Question about Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
Steam won't come out. - Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
  • Euro-Pro Master
  • 43,501 Answers
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
bv
Posted on Sep 25, 2010
Steam mop won,t steam. Have tried all suggestions in user guide. Water won,t heat up. Machine becomes warm. Water ' vinegar will slowly drip out of base - so not blocked. Help,,
It could still be blocked, not totally blocked but enough to keep the steam from coming out as strong as it should.
Mar 14, 2017 | Vacuums
Light won't turn on Shark steam mop
I posted this video explaining how to clean the heater core of the S3501...it is likely a similar design as the Euro Pro.
http://youtu.be/S4NglGXVv50
Dec 09, 2012 | Euro-Pro Shark Steam Mop - Gray/ Purple...
The vaccaume motor won't work on my brand new steam vac by Shark
If this is new and returnable then I recommend an exchange. If not possible check to see if the vacuum has an internal fuse on this model. If not, use a voltage tester and test power to and from power switch and to the motor itself.
Jun 03, 2012 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My h2o mop won't steam. How do i fix it?
If your H2O mop will not steam:
1. Ensure you have followed the operating instructions.
2. Ensure you have followed the troubleshooting instructions.
If the unit fails to produce steam:
3. Switch off the power at the outlet.
4. Look at the water reservoir. Inside you will see a flexible tube with a cone on the end. Tilt the unit or give it a gentle shake to submerge the cone in water.
5. With the cone submerged, switch on the power supply and follow the normal instructions. The unit should produce steam as normal.
Note: Unless the cone is submerged in water, the unit will not steam.
Apr 21, 2012 | H2o TR220002 Steam Cleaner
I have a turbosteamer 220 hand steamer. It heats up but won't spray steam
It's most likely the trigger not engaging the piston that releases the steam. Due to the fact that the plastic inside the 220 holding the trigger in place has cracked on both sides.It will need to be taken apart.That's another issue.Be easy on the trigger press down gentle.....
Jul 27, 2011 | Vacuums
Polti steam cleaner
It should go just below the red providing steam isn,t escaping from the cap otherwise you won,t get the pressure build up to enable it to come out when you pull the trigger
Oct 23, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
Heats, but no steam.
The people who manufacture this unit and box it are idots. The manufacturer should that steam can be dangous, and , a user manual should be shipped inside the box. Hey SCUNCI STEAMER dum dums,. Put a printable manual on the site so your customers won,t get hurt by not knowing robert ferriss
Aug 29, 2008 | Scunci 52001 Handheld Steam Vacuum
Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum Logo
544 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
