Question about Mitsubishi WS-65513 65" Rear Projection HDTV
There is not reception. Antenna A failed a year a go, I switched to Antenna B and now is not working either. When I connect Cable (COX) antenna inputs, A & B, do not detect it. My TV is a Mitsubishi WS-65513
  • Mitsubishi Master
  • 17,130 Answers
Check if the video /audio input( AV) works ok.If so the tuner inthe set is defective and must be replaced.
please replace one to confirm after checking the +B voltage on the tuner being present.
Posted on Sep 12, 2010
Bad radio reception
This will be either bad antenna connection in the back of the receiver, bad antenna cable, insufficient or poor antenna type, or possibly a bad earth connection.
Feb 12, 2013 | Kenwood Car Audio & Video
Am fm reception bad
FM reception is weak
What to do
• Extend the power cord as much as possible. The FM antenna is in the power cord.
• Move the power cord to adjust the FM antenna
• If you still have problems with FM reception, you may need an external antenna.
* Call Bose®Customer Service to request one.
The external antenna on your radio is a coax (round) design It needs an adaptor and an antenna which are cheap.
Easy to make, radio shack "F" connector 90 degrees or straight, to 300 ohm wire connections. Attatch a 300 ohm flat ribbon antenna cable to those two screws and plug into radio and see how your reception is. You will need to position the antenna wires to get best reception. I have hid them in back of paintings and so on.
Cheapest solution next to putting an extension cord on radio power cord.
Jan 03, 2011 | Bose Wave Radio
Kdl-37w55/57 sony bravia problem is every so often the picture seems to stutter,delay best way to describe it. Any ideas
hello, try tightening your antenna connection this happens when your signal input cable is fualty or loose check that first. then try all other connection that come from your cable,sat reciever or antenna hook up. if your using a digital reception device or digital antenna check those connections to. and be aware that digital reception has interuptions and they depend on the distance between you and the digital signal broadcast station, sometimes storms and atmospheric conditions may cuase a brief lapse in the signal.(stutter) what are you using for a reception? satelite, cable or a digital antenna? hope this helps
Jun 04, 2010 | Sony Televison & Video
My tv just stopped getting antenna reception today.
It is not possible clear picture use indoor antenna it is use cable tv then get a lot of channel enjoy
Sep 24, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
FM/AM reception problem
It should- that splitter is generally used for factory telephone reception and also there is an antenna located in the rear window glass. It will work for radio reception but it will interfer with your phone if you have a phone installed. just make sure you have a good antenna ground. Try removing the grond and sanding the metal so that there is no paint or oxidation that causes higher resistance. This generally affects a.m. reception.
Jul 17, 2009 | 1998 Mercedes-Benz S-Class
Fm stereo
FM radio reception relies on a very good working antenna and cable, AM reception much less so. Unfortunately, the problem could be in the radio itself as there are separate signal processors in it for FM and AM. However, the most common problem is a bad cable connection at the antenna or the radio, or a bad cable itself (corroded, pinched, broken wire inside).
A couple of simple things to check: if the antenna is in the window, it may have become disconnected from the cable at the window. If the antenna is body mounted, could be a bad cable connection at the base of the antenna, and in this case, the base of the antenna could be very corroded.
You could also check the antenna cable from end to end using a continuity checker. If you can't figure that out, you could just try replacing the cable (or body mounted antenna in that case).
Dec 19, 2017 | 1997 Jeep Grand Cherokee
Radio does not work
put a wire in the antenna hole while radio is on if you get some reception then you know its your antenna do you have sirius if you do it sometimes it runs through your antenna if you dont then check your antenna wire where it connects to the antenna good luck.....
Dec 28, 2008 | Pyramid PDVD79 CD Player
Can't Get A Radio Signal When I Connect A Cox Cable
Hi...
Some cable companies dont put the FM band on cable and some others put an FM trap (which kills the FM band) in line with the cable.
One of those is your problem.
You'll need to buy a FM antenna
Jul 25, 2008 | Sony STR-DE597 Receiver
Better fm reception
Is it just a single wire?
If so, purchase a cheap FM antena. It looks like a "T" when spread out (4' to 5'). That should help.
You can purchase an "amplified" antenna, but if your area reception is really bad (such as in a valley) the antenna would just amplify the noise as well. Look for web based radio in this case or if you have cable there are stations on it.
Jeff
Jan 11, 2008 | GPX HM3817DT Shelf System
Mitsubishi WS-65513 65" Rear Projection HDTV Logo
77 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
