Question about Matrix TX-1099 TV
How to unlock the television set? - Matrix TX-1099 TV
Tip
Mitsubishi lock code
Mitsubishi Television asking for an unlock code.
Well you locked the set and forgot the code, or someone has locked the code before you got the set. One other scenario is that the code was entered by someone accidentally. Please note: If your parents have locked the television you should not be unlocking something that your parents have blocked. So don’t use these instructions to unlock a television that your parents have locked.
You must have the original Mitsubishi remote control to perform this operation on the set. Look on the remote for a button that is labeled QV (Quick View), if you have this button on the remote then we can press on. Go to the selected channel or input that is asking for the unlock code. When it asks for the code, press the QV button: Holding it down press the number 9 and release. This will unlock the set for this instance. To remove the code I suggest that you go through the setup menu and find the code lock and when it asks for the code use the QV+9 trick again to turn it off from the main menu.
If you do not have the original Mitsubishi remote you will not be able to try this trick. You will have to order a replacement remote from 1-800-REMOTES or www.remotes.com.
Once you have the replacement remote you can unlock the television and be back on your way.
I hope that this helps you with your television lock issues and as always, Thank you for using FixYa.
asnowman
on Mar 22, 2010 | Televison & Video
What is the code to unlock channels for JVC TV
JVC Standard Televisions 'Set Lock Code' are factory set to '0000'
Nov 17, 2009 | JVC Televison & Video
Channel lock
http://books.jvcservice.com/Download/558004078/52022IEN.pdf Use this web link to the JVC customer support website . On the website you will find a pdf copy of the owners manual for your model television set. It will explain how to reset the password and unlock your television. You will find the information you are looking for on page 14 and 15 of the owners manual. I hope this information helps you solve you problem with unlocking your television. Thank you for using FixYa and have a nice day!
Jun 12, 2009 | JVC AV-32D305 32" TV
Lock
You will have to have access code or password to change settings. Or contact set manufacturer technical service for override procedure
Apr 26, 2008 | Panasonic PT-40LC12 40" Rear Projection...
HELP ME PLEASE.............
On your television, it has an initialization code. To get to this menu, press menu 2470. The menu will say "Initialize." Highlight this and press Enter. This will reset the TV back to factory settings. WARNING: This will also delete any user settings, e.g. color, channel settings, input labels, or other. After you press "Initialize" the TV will shut off and restart automatically. You should be unlocked at this point. Hope this helped.
Mar 31, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Unlocking
I would hire the safe cracker from the Italian Job. He can unlock anything!
Feb 12, 2008 | Televison & Video
How to unlock my rca tv
unlock?....does the set have no sound and piture? does the green light flash. i dont think this set locks like that you can lock out channels.
Dec 08, 2007 | RCA HD56W66 56" HDTV
Hisense TL2020 TV repairing
To unlock your Tl2020 with a universal remote just go into the menu and select V chip setting. The password from the factory is four zeros (0 0 0 0 ). Once you get in you will the letter "B" nect to everything. Set everything to the letter "U". Then, turn off the television. The set should be unlocked now. Good luck !
Frank
Sep 15, 2007 | Hisense TL1700 17 in. LCD Television
Television "locked"
Yes only the original remote will unlock it. 10 out of 10. I have unlock it also with Ellis universal but buttons is not the same.
Sep 14, 2007 | Televison & Video
Matrix TX-1099 TV Logo
170 people viewed this question
Top Matrix Televison & Video Experts
Electro Med Services...
Are you a Matrix Televison and Video Expert? Answer questions, earn points and help others
