Question about Refrigerators
My drain tube is clogged and water keeps pooling on the floor of the refrigertor. I need help locating access to the tube, please.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 110 Answers
Switch of fridge for at least 6 hours. Behind the fridge , usually mounted above the comperssor you will find a drain pan, above which you will find a tube which drains water from the freezer. Use a stiff wire ( straightened out clothes hanger) and push through until the blockage is cleared. Alternatively you can access the drain tube from the freezer end after opening the panel that houses the eveporator fan
Posted on Sep 12, 2010
What is plugged to cause water to come from under refrigertor?
The defrost water drain tube may be clogged with "gunk". You can confirm this by inspecting the evaporation pan under the cabinet. If it is dry, the cabinet isn't draining. I have found the evaporation pan (usually flimsy plastic) cracked, allowing water to leak onto the floor.
Apr 27, 2017 | Refrigerators
Do I need to remove the bottom panel beneath the last basket of my freezer in order to see the drain tube for flushing
Hello Shirley, thank you for you post!
I understand that your Frigidaire freezer is leaking water onto the bottom panel of your freezer. This could be a possible clog within your drain line or an issue with your gasket. I would recommend performing a manual defrost on your freezer and you can do that by disconnecting power from your freezer for at least four to five hours. This will help clear out any clogs within your freezer.
You may also want to test your gasket and you can do that by using a dollar bill. Place the bill between your freezer and the freezer door. If you pull the bill and it provides resistance the gasket is good. If the bill slides out you may need to replace the gasket. It that all checks out to be in proper working order I noticed you wanted to access the drain tube. In order to access the tube you would have to remove the rear panel wall. This is not a simple DIY job and I would recommend reaching out to a professional for proper diagnosis and repair. I hope this information is helpful to you. -Matt
Apr 14, 2015 | Frigidaire Freezers
Frigidaire FFHS2311LWD has water pooling up and freezing bottom drawer and lower vent. Drain tube doesn't seem to be clogged. Water leaks onto floor some days.
the drain tube is most likely clogged. if the lower vent is freezing up there is no way to confirm because it is covered with ice. the reason water leaks onto the floor is, the refrigerator goes into defrost, frost melts and runs down the ice to the door. use a hair dryer to remove all ice, then use hot water to check drain. drain tube may be up to a foot long and may have a trap. you may have to go in through the back to gain access to the drain
Oct 22, 2013 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Drain tube blocked in freezer GE profile PDS22MCRBWW
This is a result of the drain being clogged. you'll have to locate the drain hole in the bottom of the freezer. Remove the wire bins and gently poke around the back of the floor of the refer with your finger. You should be able to feel a soft spot and clear the drain with a Q-tip or something else soft and flexable.
Dec 17, 2012 | GE Profile PDS22SCRL Stainless Steel...
Whirlpool up and down, water pooling on floor from under refrigerator. Pan full in back. How to empty it==can't get it out. Pan moves alittle from side to side
Sounds like cooling coils inside ref. that cools the water before the dispenser in the door.
These coils are in the back bottom of ref, behind crispers. They may be leaking.
Here is some more help.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
If you need more help GO HERE:
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 23, 2011 | Refrigerators
Our refrigerator is cooling and our freezer is freezing, but there is a leak coming from the freezer area that is dripping down into the refrigerator that just keeps getting worse and worse. Appears that...
Hi maabjcraft,
Have you tried clearing the drain tube?
Your refrigerator has a drain that leads to the exterior drain pan beneath the refrigerator. Occasionally this drain can become clogged resulting in standing water inside your refrigerator. A similar drain exists in the freezer, which when clogged results in ice build up on the floor of the freezer.
The drain is located either on the floor of the refrigerator, beneath the vegetable crisper, or in the wall behind a drain funnel.
Clear the drain by forcing a solution of water and bleach or water and baking soda into it with a basting syringe. If the solution will not flow through, slide a length of 1/4 inch or smaller flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog.
Hope it helps.
Thank you for using FixYa.
May 18, 2011 | GE GTS22WCP Top Freezer Refrigerator
Water on the inside bottom of the refrigertor. Where is the drain tube located? Do I have to take the bottom of the freezer out to access the drain line or can it be reached from the back. If the tube...
if it is a deep freezer the drain is at the bottom, you will see a round seal remove it and the water will drain out. replace it when finished.
May 11, 2011 | Refrigerators
Every couple of days lots of water runs out on the floor.
It sounds like the defrost drain is clogged up. On some models there is a removeable white pull out cup located in the center back wall at the top in the refrigerator section. It is connected to a tube on the back of the refrigertor.If that is blocked water will be in the bottom under the crisper drawers.
Jun 10, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Smeg fride freezer leaking
HI Mark,
The evaporator drain is blocked causing the defrost water to pool, freeze and then leak onto your floor.
Clear out the freezer, then use a hammer to break up the ice on the floor. Now remove the rear panel. You'll see more ice build up. Don't use the hammer on it! (Too close to the coils for comfort) Use a hair dryer to warm up/melt the ice below the coils.
You'll see the drain hole now. Clear the drain by forcing a solution of water and bleach or water and baking soda into it with a basting syringe. If the solution will not flow through, slide a length of ¼ inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog.
SG
Mar 27, 2009 | Smeg FA561X Side by Side Refrigerator
Refrigerators Logo
167 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
