Question about Fisher and Paykel AeroTech - OS302M Electric Single Oven
Fisher & Paykel oven model# BI601E will not heat (turns on & fan works) after smart meter installed
5 Suggested Answers
  • 412 Answers
SOURCE: Fisher Paykel electric oven doesn't heat in Bake mode
Check the Heating Element of your Oven.......
Posted on Mar 20, 2009
  • 1170 Answers
Electric Oven: Repairs and Maintenance Electricranges and ovens are generally easy to repair, because there's not muchto go wrong and there's not much you can do. Most repairs are actuallyreplacements, a matter of unplugging the old part and plugging in thenew. Most of the malfunctions that affect electric ranges involvefaulty heating elements.
Caution: Beforedoing any work on an electric range or oven, make sure it's unplugged,or turn off the power to the unit by removing one or more fuses ortripping one or more breakers at the main entrance panel or at aseparate panel. If the range is fused at a separate panel, this panelmay be located adjacent to the main panel or in a basement, crawlspace, or other location. If there is a grounding wire to the range,disconnect it. Make sure the power to the unit is off.
Servicing Fuses
Ifthe range or oven is receiving power but doesn't work, the unit mayhave its own fuse or circuit breaker assembly. This assembly is usuallylocated under the cooktop of the range. In some units, lift the top ofthe range to gain access to the fuse assembly; or lift the elements,remove the drip pans, and look on the sides of the cabinets. Inside theoven, look to the back to spot the fuse assembly.
Ifthe unit has this additional fuse or breaker system, components such asthe oven light, the range heating elements, the timer, and aself-cleaning feature may be separately fused.
If thesecomponents or features fail to work, don't overlook the possibilitythat the fuses have blown. To replace a blown fuse, unscrew the oldfuse and install a new one of the same type and electrical rating. Ifthe unit has circuit breakers, push the breaker or reset button, whichis usually located on the control panel.
Replacing Range Heating Elements
Whena range heating element burns out, it's easy to replace. But before youdisassemble the range to check or replace an element, make sure therange is receiving power. Here's what you can do:
Step 1:Check the power cord, the plug, and the outlet. Then look for blownfuses or tripped circuit breakers at the main entrance panel or at aseparate panel.
Step 2:Check the fusing system inside the range. If the circuit is broken,restore it. If the range is receiving power, go on to check the element.
Step 3:When the element is cool, remove it. In most ranges, each top heatingelement is connected to a terminal block in the side of the elementwell. To remove the terminal block, lift the element and remove themetal drip pan that rests below it. The element is held by tworetaining screws or is push-fit into the terminal block. To remove ascrew-type element, remove the screws holding the wires. To remove apush-type element, pull the element straight out of its connection.
©2006 Publications International, Ltd.
To remove a range heating element, remove the screws holding the terminal
wires, or pull the element straight out of its connection.Step 4:Test the element with a volt-ohm-milliammeter (VOM) set to the RX1scale. Disconnect one of the electrical leads to the element and clipone probe of the VOM to each element terminal. If the element isfunctioning properly, the meter will read between 40 and 125 ohms; ifthe meter reads extremely high, the element is faulty and should bereplaced.
To test a range element without using a VOM, remove aworking element from its terminal block and connect it to themalfunctioning element terminal. Don't let the test element overlap theedges of the element well; keep the element inside the well, even if itdoesn't fit perfectly. Turn on the power to the range. If the workingelement heats, the suspected element is bad and should be replaced. Ifthe working element doesn't heat, the terminal block wiring or theswitch that controls the element may be faulty. Call a professionalservice person.
Step 5:Replace a burned-out range element with a new one made specifically forthe range. Take the old element to the appliance-parts store; ifpossible, take the make and model information, too. This data willprobably be on a metal tag attached to the back service panel of therange. To install the new element, connect it the same way the old onewas connected.
Replacing Oven and Broiler Heating Elements
Electric oven and broiler elements are often even easier to test and replace than range elements. Here's how:
Step 1:If the oven element doesn't work, first check to see if the range isreceiving power. Don't overlook the fusing system inside the range.
Step 2: If the range is receiving power, set the timer on the range to the MANUAL position.
Step 3: If the element still doesn't heat, turn off the power to the range and test it with a VOM set to the RX1 scale.
Step 4:Remove the screws or plugs that connect the element to the power.Remove the retaining shield, which is usually held by two screws, andremove the element from the brackets that hold it in the oven. Theelement is usually held in these brackets by screws.
To remove an oven or broiler heating element, remove the screws or pull
the plugs that connect it. Remove a retaining shield and lift out the element.
Step 5:Clip the probes of the VOM to each element terminal. If the element isin working order, the meter will read from 15 to 30 ohms. If the meterreads higher than 30 ohms, the element is faulty and should bereplaced. If the element tests all right but doesn't work, the problemmay be at the terminals. Make sure the terminals are clean and tight atthe element connections.
Oven and broiler elements cannot betested without a VOM. If you don't have a VOM, take the element to aprofessional service person for testing. The problem is usually amalfunctioning element; however, you aren't risking much by replacingthe element without a professional test.
Step 6:Take the burned out element with you to the appliance-parts store tomake sure you get the right replacement part; if possible, take themake and model information, too.
