Question about Navman Trackfish 6600 GPS Receiver
Only a 1/4 of the display shows up at the bottom of the screen and everything else seems to be working ok ? Can I download my coordinates from my Navman to my desk top so I dont loose them?
  • 2 more comments
  • googley1 Sep 12, 2010
    Thanks for reply. Just need to try and find that cable now. Did you have any ideas about the blacking out of 3/4 of the screen ?
    How do I reset it?
  • googley1 Sep 13, 2010
    Thanks for assistance but the type I have is operated from a panel mounted on the side of the unit to select whatever functions are needed etc. The unit has been well protected and worked fine the last time I used it but for some unknown reason the problem above occured. Cheers.
  • googley1 Sep 14, 2010
    Yes thanks for assistance
  • 10,515 Answers
Usually blackening of a part of screen is most probably due to faulty LCD screen.
he Display of a GPS Consists of (2) Separate Devices that Work Together.
# The Liquid Crystal Display (LCD)
# The Touchscreen with Glass
The touchscreen consists of several transparent layers with spacers that are applied with an adhesive to a thin pane of glass. The touchscreen & glass lies on top of the LCD display. The touchscreen & LCD display both have their own flex cables that connect to the main board.
The touch screen has a ribbon flex cable with 4 or more conductors, each conductor representing a direction such as:
1. X-Coordinate, Left
2. X-Coordinate, Right
3. Y-Coordinate, Up
4. Y-Coordinate, Down
Most GPS units use a resistive, analog touchscreen. A voltage is applied to the touchscreen and by pressing anywhere on the touchscreen, it acts like a voltage divider, returning a specific voltage value, based upon the location touched on the screen. The GPS is programmed to read this voltage and it translates it back to a specific position on the screen, which may or may not activate a function.
The touchscreen doesn't have to sit directly on top of the display. If you were able to set it beside the display, you could still press the touchscreen and activate a function. The LCD display has no idea where the touchscreen is mounted, all it is concerned about, is what area is being pressed and whether or not that location matches a particular function on the LCD display menu.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 12, 2010
  • taran_2005
    taran_2005 Sep 13, 2010
    Thanks for your response!!
    If the functions is operated by the side panels, this is more suggestive of a screen failure. If firmware would have been at fault, you could never even see 1/4 of the screen. It would be either completely white or black or a message like xxxx.exe or something of that sort.
    In this regard, you need to send the unit for repair.
    Hope i helped you.
    PS - Do accept the solution,if 100% satisfied from my response.
    Genius:
  • 1,478 Answers
Yes, it is possible to download the coordinates from navman to your desktop. connect your GPS to your system via the USB cable that came with the GPS and wait for your system to detect it, once it detects it, open the files and download the information to the desktop.
Take care.
  • Jimoh Adeleke Muyideen Sep 12, 2010
    I will suggest you reset the device, once the device is reset, it should fix that problem, but ensure you download the coordinates to your desktop irst before resetting it.
Can gps coordinates be used with TomTom go live 750
If you mean, can you enter latitude and longitude coordinates on your GO 750 LIVE GPS device .... yes.
First you'll want to set your unit to accept coordinates. From the main menu, tap Change Preference, then select "Set Units" and select a Latitude and Longitude format in the "Coordinate display" screen, and then tap Done.
To navigate to a location using latitude and longitude coordinates, follow the steps below:
  1. From the Main menu, tap Navigate to...
  2. Tap Latitude Longitude.
  3. Enter the coordinates and tap OK.
May 09, 2013 | Tomtom GO 750 LIVE GPS Receiver
Can I set the TomTom to "go to" a longitude/latitude location?
Yes.
Feb 08, 2012 | Tomtom GO GPS
I know the GPS coordinates of a place, I want to be. How do I enter those to start finding a route from where I am?
I am assuming this is a Quest or Quest2 GPS.
Using the map screen use the larger 4way "navigation" button on the front panel and cursor the screen pointer to the location you would like to save. You may need to zoom in on the location. At the bottom of the screen you will see the "lat/long" displayed. The further you "zoom in" the more precise you can get with the "lat/long". Once you have the pointer at your desired coordinates, hit the "OK" button. This will bring up an address or some other feature name. If there are multiple choices, simply pick the one that is most appropriate and again his "OK". At the bottom of the screen you will see 3 "buttons" (save, find near, and route to). Select "save". Now you will see a screen with several windows that contain the lat/long data, perhaps an address, a map icon, and the name you selected in the earlier screen. You can again use the large 4 way "navigation" button on the front panel to switch between the displayed fields. This will allow you to select a map icon such as a house, store, marina, or whatever. You can then use the "nav" button to select the lat/long window and make any final adjustments to the lat/long data. You can also move the cursor up to the waypoint name box and change it to whatever you prefer. Once you have all of the data fields to your preference on this page, you can use the "nav" button to cursor down to "OK" at eh bottom of the screen and then hit the "OK" button on the front panel. The waypoint should be stored with the correct data in the GPS.
