Question about Kodak Easyshare C182 12MP Digital Camera
I want to format my sd memory card to my new kodak easy share c182.
    Problem Solver:
  • 19 Answers
On a PC. Plug in camera and turn on or take card and put in the computer, however you normally do it.
Open: MY COMPUTER or EXPLORER
locate the camera in your list of drives
OS(C:), RECOVERY(D:) and so on...
It will probably say CAMERA(?:)
Drag the mouse pointer over the top of the drive or over the word camera, or if you put the card in a port it will say something like SDCARD or (Brandname)CARD
Once the mouse is over the drive name right click mouse bringing up menu, in the pop up menu list will be: Format... You can choose quick format or slightly longer thorough format.
Vuala! Formatting made easy and quicker than searching the cameras menu's.
If you're on a MAC I can't help ya.
L8ers
Posted on Sep 12, 2010
  • altern8
    altern8 Sep 12, 2010
    I forgot, if your plug the camera in with a wire?
    Then you will have to expand ( ) your camera's folder to expose the inner drives.
    Fixed storage
Kodak easy share c183 memory card protected how to reset
Camera LCD: "Memory card is protected (Reset ... - Kodak
support.en.kodak.com/.../camera-lcd%3A-memory-card-is-protect...
KodakAug 25, 2010 - The camera screen displays "Memory card is protected (Reset switch on card). ... The memory card is locked so that data (pictures, videos, or files) ... The disk is write protected." when writing to or formatting an SD card. Share.
[PDF]KODAK EASYSHARE C183 Digital Camera
resources.kodak.com/support/pdf/en/manuals/.../C183_xUG_GLB_en.pd...
Kodak, EasyShare, Max, Perfect Touch, and Pulse are trademarks of Eastman Kodak. Company. ..... Access to more manual settings than Smart Capture mode. ..... NOTE: To delete protected pictures/videos, remove protection before deleting.
Jan 26, 2016 | Kodak Easyshare C183
Mi camara digital kodak c195 dice internal memory is full
The internal memory is very small and will only take a few pictures. Just enough to test the camera. Your camera also accepts SD and SDHC cards, which are not expensive. You can put lots of pictures on the SD or SDHC cards.
You also could connect the camera to a PC or MAC and send the pictures over after you installed Kodak Picture easy share.
After you backed up the pictures that way, you can delete the pictures in the camera. Always make sure you have at least 2 backups from your pictures.
May 02, 2014 | Kodak Easyshare C182 12MP Digital Camera
Kodak EASYSHARE C182 , memory card not formatting !!
Sometimes these memory cards have a small (switch) tab on the side of them which needs to be in the correct position.
Check it out and slide the tab fully to the other position
Oct 12, 2017 | Kodak Easyshare C182 12MP Digital Camera
Difficulty formatting new memory card for a Kodak Easy Share DX7440
The DX7440 works with MMC and SD cards, which max out at 2GB. While your 4GB SDHC card fits into the slot, it is electronically incompatible and will not work with this camera. You need to stay with SD cards, 2GB and smaller.
Dec 01, 2011 | Kodak EasyShare DX7440 Digital Camera
New memory card 4gb will not format in the kodak easy share c533 camera
The C533 works with MMC and SD cards. Your new 4GB card is actually an SDHC card. While it will fit into the slot, it is electronically incompatible and will not work. You need to use SD cards 2GB and smaller.
Dec 09, 2010 | Kodak EasyShare C533 Digital Camera
Bought a new Lexar 8GB memory card and having trouble formatting it for the Kodak Easy Share V530
The V530 works with SD cards. Your new 8GB card is an SDHC card. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. You need to go with SD cards, 2GB and smaller.
Nov 28, 2010 | Kodak EasyShare V530 Digital Camera
Kodak Easy share C182 Digital Camera
Please check that you have putted kodak alkaline batteries.
Mar 03, 2010 | Kodak Easyshare C182 12MP Digital Camera
Kodac easy share c330 says memory card full, but it is a new card
Which size has the memory card? More than 1GB?
The spec for the SD card format is going to 2GB but the Kodak C330 not compatible with 2 GB SD memory cards.
Click
But try an firmware upgrade. Maybe the supporting now the 2 GB memory cards.
Why download firmware version 1.07?
This firmware version improves memory card compatibility and provides general performance updates.
KODAK EASYSHARE C330 Zoom Digital Camera Firmware
May 03, 2009 | Kodak EasyShare C330 Digital Camera
SD HD card won't format
This camera only works with standard SD cards with a max of 2 GB
Mar 31, 2009 | Kodak EasyShare Z612 Digital Camera
New memory card and the camera says its full
try doing a format with the camera. check your manual to see how to do this with your camera. Beware, formatting will erase anything on the card. i actually had the same problem with my camera, and this worked for me. Sometimes new flash cards are not compatible off the shelf--they need to be formatted. You should have at least flash cards to be sure card is not defective. Let me know if this helps!
Dec 02, 2008 | Kodak EasyShare C330 Digital Camera
Kodak Easyshare C182 12MP Digital Camera Logo
78 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
