Operation manual for Casio cfx=9850gb plus - Office Equipment & Supplies
Casio CFX-9850GB Plus/Product User Maunal
Link for manual: http://support.casio.com/pdf/004/fx_plus_ch_intro.pdf
Posted on Sep 12, 2010
How to use casio 9850GC PLUS to solve equations in polar form?
Put the calculator in Equation solving mode. Select F3:Solver. Enter your equation; use X as unknow (no need to use Theta, the name of the variable is irrelevant.) Besides if you use theta you will get a syntax error.
Jun 29, 2012 | Casio CFX 9850GB Plus Calculator
I have casio cfx 9859gb plus i dont know how to change from deg to rad pls help
Press SHIFT [SETUP] to bring up the setup screen. Move down to the line beginning "Angle" and select "Rad."
Nov 29, 2010 | Casio CFX 9850GB Plus Calculator
Casio CFX-9850GB Plus calculator will not switch on when AC/on pressed, all 4 AAA and 3v backup battery are new.
If it is just a matter of the screen being too dim, you can actually increase the contrast.
  1. Turn calculator ON
  2. Press [MENU] even if you do not see anything
  3. Press [ALPHA][COS] sequence to access the letter E.
  4. Press repeatedly the Right Arrow till the contrast is adequate.
Jun 14, 2010 | Casio CFX-9850G Plus Calculator
Casio cfx-9850gb plus calculators's graph messed up
Press the RESET button on the back of the calculator. Use a starightened paper clip.
May 05, 2010 | Casio CFX 9850GB Plus Calculator
Do i have only one type of exponencial regression o my 9850gb plus?
Th CFX-9850GB Plus is programmed to perform 10 types of regressions, namely
LinearReg: Linear y=ax+b
Med-Med also linear y=ax+b
QuadReg :Quadratic y= ax^2+bx+c
Cubic: y=ax^3+bx^2+cx+d
Quartic: y=ax^4+bx^3+cx^2+dx+e
LogReg, logarithmic: y=a+b*ln(x)
ExpReg, exponential y=a*e^(bx)
PowerReg, power: y= ax^b
SinReg, sinusoidal: y=a*sin(bx+c) +d
LogisticReg, logistic; y= c/(1+a*e^(-bx))
There may be more regression models appropriate for more advanced (specialized) statistics but the ones in the list are all the CFX-9850GB plus offers. However, since the calculator knows a programming language, you may want to implement a particular model.
Hope that helps.
Oct 24, 2009 | Casio CFX 9850GB Plus Calculator
Generating random numbers
Turn calculator ON, press MENU if you see no icons. Use arrow key to highlight the RUN application. Press OPTN, press F6 to pan right. Press F3: Prob, then F4:Ran# then EXE to execute.
Each time you press EXE a new random number is generated. You might want to fix the number of decimal digits to less than the 10 digits displayed by default.
By default number generated are between 0 and 1. If you want numbers between 0 and 100 you enter Ran#(100).
Hope it helps.
Oct 20, 2009 | Casio CFX 9850GB Plus Calculator
Ma error appears in stat menu with casio cfx-9850gb plus
Here are the possible causes for such an error
1. calculation results exceeds calculation range.
2. Calculation is outside the input range of a function
3. Illogical operation (division by zero, etc.
4. Poor precision in sigma calculation results,
For all these reasons
Check the input numeric values and correct them . If you are using memory, check that the numeric values stored in memory are correct.
Hope it helps
Apr 07, 2009 | Casio CFX-9850G Plus Calculator
Confused
Here is the link to the user s manual.
http://support.casio.com/manualfile.php?rgn=4&cid=004002005
Hope it helps.
Dec 18, 2008 | Casio CFX 9850GA Plus Calculator
In it's back, there is a small hole-reset key. prick it with your pencil.
Nov 11, 2007 | Casio CFX 9850GA Plus Calculator
jasbo
jasbo