Feb 10, 2010 | Garmin Quest 2 GPS Receiver
How do I use coordinates? I entered map coordinates and it took us to the wrong place.
Some Tomtoms can use latitude and longitude coordinates. They refer, of course, to points on the map.
To use coordinates on some tomtoms you tap the Browse Map option. A general Map of the route is displayed. The screen has three buttons at the bottom
  1. Options
  2. Find
  3. an icon for the point on the map.
  4. Done
Tap the Options button: The Map detail Preferences appears, offering the choice to put a check mark in POI, Favorites, images. At the bottom of screen you have 3 buttons : POI, Advanced, Done.
Tap Advanced: In thsi screen you can put a checl mar on Names, Markers, and Coordinates.
Put a Check mark on Coordinates and press Done, Then Done again until you exit all those options.
Now your tomtom is configured to display coordinates. Be aware that GPS technology was created for military purposes and its civilian uses cannot be expected to offer pin point accuracy. It took an act of the US president to allow its use for civilian localization.
When you plan a route you can use longitude and latitude. Here is the icon you should like for.
Dec 30, 2009 | Tomtom ONE XL GPS
Can you show how to convert pola to rectangular o
To avoid errors make sure that the angle unit is THE ONE required by your problem. To verify or to change the angle unit press [SIFT][MODE] and select [3: Deg] for degrees, [4:Rad] for radians, or [5:Grad] for grads.
Convert from rectangular to polar
[SHIFT][+] (Pol) . Screen displays Pol(
You enter the X-coordinate, and the Y coordinate separated by a comma, then you close the parenthesis and press [=].
Exemple: Polar coordinate of the point (1,1)
Pol( 1, 1) gives
r=1.414213562 (square root of 2)
θ=45
Here is how you enter it
Press [SHIFT][MODE][2:LineIO]
[SHIFT][POL] 1 [SHIF] [,] 1 [)] [=]
The screen displays
Pol(1,1)
r= 1.414213562
θ= 45
Convert from polar to rectangular coordinates
Rec ( radius, angle) =
Exemple: Recatngular coordinates of (r=3, θ=60°)
[SHIFT][Rec] 3 [SHIFT][,] 60 [ ) ] [=]
The screen displays
Rec(3,60)
X= 1.5
Y= 2.598076211
Hope it helps.
Nov 14, 2009 | Casio FX-115ES Scientific Calculator
HP R707 wont take pictures - get F2.8 1/60 message
Does it work while connected to charger? If yes, you need a new battery.
Feb 04, 2009 | HP Photosmart R707 Digital Camera
Rerecord the outgoing announcement
Hi, Press feature 9 8 3, display shows: Log: QUIT RETRY OK, enter system coordinator mailbox and password ( default is 102 0000 ), press OK, display shows: Admin MBOX AA OTHR, Press AA, display shows: Auto Atdt Admin GRTG TABLE LINES, Press GRTG, display shows: Greeting Admin GRTG AA, press GRTG, DISPLAY SHOWS: Greeting: RETRY OK, enter greeting number ( 1 to 20, usually 1 is the Main Greeting ), press OK, display shows: Greeting < X >, RETRY PLAY REC, press REC, at the sound of the tone record your greeting, press OK to end recording, display shows: Accept greeting? RETRY PLAY OK, press OK when you are satisfied. Good Luck
Aug 16, 2008 | NorStar M7324 Telephone
Getting to see the UTM coordinates of where I am on the gps screen
The solution is in the manual but however it is not given the prominence it deserves. It is talked about in passing and yet it is the most important thing GPS users need. One goes to the Pointer and uses the scroll up and down keys to get the coordinates aprt from other things like bearing, elevation, sunrise or sunset time, trip odmeter etc .
The manual should clearly show this prominently. I gave this GPS to 4 people and the manual and all failed to figure this out. This shows the instruction is not user friendly. The Old Garmin GPS would lead you straight into coordinates and the accuracy reading on the same screen display and this was simple.
thanks
Jun 23, 2008 | Garmin eTrex GPS Receiver
Monitor/screen
You need to install the correct video driver let me give you the download site along with other downloads to make sure you have everything.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&dlc=en&product=214330&lang=en
you need to install the first one on that list
Feb 13, 2008 | HP Pavilion ze5185 Notebook
Navman Trackfish 6600 GPS Receiver Logo
93 people viewed this question
Top Navman GPS Experts
Martin Murray
Are you a Navman GPS Expert? Answer questions, earn points and help others
