Question about Kenmore Elite HE4 Electric Dryer
Can my kenmore elite HE4 electric drier be converted to natural gas?
  • 347 Answers
No unfortunately it can not de converted ,besides after you bought all the parts needed you could have bought a new gas dryer
Posted on Sep 12, 2010
My kenmore elite turbo super capacity drier will not dry.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101][]
Sep 11, 2011 | Kenmore Elite HE4 Electric Dryer
Not heating on kenmore elite he4 model 1108508
heatman101
Aug 30, 2011 | Kenmore Elite HE4 Electric Dryer
My kenmore elite he4 dryer is not heating up to dry the clothes
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 10, 2010 | Kenmore Elite HE4 Electric Dryer
I have a kenmore elite he4 dryer and it is running but isnt getting hot. Need to know where the fuses are located to check them
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Sep 04, 2010 | Kenmore Elite HE4 Electric Dryer
Our Kenmore Elite HE4 gas dryer will not start although all controls on front are lite and appear to be functioning properly (settings can be changed, etc). I has been working fine for several hours until...
check the door switch and door latch. Open door, set the dryer to air fluff cycle, and manually depress the door switch. Press start button. If it started - door needs alignment to fix it.
If it did not start:
If your dryer has light inside - check if light turns off when you press the switch. If not - switch needs replacement.
If all that checks out ok - the problem is more serious, and you might need a tech to come out and diagnose it.
Mar 04, 2010 | Kenmore Elite HE4 Electric Dryer
Cloths not drying all the way
if you have heat and the clothes take to long to dry you need to clean out the dryer the lint duct and blow out the vent line,also go outside and make sure there isn't a cage or something acting like a lint catch stopping air from blowing out where the flapper is
Nov 02, 2009 | Kenmore Elite HE4 Electric Dryer
I have Natural gas and am moving where it will be hooked up to lP instead. What do I need to convert to LP from Natural Gas
you will need an L.P. conversion kit. the kit contains a small spring, a new brass orifice and a new brass cap that fits on the gas valve. some kits are minus the spring. you will most likely have to remove the burner to put the new orifice in. any appliance repair store will be able to order you the kit. have model and serial number handy. good luck with your move into the country.
Oct 20, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 gas dryer, no heat at all
The ignitor may be bad or the thermal fuse may be failed.
Aug 27, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Gas Dryer HE4-Panel Switch is not Working
repl/ touch panel ,were the front push buttons are the whole assembly ,,
Dec 31, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore elite gas dryer smart heat quiet pak 9 HE4
possible front control bd ..be sure there is 220 volts to rear connection first
Aug 03, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
