Question about Carrier Heating & Cooling
Compressor, wall unit works well. Therm is set to 78 cool temp 90 and ac is not getting cool. Nothing blocking vents
    President:
  • 3,074 Answers
Either the compressor is bad or it is frozen, I would try cleaning the coil and make sure the fan and compressor are working. Hope this helps tim
Posted on Sep 12, 2010
My Duo-Therm AC on my 2001 Sandpiper Lite does not get cold in the afternoon win really starts to get warm. When it's on max the unit will barely cool and the seems to bog down fan slows down
check voltage coming in at that time also check see if air vents on faceplate open will cool that area close to get flow through unit check air temp coming out should be 20 degrees different from ambient room temp if not check fins on unit see if dirty if ok cooling unit going
Jun 20, 2016 | RVs
Ok 2005 chevy malibu. Fan hits on all speed rear defrost works. temp control does nothing no heat no ac. Blower blows from dash vents only no defrost no foot no blend on vents no nothing. Compressor does...
replace the switch its self.. you can search ebay motors under electrical and find one easily.. also they remove easily and just plug in the back..
Apr 05, 2014 | 2005 Chevrolet Malibu
Malibu heating and ac
does the car have automatic climate control?
Duo therm rv air conditioner repair
Sounds like thermostat is failing. There is a factory set resistor that helps the thermostat keep a 2 degree accuracy. Second possibility is that you have a fan or direct airflow from the cooling system, being devirted, that is allowing the cool air hit the thermostat on the wall.
Aug 17, 2013 | Heating & Cooling
Duo Therm RV air conditioner inadequate cooling
The rule of thumb is 20F difference (lower) than ambient temperature. Most manufacturers will tell you 20 F degress is about normal. In your case it does sound a little warm, but I need to ask, sorry. Was it working o.k. before in same basic temperatures? Have you cleaned coils & fins good on Evaporator & condenser recently? Have you removed filter inside & cleaned it as well, and looked to see if coils are frosting up by chance? Is this a ducted or non ducted system? I'm guessing on a 5th wheel, it is ducted, so make sure you have good discharge on all of those as well. Any blockage or restriction on the discharge side will also cause the problem. Keep me posted on what you find.
Aug 31, 2009 | Dometic Rooftop RV Air Conditioner
Ac set at 74 room temp up to 78 and no Ac kicking on.
it could be the thermostat is loose on the subbase or if you went from OFF to COOL and the stat is a digital stat It will not come on for five min. This is a delay set by the manufacture to protect the compressor. during normal operation you will not notice because thier will be more than 5 min from the time it shuts of till it need to come back on but if the system switch is set to off and you switch to cool or unit just shut off it will always delay 5min. usualy there will be some insdiction on the screen that it is in delay like a flashing COOL or SNOW FLAKE or the word WAIT. the unit will not be running until the flashing words go solid
Jun 26, 2009 | Honeywell Programmable Thermostat Heater
Indoor temp doesnt go to my punched in setting of 68 on therm
if it is around 93-97 degrees outside,thats all the cool your going to get
Jun 23, 2009 | Honeywell Programmable Thermostat Heater
Frigidaire window air
Nothing less than low on freon...You've done good!
Sep 08, 2008 | Frigidaire FAC107P1A Wall/Window Air...
Dometic a/c, duotherm thermostat, turns right back on after it reaches desired temperture.
I have a dometic 13500 BTU Roof mount a/c. It is set up with the duo-therm analog thermostat. The system cools fine. The problem is that the a/c gets down to the right temp, then it turns off like it should but turns right back on within a few seconds. Any help would be greatly appreciated.
May 13, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
