Question about Samsung HLT-5075S Television
My Samsung Dlp model hlt5075s was working great with great picture for last 2 years. This afternoon I went to cut it on and it the three lights on the bottom right started blinking(standby, time, and lamp) and it chirped like it was trying to cut on but all i got was a black screen. Tried unplugging it, but to no avail.
  • Samsung Master
  • 8,457 Answers
The projection lamp life is over.2 years has not been replace projection lamp,tv on daily watches like 4 or 5 hours a day?u need to replaced the projection lamp.
Posted on Sep 12, 2010
TV lamp has been replaced, still won't come on, no picture. When turned on, I can see a blue, kind of sparking light and noise starts and does this about three times. TV powers down and does this again....
Samsung DLP TV Repair - No Picture - Replacing ...
? 2:41
https://www.youtube.com/watch?v=pBTgk_C5FVU
Jun 11, 2012 - Uploaded by ShopJimmy.com
DLP TV Repair No Picture Bad Lamp Bad Bulb TV Won't Turn On DIY Samsung DLP TV Repair How to replace Faulty LampTutorial Click Here to ... Rating is available when the video has been rented. ... is a replacement for the following DLP Rear Projection TV models: ... SAMSUNG HLR6167WX/XAA
Samsung DLP problems - Help! - ecoustics.com
www.ecoustics.com > ... > Home Video Forum > Projection TV Forum
Oct 26, 2009 - I have attached a picture of to show where the "Light Tunnel" is located. Upload ... So now I have a Samsung HLN5065W/XAA that I am willing to part out or sell as is. ... I replaced the ballast but the TV still won't turn on. .... The lamp has been sitting on a shelf until two weeks ago, when the TV went dark. Samsung DLP Light Ballast
Apr 10, 2009
Archive through October 26, 2009 - Samsung DLP problems ...
Apr 8, 2009
Samsung DLP Flashing Standby light
Jul 1, 2006
More results from www.ecoustics.com
Jan 19, 2016 | Samsung SELECT HLR6167WX/XAA Rear...
Samsung hlp-5063w no picture when its on
Do you have three flashing lights on the front? You most likely have a problem with your lamp or color wheel. Those two component combined are pretty much the guts of your TV. If you are handy, you can replace those parts yourself. I have a 50" Samsung DLP and I've already replaced those to items myself. Otherwise, you can contact Samsung at 1-800-SAMSUNG and they can assist.
I bought my parts using Amazon, had them shipped to me, and took an afternoon to take about the back of the TV; documenting everything and taking photos of the progress, until it was done. There may be video tutorials on Youtube. There was for my model (HLS5086). Here is a great link to help you along. Good luck.
http://blog.trebacz.com/2011/01/50-samsung-dlp-hl-p5063w-with-3.html
Nov 19, 2013 | Televison & Video
Samsung rear projection tries three time then goes
There are several things in this set that will cause this. I have ran into this problem 40-50 times on that specific unit. Most common problem is the lamp. Next most common problem is the DMD board which is a very expensive repair. Next most common cause is the ballast which powers the lamp. Next is the color wheel but usually that gets noisey before it fails. These DLP televisions aren't easy to diagnose but they're easy to work on. Now here's the thing, all four of these problems can be solved by replacing the light engine. If you are willing to put some money into it, the engine assembly is real easy to change. Just google the exact and complete model number and search prices of the light engine. I'm pretty sure the part number is BP96-00305J. Sometimes you can actually ship the engine from your tv in to be rebuilt. This can save you money. Any repair on this tv will probably cost 200-500 but they get a great picture. I have a samsung DLP in my livingroom. Good luck, Russmann.
Apr 28, 2010 | Samsung HLM507W 50" Rear Projection HDTV
The tv went black no sound or picture. We
U have a solid green light from the LED power light indicator right?U have this DLP tv for awhile like two or three years,and use it alots right?Never change the lamp and the ballast right?Change the lamp and the ballast should solved ur problems.
Apr 01, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
I have a Samsung HLT5075s. Last Sunday the Tv
Not the light engine. But it could be the power supply. I've seen a few than pass "dirt" power to the ballast and damage it. Have a peek at the ballast, there's a big 47uf, 450v capacitor on it. If it is swollen, it's a dead give away. You need both. I hope this was helpful.
Mar 30, 2010 | Samsung HLT-5075S Television
Numerous white spots on Smasung DLP TV
See link below for "field of stars" fix:
http://www.avsforum.com/avs-vb/showthread.php?t=1107926
Worked a charm on my 50" Samsung DLP. Read thread carefully as there are 2 different version of the DMD chip you will need to replace. I ended up fixing mine for less than $165!
Chuck
Feb 07, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Cuts off
Hi, tough question, could be lamp, lamp circuit is overheating,t-con module or you have a bad color wheel, the latter usually causes a hi pitched squeal periodically, you have 2 choices, 1. try replacing the lamp 2. call a tech and let them diagnose it, too many possibilities without doing some diagnostics, video-tek
Feb 03, 2009 | Samsung HL-67A510 67" DLP HDTV
No picture whirring noise shuts off and on
DLP(digital light processor) does not have a color wheel
Oct 05, 2007 | Samsung HLR5067WX 50" Rear Projection HDTV
Samsung HLT-5075S Television Logo
742 people viewed this question
Jerry Greenberg
Jerry Greenberg
