How do i fix my HP power pack the part that has the wire that carries the power to the laptop it is beeping non stop and no longer powering my laptop
I need to know if i can use a external video card on me DELL inspiron 1300
Posted on Sep 12, 2010
Tip
Tipical Computer/Laptop Post & Beep Error Codes
Error Code: Faulty Component:
_____________________________________________________________
1 short beep None (Normal Boot)
2 short beeps ( POST error)
Non-stop beep ( Power supply or system board)
1 long beep and 1 short beep ( System board)
1 long beep and 2 short beeps ( Video card)
1 long beep and 3 short beeps ( Memory)
3 long beeps ( Keyboard)
Non-stop short beeps ( Power supply or system board,a key on the
keyboard might also be stuck)
None ( Power supply,system board,or system
case built-in speaker)
______________________________________________________________
Visual POST Error Codes:
Error # Range: Component with Error:
100-199 System Board
200-299 System Memory (RAM)
300-399 Keyboard
600-699 Floppy Drive or Floppy Controller
700-799 Math Co-processor
900-999 Parallel Port (LPT1)
1000-1099 Parallel Port (LPT2)
1100-1199 Serial Port (COM1)
1200-1299 Serial Port (COM2)
on Oct 01, 2010 | Computers & Internet
Malibu transformer
Unplug transformer, change bulbs with low voltage bulbs from local hardware or home center. There are two screws on back of each bulb.
Copy following link for tips to get power pack to last longer, replacement trippers, warranty, troubleshoot. etc
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Reason for unplugging transformer: because product manual lists that as best way to change bulbs. The low voltage transformer output is 12Volts and does not carry enough power to cause you harm if you touch bare wire.
Add a comment and attach photo as needed.
May 25, 2013 | Malibu ML600TW - Low Voltage Power Pack -...
How to fix a laptop that doesn't turn on but beeps 1 long beep and 3short beeps
This POST cade is related to RAM problem
one beep, three short beeps
three short beeps, one beep
  • Memory problem: bad DIMM or bad DIMM slot
Try reseating the RAM, if this does not work then remove the RAM module and take it to your friendly computer repair shop and get them to test the RAM for you.
May 12, 2012 | HP Pavilion ze2000 Notebook
Have 5 year old ML600TW carrying 320 watts on one side. Stopped working. Noticed it has a circuit breaker internal. Is it possible to open unit and rest circuit breaker. Thanks
I've never heard anyone fixing a power pack transformer once it stopped working.
You could be the first.
Add a comment and say what you discover.
Open following link for troubleshooting resources:
Instruction manuals say to match bulb wattage with power pack wattage.
Aug 18, 2011 | Intermatic & Malibu& 300 Watt Power/Pack...
My hp mini note book wont stop beeping it says reboot how and where can i fix this problem
the only way you can solve this problem is to hard boot the power by pressing and holding it for 8 secs with the battery and cables removed. If you can tear down this laptop and reseat the power supply and the heat sink, the beep will be minimized. Otherwise repair this laptop by contacting HP.
Jun 01, 2011 | HP Mini 1000 Netbook
4 beeps on my Hp pavillion dv6000, blank screen
No Screen on Pavilion DV2000T
I had this problem before. Tere is a good chance this may work.
First of all remove the ram memory.
-remove battery pack and wait 10 mins
-now start charging laptop without battery pack for 2 mins
-unplUg the power AND press and hold the power button for 45 seconds
-REPLUG THE POWER CABLE BUT DONT PUT THE BATTERY PACK YET
NOW OPEN THE LID WIDER YOU CAN PRESS POWER BUTTON YOU WILL SEE YOUR SYSTEM WILL START. ONCE YOUR SYSTEM IS READY SHUT IT DOWN PUT THE RAM AND BATTERY PACK BACK AND CONTINUE TO USE YOUR LAPTOP.
It hope fully will work as if you get one or more beeps, the POST is completing alright.
Hope that helps.
Dec 10, 2010 | HP Pavilion dv2000t 14.1" Notebook Laptop...
When you turn on the computer it makes a series of stringed beeps for a second also when turning it off, keyboard and mouse does not work
what's the beep pateren it does? here is the basic beep codes:.....
2 short beeps POST error
Non-stop beep Power supply or system board
1 long beep and 1 short beep System board
1 long beep and 2 short beeps Video card
1 long beep and 3 short beeps Memory
3 long beeps Keyboard
Non-stop short beeps Power supply or system board
(a key on the keyboard might
also be stuck)
None Power supply, system board,
or system case built-in speaker
Oct 01, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
Computers & Internet Logo
David Payne
David Payne
