrating.
  1. Drain hole blocked.
    Rear of air conditioner base has a drain hole or groove to allow water to escape. If becomes blocked water can back up. To test, operate machine for 30 minutes and then inspect if draining properly. If appears blocked use a small piece of wood to open drain hole at rear of metal base. CAUTION: Never be tempted to drill holes into the air conditioner body to relieve water pooling. Severe damage can result.
  1. Internal drains blocked.
    There are small passageways that allow water to drain from front of air conditioner to the rear. If they become blocked water will pool at front of machine and overflow onto floor. If this happens the air conditioner will require removal from window and servicing.
  1. Outside temperature too cold.
    This occurs at end of cooling season. If outside temperatures drops below 60 degrees Fahrenheit at night the cooling coil may ice up. If no leakage at bedtime but water in front of machine in morning, suspect this problem. If this problem suspected turn off machine before bedtime and restart as day warms. Alternately, operate machine at night with selector switch in ‘fan only’ position. This will circulate room air during night but not allow cooling.
Hope u find this useful. I'll be thankful if u could rate this. thank you.
Jul 10, 2008 | Samsung AW0505M Air Conditioner
Heating & Cooling Logo
73 people viewed this question
Top Samsung Heating & Cooling Experts
Nyte_Ryder
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
