Question about liftmaster Chamberlain Garage Door Opener Transmitter 300MC
We have a Liftmaster Professional Formula One garage door opener. The garage door will only open a few inches and stops. If we disconnect from the piece that runs on the track, that piece will move all the way along track in both directions...but not when connected to the door. We ran that piece all the way into open position and opened the door manually, replacing it on the piece on track...door then closes correctly but will only open those few inches again. Can you help??
    Problem Solver:
  • 23 Answers
Did you check the spring tention or it could be a problem with the track
Posted on Sep 13, 2010
Why does garage door opener only move a few inches?
Check the spring above the door, mine would go up a couple of inches and we found that the spring had broke.
May 16, 2014 | Sears Craftsman LiftMaster Chamberlain...
Garage door will not close from remote or car. Garage door will open from remote or car; however, it will not close using these controls. The only way I can close the garage door is to press on the manual...
Try reprograming the opener to each remote, if this doesn't work then the command/radio module in the opener is damaged and needs to be replaced. Hopefully you can find one or you will have to replace the whole garage door opener. Good luck.
Jan 21, 2012 | liftmaster Chamberlain Garage Door Opener...
Liftmaster Professional Formula I, will not close.. Goes down and hits floor and open up again. Thank you
On the operator is a screw adjuster for how far down the door goes. Find this adjustment and rotate it in the direction of less travel. Then you may have to spend a few minutes setting it so the door closes snugly.
Gary
Aug 31, 2011 | liftmaster Chamberlain Garage Door Opener...
My Chamberlain Liftmaster Formula 1 garage door opener just started going up 2 inches then stopping. If I hit either the inside wall mount or the remote in the car it just goes back down 2 inches and back...
You need to check the door springs to see if one is broken and also remove the cover from the motor unit and check the drive gear. The gear is white nylon and will be very obvious if it is bad. The part number is 41A2817 and is available at any good door service company. It will come with instructions.
Apr 03, 2011 | Sears Craftsman LiftMaster Chamberlain...
Where can I get a copy of the owners manual for Liftmaster Professional Formula I garage door opener?
Go to this website and put in your model number.
http://www.liftmaster.com/consumerweb/service/manuals
Oct 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster Professional Line 1.5 hp won't open the garage door
Sounds like a bad spring or the drive gear is going bad. Take a good look at the springs above the door. It is sometimes hard to tell when one is broken. Remove the cover and look at the gear. It is obvious when this is going bad.
Aug 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opens about 8 inches and then revereses
Formula what? they have over forty different types. though sounds something like either limit switches may be faulty. Is this door new? Are there any odd noises from the motor?
Mar 21, 2009 | liftmaster Chamberlain Garage Door Opener...
My garage door opener doesnt close all the way.
The motor is probably either stalling because the door is too stiff, or you have a beam break detector that is being triggered when the door is halfway down.
Nov 23, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Chamberlain Liftmaster Professional 1/2 HP
Okay...upon further inspection, my left spring has broken in two. Going to call around for some quotes to replace the spring. Thanks for the suggestions.
Jul 21, 2008 | Sears Craftsman LiftMaster Chamberlain...
liftmaster Chamberlain Garage Door Opener Transmitter 300MC Logo
778 people viewed this question
Top liftmaster Electrical Supplies Experts
Mike
Gil Shultz
ray gallant
Are you a liftmaster Electrical Supply Expert? Answer questions, earn points and help others
