Question about Acer Aspire 5500 5570-2609 Laptop
How do I open to replace internal battery? - Acer Aspire 5500 5570-2609 Laptop
  • Acer Master
  • 17,130 Answers
Remove the battery panel , memory card panel and you will be able to locate the internal cell to replace.
Normally for all laptops it is seen and can be replaced without the whole set being replaced.
Posted on Sep 12, 2010
    Guru:
  • 1,082 Answers
These batteries will last for years if not longer. I would not believe that it is bad. Now, if you want to reset a BIOS password check my tip.
http://www.fixya.com/support/r5953318-reset_bios_password
How do you open the Sylvania model no 72032 rechargeable flashlight to replace the battery and light bube?? Thanks
This is from the Sylvania site
  • Dimensions: 2.4" long x 1.7" diameter
  • Light Source: 0.4 watt non-replaceable LED
  • Internal Battery: Sealed Ni-MH 3.6V 110mAH rechargeable battery
This look like it is not replaceable - amazon sells them fairly cheaply
Oct 04, 2014 | Camping, Backpacking & Hiking
My TI-34 MultiView does not turn on or off. Is there an internal battery? tonyramonas@ci.bristol.ct.us
Yes, it has an internal button cell battery, type CR2032. You can replace it by removing the calculator's protective cover, and loosening the screws in the back plate. Carefully open the case and do not touch other internal parts. You may use a small screwdriver to aid in removing the old battery.
Insert the new battery in proper polarity and it should snap in place.
Jan 11, 2011 | Texas Instruments Office Equipment &...
My still digital camera is Sony DSC W210. I am remove the external battery 3-4 days and open again aftre 3-4 days, display lost the set date and time. this problem is Internal battery or external battery.
that is the internal battery you cant replaced whit out opening the camera cassing and its very touchy you will need a tech to do so
hope that will help you
regarsd Allan
Sep 03, 2010 | Cameras
The internal battery is dead. How do I replace the the old battery with a new one. Please explain how to open the battery compartment and how to install a new lithium-ion battery.
The internal battery, that only Garmin can change. It would cost $125 just to send the unit in if it needed work outside of the warranty period.....hopefully the battery will last about five years.If you get it replaced from Garmin. If still you want to void the warranty and get it opened then there is step by step images shown how to open the unit.But that actually damages the unit. Click this link directly:--- There are total 26 images showing step by step procedure.Click on each image and continue disassembly. http://content.techrepublic.com.com/2346-22_11-178052-6.html?tag=content;leftCol ---------------- Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 10, 2010 | Garmin StreetPilot C330 GPS Receiver
I have a philishave hq 6849 which is about 5 years old. I charged it yesterday and today it is "dead" when I plug it in the mains the greenlight comes on but nothing else happens. Is there an internal...
Yes, there is an internal battery and it can be replaced. You will find the battery you need at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-battery-pack-for-most-shavers-p-211.html
You will need one or two batteries depending on the internal configuration of your model.
To open the shaver, you will need to remove the two screws on the back of the shaver. Once the back cover is removed, you will be able to access the battery pack and circuit board. You will need to unsolder the old battery pack from the circuit board and solder in the new one
Feb 03, 2010 | Philips Philishave HQ6849 Electric Shaver
Internal battery dead,how to replace
The GPS 12 has an internal battery soldered to the board inside the unit.
I have replaced about a dozen of these over the years,
The problem is caused when the unit is stored for a long time without batteries.
The internal battery is not a rechargable.
You have to use a screwdriver in the crack that joins the 2 parts of the case and break the seal to split the case open.
This will of corse render the waterproofness of the unit void.
You then have to unsolder the internal battery from the board and find a replacement.
It is a tagged lithum battery, I can't remember the model at the moment.
Inside you will also notice the surface mount Intel 386 Chip. which is the main processer.
This has nothing to do with the battery but I found it interesting that a chip in a computer from the mid 80s worth over $3000 then, still has a use.
When you have soldered the new battery into place you need to either glue or tape the unit back together. Be careful not to damage the other parts around the battery.
Always keep charged batteries in the unit when not in use.
Hope this helps.
Alan
Apr 12, 2009 | Garmin GPS 12 GPS Receiver
If you put in fully charged battery and after taking one picture it reads battery low whats the problem
two problems either of that will be causing this. 1)either the battery is drained internally its showing up charged on the device but actually not getting charged so its happening. to resolve this replace the battery. 2)either the connector which is touching the battery internally is got loose internally so its showing up this problem. to resolve that connector problem the device must be opened and that connector should be resoldered.its a metal connector.
Feb 20, 2009 | Kodak EasyShare C310 Digital Camera
Canon sd750 does not hold date/time setting
yes there is a internal battery the camera has to be opened up to replace it. we replace the battery on this model for 45.00
Jan 26, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
How to replace internal battery
This website sells a replacement battery and I am going to do it myself. I openned up the unit and it looks pretty easy as long as you are somewhat mechanically inclined and have a sodering tool. i'll let you know if it works out when I do it.
Jul 07, 2008 | Garmin StreetPilot c340 GPS Receiver
Acer Aspire 5500 5570-2609 Laptop Logo
47 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
