Question about Kitchen Ranges
The clicking that normally just goes to start my burners started clicking all by it self and will not stop unless I unplug it. It is all the burners at the same time. They just keep on with the tick, tick, ticking?.. what might the problem be? It is a jenn-Air glass top if that matters and is about 5 years old. Their is no water on the stove and I did not recently clean it.
  • athomeval Sep 12, 2010
    My cooktop is gas with an electric start. Not electric.
  • 857 Answers
Clean the Igniters:
Unplugged the burner from the power. Then take a small wire telcom pic tool to scrape the white and brown deposits from the sides of the igniters. You could probably use something else similiar to do the scraping. You will notice a shiny surface underneath. then go ahead and scrap it and brushed the clean the mating surface where the spark travels then vacuumed up the mess.All burners will work great after this.
Turned off the power, remove the five knobs and corresponding rubber rings, and used a hair dryer on the five holes where the knobs were for about ten minutes in total.
Posted on Sep 12, 2010
    Genius:
  • 1,478 Answers
If one of your burner heating elements works only intermittently/all works intermittently, it's probably because of worn or bad contacts in the receptacle that the element plugs into. On most electric ranges, you can remove the element by lifting it up several inches and firmly pulling it away from its attachment (receptacle). Read your owner's manual to learn the correct technique for your range. If, after removing the element, you see that the ends of the element that were plugged in are pitted, corroded, burned, scarred, or rusted, replace both the element and the receptacle.
Take care.
Why does my top load whirpool washer restart on its own after it finishes the last rinse and spin cycle. It does this on all settings, delicate, normal or heavy.
  1. Turn the washer off.
  2. Set the mode selector dial to NORMAL.
  3. Turn the dial counter clockwise ONE click (LEFT), clockwise THREE clicks (RIGHT), counter clockwise ONE click (LEFT) then clockwise ONE click (RIGHT).
  4. Now press the start button.
  5. All the cycle indicating lights should be illuminated.
  6. Press the Start Stop button once.
  7. Rotate the dial until Rinse, Wash, and Stop light illuminate.
  8. Turn the washer off and unplug it for 10 seconds.
  9. Finally, turn on the washer and it should now be reset.
  10. Run a test load empty to be sure the reset worked. If not perform the reset procedure one more time.
Oct 07, 2016 | Whirlpool Whirpool 3.5cu ft Top Load...
Tip
Gas Range Repair Burners Keep on Clicking
The clicking that normally just goes to start your burners is not stopping. They just keep on with the tick, tick, ticking….. What can go wrong that will make them keep on doing this?
There are a few possibilities for this problem. The first one is that the little switch that is behind the burner knob either went bad or got water in it. To isolate the switch that is the problem you can pull one of the wires off of behind the burner knobs one at a time till it stops. That one is the one that is bad.
If you have just washed down the stove top then you may have water in it that is making it continue to click. Let everything dry out over night and see if that fixes it. A hair dryer can be used to speed up the process.
If you pull a wire from each switch and it still goes on, then the spark module is bad. You will need to replace it.
Be aware that it is normal for all the burners to spark whenever another one is being lit.
Excessive dirt and grease can cause the burners to light hard but will not cause the spark module to keep on sparking all the time. If a burner lights hard, check the tip of the spark electrode to make sure it is clean.
If your spark module has burnt out to rapidly, or needs to be constantly replaced, you may not have a properly wired and grounded receptacle. Reversed polarity or not being grounded can cause the spark module to fail prematurely. Make sure that you do not use a two pronged outlet or extension cord for your range.
If all else fails you can always unplug the range to get the sparking to stop. You can light the burners with a charcoal grill lighter or a match if you do it carefully. Turn the burner to full on and then slowly go towards the burner keeping the flame as low to the top as possible till the burner lights.
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
on Feb 02, 2010 | Kitchen Ranges
I have a Miele cooktop and often during ccoking another burner starts clicking and click for a long time......solutions..... Also the lower left burner goes on for may be 10 seconds while clicking, the...
I have the Miele km342g cooktop. The ignition would continue firing intermittently after the burner was lit - click, click, click. Drove us crazy for years and we cursed the unit every time we used it. We assumed it was sensing unburned fumes and so we bought a small fan to "whisk" the gas fumes away. etc. etc. I finally figured out what a simple little thing it was. To start the burner, you turn the knob counter-clockwise. Therefore, once the burner is lit it's intuitive to turn the burner down by turning it clockwise. But in order to turn the burner down, you have to continue turning it counter-clockwise - or, "counter-intuitive". Once we figured that out, we haven't had a problem since.
Sep 04, 2011 | Miele 36 in. KM342 Gas Cooktop
My 36" sealed gas cooktop
I had that problem also. It seemed to me that when anyone set the flame too high for the size of pan, the burner overheated. Then when the burner was turned off the igniter made clicking noises for a few hours...till it cooled down.
When I cooked at a lower setting all was ok.
This is free help...please take time to rate me....good luck.
Jul 25, 2011 | GE Kitchen Ranges
My Kenmore Upright Freezer Model 25326432100 flashed "ER."
My freezer was purchased in February, 2004. It is a self defrosting freezer but ice has started forming along the bottom shelf and back wall. Also, after cleaning the freezer the other day it has stopped clycing. The freezer will stop running only if I turn it down to the #1 setting and then it will not come back on. If I turn it up to a higher setting the compressor will not stop running. It ran for over 24 hours and would not cycle unless I turned it off or set it at the #1 setting. When I unplugged it and pulled it away from the wall, there was a green water spot the size of a dinner plate underneath the freezer. Help!! Very Unhappy this freezer is only 6 years old. S in Phila.
May 31, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Stove top igniter won't stop clicking
I found this on Youtube... I thought it might have to do with a thermal sensor not working properly.
Anyheuw, watch this video and see if this doesn't help fix your issue. If not, please respond and I will look at the schematics for the board as you may have a relay or some capacitors going bad.
Aug 14, 2017 | GE Kitchen Ranges
Burners ignite simultaneously (clicking)
When you set a burner to light, all burners spark. This is normal. Move knob back off the spark position as soon as burner lights. All sparking will stop.
Sep 04, 2008 | DCS 48 in. CP486GDSS / CP486GDSSL /...
Maytag gas kitchen range/oven model# MGR575 ADW during preheat cycle in oven seems to keep trying to start left bank of burners over and over again. Gas can be heard flowing an ignition occurs and then...
that actually sounds to be pretty normal operating procedure unless im not understanding correctly, the unit will shout off, and cycle back on to maintain proper temp as cooks, the" top lef bank of burners" they show signs of clicking??? but not actually igniting correct??? and do they ever start to click when unit is completly off???
Apr 07, 2008 | Kitchen Ranges
Clicking noise on cooktop even when all burners ignite
I have a viking gas cooktop. The ignitor on one of my front burners wouldn't stop clicking even after the flame ignited. I swapped that ignitor with the ignitor from a back burner, expecting that the problem was with the ignitor and that the back burner would start to click incessantly, but at least I'd have my favorite front burner for use. Instead, the front burner was then only clicking 50% of the time and the back burner was fine, suggesting the problem was related to the burner not the ignitor. I pulled the front ignitor a bit away from the burner and now it is working normally. Hope this helps.
Dec 01, 2006 | Viking 37 in. VGSU161 Gas Cooktop
Kitchen Ranges Logo
451 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
