What's the correct details for using LAN settings?
  • 32,281 Answers
To secure your wireless network from unauthorized access. please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Posted on Sep 12, 2010
Windows 10 upgrade on my Laptop shows limited internet , can't get online, any ideas?
Try installing the correct lan and wifi drivers from the computer manufacturer. If there are none available, win10 is not compatible.
Aug 10, 2015 | Computers & Internet
I am getting a 'Check Network Connection' error message. I have checked all wires and turned the copier on and off again but the message still comes up. Grateful for assistance with this
Check network connection means that the device is not communicating with the local LAN. This could be due to:
  1. Cable connection to LAN interrupted
  2. Wireless connection (if used) not enabled
  3. IP address settings incorrect
  4. WLAN validation password incorrect.
Check to ensure that the network settings are correct in the configuration menu. Ensure that if you are using a wired LAN that the LAN cable is connected between the copier and the LAN outlet.
Mar 13, 2015 | Canon IR 105 Digital Copier RECONDITIONED
ERROR CODE EA21F7
LOTS TO CHECK
Check if the LAN cable has been correctly connected, if the SMTP server is ready for communication, if the network settings
such as sub-net mask setting are correct, or if the E-mail address of the destination is correct.
LAN cable has not been connected, or failed to communicate with
the SMTP server. You tried to transmit the document to an incorrect destination address.
A LAN cable is not connected. Check that the LAN cable is connected correctly. The network of the network multifunction
machine and the PC with the IP address of the destination mismatch.Confirm whether the network settings of the PC and the network settings of the network multi-function machine pose a
network-type problem.The network settings in the PC have
not been set correctly.Check the TCP/IP settings of the PC.
The network board of the PC with the IP address of the destination has failed. Replace the network board or the PC. Power is not being supplied to the HUB. Supply power to the HUB. A cross-type network cable is not being used for Peer-to-Peer connection.
Use a cross-type cable. The network cable is disconnected. Replace the network cable. Network load in the destination PC is
too high. Check whether a mail with large size data is received in the destination PC, or a large file is downloaded from the Web.
There is too much transmission data. If the scan resolution is set high, scan fewer pages. The access is limited by the firewall
(Windows Firewall) of the network connection in the PC.
Consult with the network administrator, and change the firewall (Windows Firewall) settings of the network connection.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Dec 10, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
Wireless conection
To enable or setup the wireless on a modem router you usually have to connect the computer to the router with a lan cable first, go in to the routers settings, most routers use the web browser to access the settings but read the manual for the correct procedure. Then you put in your account details supplied by your internet service provider.
Enable wireless and apply security settings like a wep key, wpa, or wpa2 passkey. Restart the router, remove the lan cable and you're done.
When any wireless device tries to connect it will need the wep key, wpa, or wpa2 passkey to be entered to allow access.
Feb 19, 2012 | Computers & Internet
I cannot connect internet using LAN, The internet provider already come to check the internet settings but the computer responded "unidentified network"..please help me solve my problem...thanks...
try changing the lan cable ..and make sure that your lan settings is not disabled !!
make sure the IP address of the network are correct this occurs only due to this reason!!!
call your regional head and ask for the correct IP address !!!
Jun 14, 2011 | ASUS Computers & Internet
Finding mac address
To check the MAC address of the machine, use the up or down arrow buttons to display Setup on the HOME screen and press the right FUNCTION button,
then go to Device Settings > LAN Settings > Confirm LAN settings > WLAN setting list to see your MAC address details. YOu should see a screen that looks something like this:
WLAN setting list
MAC address
Printer name
Bonjour service name
May 29, 2011 | Canon Pixma MG6120 InkJet Printer
How to connect router to more pc
It depends upon whether you want to attach other computers using a LAN cable or by wireless.
If you want to attach more computers using a LAN cables then all you need is to connect a LAN cable from the router to each computer's LAN port.
If you want to connect by wireless then you need to configure each wireless card in the computers with the router's wireless settings ie. SSID and the encryption key.
For these details and to secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
Dec 08, 2010 | Computers & Internet
Unable to connect to internet via router.Computer says signal strength is excellent.diagnostic check highlighted DNS problem.I think VIRGIN (my isp) have recently changed their DNS nos. Virgin (my isp)...
If you're using an ADSL connection the details you need are below.
Settings for an ADSL connection through a telephone line.
Open a web browser and log onto your router.
Find Internet Wan > Connection Type.
Set the Router to use PPPoA, type in your User Name and Password in the spaces provided. If you do not have a Service Name or do not know it, leave the Service Name field blank. After you have typed in your information, click "Apply Changes". After you apply the changes, the Internet Status indicator will read "Connected" if your Router is set up properly.
WAN > Connection Type PPPoA
User Name > firstname.name@adsl.virgin.net (or virgin.com or whatever)
Password > *******
Retype Password > *******
VPI/VCI > 0 / 38
Encapsulation > VC MUX
MTU > Leave as Default
Find Internet Wan > DNS.
Select Automatic from ISP
(Virginmedia DNS servers are Primary: 194.168.4.100 Secondary: 194.168.8.100)
Find Lan Setup > Lan Settings
Ensure DHCP Server is set to On
If the details entered are correct the router will show connected and the internet lamp will be green.
Do the configuration on a wired connection.
Jun 19, 2010 | NetGear WGR614 54Mbps Wireless Router...
Open Questions:
6 Ways Cloud Computing Helps Businesses Save Time and Money You must be using cloud computing now even if you do not realize it. For doing a simple task like sending an email, uploading a video online, downloading work related files it is nothing but cloud computing that is making it all possible behind the arena. Cloud computing is a big switch from the orthodox way businesses think about IT resources. Many Online Cloud Backup services advertise a lot of features, such as fast upload and download and unlimited backup, but often in real life usage these commitments fall short. As the old saying goes you get what you pay for stands true. For extremely basic file storage or sharing, you may look for a low cost, simpler product. However, if you are looking to get the best for your business, you'll need to consider better solutions like DataAlign. We all have masses of unstructured data scattered across laptops, desktops, and mobile devices and this is an ever-growing pain not only for a business but also for a home user. With time scarcity and insufficient security measures to protect these valuable data assets, we decided to create a competent Online Computer Data Backup Solutions that can not only assist you to organise your data, but secure it with military-grade encryption. Unlike other business online backup services that does not give optimum functionality, DataAlign provide application and operating system backup, 24-hour support, advanced file versioning, compliance-level security, server and NAS backup and infrastructure-as-a-service IaaS features. Of course, these offerings are simple to use and self-explanatory. With our ever growing and latest technology, Data Align Online Business Server Data Backup Solutions makes data backup, disaster recovery and business continuity uncomplicated and less extravagant as the is mirrored at multiple redundant sites on our network. DataAlign has been designed with you in mind. You wouldn't require any technical skill or IT degree to use it. Simply, upload your data and the technology will do the rest, enabling you to focus on what really matters; your business. Our dedicated support is readily available to answer any questions that you may have.
Jul 23, 2018 | Best Computers & Internet
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