To install the new element,place it in the same position as the old one. Connect it the same waythe old one was connected, using the same screws to hold it in place.Just about all the other components of an electric range or oven(including its door gasket, oven controls, and timer) are virtually thesame as the components used on gas ranges.
Most problems withgas and electric ovens or ranges are easier to fix than you think. Thekey is knowing how the various parts work and when to replace them.
Have a look at these websites to find parts and details :
http://www.appliancepartspros.com/appliance_range_oven.aspx
http://www.gallawa.com/microtech/dataselect.html
Posted on Mar 21, 2009
tbirdfan1
  • 3051 Answers
SOURCE: F3 fault code on fisher & paykel wall oven.
hELLO THERE:
on these ovens the f-3 can sometime be incorporated with the f-4 error code also so here is the code and the things to look for both ok ?
F3 - F4 Open oven temperature sensor (circuit) (over 2700 ohms) or, shorted oven temperature sensor. Could be a result of:
· contamination on terminals
· pinched wire in oven temperature sensor circuit
· cold solder joint on control. · Disconnect power to range and remove oven temperature sensor connector from control.
· Measure oven temperature sensor resistance at oven temperature sensor connector (take care not to damage terminals in block) - Should read 1100 ohms at room temperature (approx 72 degrees F).
· Measure each oven temperature sensor lead from connector block to ground. If shorted, look for pinched or cut wire in oven temperature sensor circuit.
· Check connector terminals - Look for deformed or corrosion on terminals. Repair or replace.
If all above is ok replace control.
Posted on Jul 14, 2010
SOURCE: Fisher Paykel oven model OS302M error
Check your lock on the oven for the door. It may be sticking out a bit:)
Posted on Jan 06, 2011
Fisher and Paykel oven hot heating on fan force
Possibly a burnt out fan element. You or a service person needs to test the element & wiring with a multimeter.
May 10, 2016 | Fisher and Paykel Ovens
Fisher & paykel b1602cte oven fan in element at back of oven not working
FIRST YOU NEED TO KNOW JUST HOW THE FAN WORKS, DOES IT WORK OFF OF ELECTRICITY OR IS THERE A COMPUTER CHIP IT WORKS OFF OF. DOSE IT WORK OFF OF JUST A SWITCH. LOOK UP ON LINE TO FIND A MANUAL FOR A FISSER & PAYKEL B1602CTE IT MAY TELL YOU WHY IT IS NOT WORKING.
Jan 29, 2015 | Fisher Ovens
How do I replace the fan in a Fisher & Paykel 60cm oven
ill assume your referring to the cooking fan you see inside the oven and not the outer cooling fan, you will need to turn the breaker off outside to cut power to the oven then you will have to take the oven out of the wall and remove the back cover then its normally just 3 screws and the nut on the inside of the oven that holds the fan blade on (which is reverse threaded by the way) and it should come out
Sep 27, 2014 | Fisher and Paykel Ovens
Fisher and Paykel Paprika Oven Top Elements Full hot!!
No controller. The switch for each element (called a simmerstat) is what controls the heat. It is a common fault and will be fixed if you instal new simmerstat for each faulty element.
Mar 17, 2012 | Fisher and Paykel Ovens
I have a fisher & paykel Astro built in wall oven which has a problem, after using the oven and then turning both switches off for some reason the rear element continues to stay on and will not switch...
Hi - theres a few components that may well cause this to happen - the power module which controls the heating & fans etc - isolating relay which switches the heater & fan relays - it only avctivates when a cook mode/cycle is selected.
One of the two components could be faulty - I guess a sparkie or techie may be your best option..
Aug 07, 2011 | Fisher and Paykel AeroTech OS302 Electric...
I have a fisher & paykel paprika and i cant get
Hi - Are you able to provide model number of the oven - or describe the front controls as they have about 6 different types of controls regardless of the brand name 'paprika'
cheers
Jul 01, 2011 | Fisher and Paykel Ovens
Bottom oven not heating. Both light and fan are working.
If fan is working o/k then it is usually the oven element that is faulty, this should be located at the rear of the oven compartment behind a removeable cover.
Dec 11, 2010 | Fisher and Paykel AeroTech Double OD302...
I have a Fisher & Paykel double wall oven that I purchased in 2005. The top oven which was used most often stopped heating up to temperature in normal time. What used to take 5 minutes to get up to 250...
Google searches report that after running the self cleaning cycle this can happen. I am experiencing this issue with my Fisher&Paykel AeroTech Double OD302 but with the BOTTOM oven. I'm concerned as Thanksgiving is coming up and I need this baby working!
Nov 08, 2010 | Fisher and Paykel AeroTech Double OD302...
I used the Self Cleaning feature on my Fisher & Paykel OS302 wall oven for the first time, and now the oven will not heat. The lights and fan run, but no heat.
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Aug 23, 2010 | Fisher and Paykel AeroTech OS302 Electric...
Fisher and Paykel AeroTech - OS302M Electric Single Oven Logo
110 people viewed this question
Top Fisher and Paykel Ovens Experts
Dan Webster
Dan Webster
Flipper
Level 1 Expert
 Fix Your Board
Fix Your Board
Are you a Fisher and Paykel Oven Expert? Answer questions, earn points and help others
