Question about Frigidaire ATF6000ES Front Load Washer
Washer didnt drain properly - Frigidaire ATF6000ES Front Load Washer
  • 3 Answers
Sounds like an object may have gotten in pump which you will hear when draining or spinning
Posted on Sep 12, 2010
Washer will spin to dry but water comes back after short time
how far down is the drain hose pushed in to the drain pipe?should only be like 3 to 4 inches,also the drain hose should be up higher than the water level in the tub.if you can pull out the drain hose try this,fill up the washer on small,after it fills,pull the hose out of the pipe and then stick the hose a few inches into the drain pipe and then turn the timer to the spin cycle and let it drain,after it stops,pull the drain hose out of the pipe,if no water enters back into washer you know that it has something to do with the way the drain hose is in the pipe or another problem.if you're saying that the drain hose is sealed to the drain pipe in the wall you will have to get in there and separate it,pull out the hose and check it,it sounds like this is where the problem is,you had the pump changed and i don't know why the guy would do this if the washer was draining so you know that's not the problem and if they changed the water valve on the washer you know water isn't leaking into the washer from the valve so i would check the drain hose.hope this helps
Apr 25, 2013 | Maytag LSE7806A Top Load Stacked...
There is a code on my washer ue, oe can u tell what it means and how to fix the problems
Check the next solution procedure (click image for zoom)...
Now, about OE code check the drain pump filter: items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Check the washers drain hose... if the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Confirm that the washer is leveled properly, if the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a LEVEL on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
Hope helps (remember to rate and comment this free answer)..
Sep 16, 2011 | LG WM-2277HW Front Load Washer
It wont work it flashes fl
the Fl code indicates an overfill condition. If the washer is empty, then you likely have a problem with the water level pressure switch. If the washer is full of water and will not drain, you likely have a problem with the drain pump or the washer drain line.
If the washer is full of water, make sure that the washer drain is clear and working properly. Check the drain hose for kinks or clogs. If you find no problems with these issues, I recommend that you manually drain the washer using a wet/dry shop vacuum. Check the drain pump and connecting hoses for problems. You may need to replace the drain pump of water will drain out of the washer properly but the pump will not work properly. A clog in the check ball assembly at the bottom of the tub can also prevent the washer from draining properly.
Aug 11, 2011 | Maytag Neptune MAH5500B Front Load Washer
Washer will not spin out, get error message OE
An OE error indicates that the washing machine has not successfully drained the water in ten minutes. However, the OE error code does not always mean that the washer requires a service call. If periodic maintenance has not been performed on the washer, there are a few simple steps to take before calling for service.
*Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
*Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
*Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a LEVEL on the washing machine, the bubble should be in the center. Confirm that the washer is leveled from side to side and front to back.
Hope this helps.. A 4 thumbs-up rating is greatly appreciated for answering your free question. Thank you in anticipation.. Good luck! ;)
Jun 11, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I have A WhirlPool Cabrio.. when i start a load.. it flashes "FL' and beeps excessively.. how can i fix and prevent that?
Feb 20, 2011 | Whirlpool Cabrio HE 4.5 cu. ft. Washer
Hello, my washer is flashing a code F 21 what does this mean?
The F21 error code indicates a long drain. Here are some tips that should help you resolve this problem:
Check your washer drain to make sure that it is draining properly.
Check the drain hose for kinks and clogs. Make sure that it is installed properly per the instructions in your owner's manual. An improperly installed drain hose can prevent the washer from draining properly.
Check for excessive suds in the washer tub. Excessive suds can prevent the washer from draining properly and will result in the F21 code. Make sure that you are using the proper amount of HE (High Efficiency) detergent to prevent excessive suds.
Place a shallow pan on the floor beside the washer and then pull the drain hose out and place the end of it in the shallow pan to see if the washer will gravity drain. If it does, then excessive suds or a drain pump problem could be causing this failure. If the water does not drain or drains extremely slowly, you could have a clog in the drain system of the washer.
Aug 24, 2010 | Kenmore HE2 Plus Front Load Washer
The washer makes a really bad noise when it tries to drain and doesn't always drain properly.
Hi.
sounds like there is either something inside the drain pump filter thats hitting the drain pump impellers or the drain pump itself is failing.
You should have a bottom plynth (you didnt give model number so cant confirm 100%) . Make sure appliance fully drained. Remove plynth and you should see a filter unit. With a few towels to hand unscrew the filter and using a torch have a look inside to see if there is something catching the drain pump.
Hope this helps
Aardvark Repairs
Nov 18, 2009 | LG Washing Machines
Morning, LG WD1295FB error OE, plese advise
An OE error presents if the washing machine has not successfully drained the water in ten minutes. However, the OE error code does not always mean that the washer requires a service call. If periodic maintenance has not been performed on the washer, there are a few simple steps to take before calling for service. oe_led.jpg oe_lcd.jpg LED display models LCD Display Models Step 1: Check the drain pump filter. Step 3: Confirm that the washer is leveled properly. Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine. An OE error presents if the washing machine has not successfully drained the water in ten minutes. However, the OE error code does not always mean that the washer requires a service call. If periodic maintenance has not been performed on the washer, there are a few simple steps to take before calling for service.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a LEVEL on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
Oct 26, 2009 | Washing Machines
Lg tromm wm2277hw rinse spin error OE
Oct 26, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My washer stops!
You should check and clean the outgoing water screen to make sure your washer can drain properly. Sounds like you have a restriction in your system.. could be a filter screen or the pump itself. Try the screen first and then cycle a load of wash without any clothes in it to see if it empties the drum completely.
Hope that helps...
Aug 13, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
14 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
