Question about Vacuums
I have a ceiling fan with 3 lights. We do not use the remote control and did not install it. The lights stopped going on today. The fan works, but the lights do not. I have tried changing bulbs, but that is not the problem.
  • 377 Answers
Sounds like a loose wire. If you turn the lights on via a wall switch or a pull chain, I would start where you hooked the wire for the lights to the house electricity, most likely where the fan meets the ceiling. Pull the "bell" part of the fan down that covers the ceiling box and see if there is a loose wire inside. There should be a plastic cap called a wire nut that covers the wire connection. Make sure it is secure and if possible, put some electrical tape around it. Please let me know if you have questions.
Posted on Sep 12, 2010
Testimonial: "Your suggestion was a good place to start. I couldn't find any loose wires, however, with the wires under tension the lights started working again."
  • pwillitz Sep 13, 2010
    Under normal wiring conditions your comment "with the wires under tension the lights started working again" is a typical indication of a loose or intermittent connection.
    Loose wires can be obvious from a wire hanging loose in a space to a wire just loose enough under a wire nut that just needs to be tweaked a bit.
    Glad you were able to solve the problem.
  • pwillitz Sep 18, 2010
    I hope you took another look for loose wires.
    According to your feedback that appears to be your problem.
    Better to be safe.
    Paul
The light on a fan is flickering. It doesn't appear to be the light bulbs. This fan has a remote control and it controls the fan OK and turns the light on and off but it flickers. What could be...
Try changing or testing the batteries in the remote or take the remote out of the fans range. See if this stops the flickering. It can also be the individual bulb. Sometimes the monofillament wires become loosened. It won't hurt the fan to use a broken bulb but it will shorten the life of the bulb. They do get the daylights shook out of them! If all the bulbs flicker it can be the twist connects. These are located under the ceiling plate cover. To check, shut off the fan or turn off the braker switch to make sure you don't get a shock (but I really doubt it). Remove the face plate ceiling screws to expose the wiring. There should be a black and a red cap that holds wires together. Black is ground red is power. One at a time hold the wires of the black cap with one hand and give the cap a gentle clockwise twist with your other hand to see if they need tightening. Repeat with the other colored cap. Push the wires back up inside the housing if needed and replace the cover.
These are the simpelist things to try before calling an expert. I hope this helps?
Sep 22, 2011 | Vacuums
My hunter ceiling fan is not working and according to hunter technical support, I need to replace the remote control receiver (part # 8511204000) at a cost of 50.00 plus shipping.is there a way to by-pass...
If the product did not come with a manual control on it then yes you will have to use the remote. However, if the replacement remote will cost nearly as much as the ceiling fan itself you could simply purchase a new fan.
Feb 28, 2011 | Vacuums
I have a model 484 709 UPC 792145330547 The fan/light is close to ceiling (instalation). Their is supposed to be an "o" ring to remove the fan/light from the celling. I cannot find it!!! ...
Remove the cowl at the ceiling by removing the screws in the cowl (very close to the ceiling). Use caution in removing them as the weight of the fan may be carried by these screws. Depending on the style, though, the weight may be borne by supports beneath the cowl. Either way, this will get you access to the wiring, allowing you to change out/remove the fan. If the fan and cowl are together, and close to the ceiling, there is usually a method of hanging the assembly while the wiring connections are made during installation. Look for a hook that the screw hole will go over, supporting the fan.
Best regards,
--W/D--
Jan 19, 2011 | Vacuums
My Hampton Bay ceiling remote model no. UC7030T does not work. How can I get another one. My fan will not work without it.
First, be sure you did not change one of the dip switches in the hand held unit while changing batteries. You would have to see if the switches in the hand held unit match the switch positions in the fan receiver.
This is one of the many sites you can go to for remotes:
http://www.lightinguniverse.com/fan-accessories_84.html
Hampton Bay fans are sold exclusively by Home Depot. I would check on line or stop by one of their stores to see if you can pick up a HB remote. Once you get a new remote you have to again make sure the dip switches are in the same position. Paul
Oct 11, 2010 | Vacuums
The switch on the wall only works to control the fan and not the light- it won't turn off the ligght. I replaced the switch but it did not solve the problem
If this is a new installation and there was only one switch on the wall, say to control a light that was once there, then you have that switch hooked up only to the fan. If you want to control the light as well, it has to be wired up at the box where the fan attaches to the ceiling. HOWEVER, with only one switch, the light and fan will always be ON or OFF at the same time. You would need to wire in another switch to control the fan and lights independently.
Oct 03, 2010 | Vacuums
I have a Hampton Bay Midili fan which I just installed about a month ago and it was working fine. A few days ago when I flipped the switch on the light flickered on and off consistently until I turned the...
in many of these remote controlled lamps you cant use the new spiral light bulbs .. you can only use standard incandescent lights .. if thats not the trouble then you may indeed have a bad controller (in the fan) .. there is probably at least a 90 day warranty maybe as much as 3 years .. make sure the wire nut power connections are secure inside the fan.. if one of the the wires in the fan are not making contact then you will see a similar problem .. once in a while i have seen strong external RF signals interfere with the controller but thats rare and usually doesnt last long ..
i would : 1. check all the connections .. 2. replace the light bulb to make sure its not flakey or the wrong type .. 3. try to get the fan replaced in warranty ..
Jun 06, 2010 | Vacuums
Vacuums Logo
115 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
