Question about Lenovo IdeaPad Y430-3231U Notebook
My Charger no longer charges my Lenovo y430. I am completely positive that the problem is not the charger and that the piece inside the computer is the problem and continues to be pushed in everytime I place my charger in to charge the laptop. Help Please. How do we repair this problem?
  • Lenovo Master
  • 32,281 Answers
To problem could be a faulty power socket on the laptop, please click on this link and follow my instructions to determine the fault and fix :-
http://www.fixya.com/support/r4799950-laptop_battery_power_supply_problems
Posted on Sep 12, 2010
My lenovo tab is not working i were checked the charger also but the charger is ok
When a device like that fails completely, and the charger is charging there's only so many things that can go wrong.
  • The device has completely failed (worst case, but, not if nothing happened to it, no plugged in while lightning, no dropping, etc.)
  • The battery won't charge. If it's not easily replaced, see a battery store, they'll usually install one for the cost of the battery, if they can open it.
  • The regulator for charging the battery has failed. This means not only will it not charge the battery; but, it can't tell when the battery is charged, and it will kill the battery, this must be replaced by a repair shop, unless you know an electrician, and have the key to open the tablet.
Sep 02, 2015 | Lenovo IdeaPad Computers & Internet
Tip
DISASSEMBLING AND CHARGER CHECKING
LENOVO S5000-F - S5000-H
Checking the Computer AC Charger
When you use the computer AC Charger to charge the tablet but no power is charged, see the instructions in this topic to check the computer AC Charger.
To check the computer AC Charger, do the following:
1. Disconnect the micro-USB cable from the tablet.
2. Measure the output voltage across the connector marked B of the micro-USB cable. Refer to the following figure:
For more pictures and description check the link bellow. On search tab type Lenovo
www.electro-medical.blogspot.com/
google.com/+AjinGopakumar
on Mar 07, 2015 | Lenovo S5000 7" Android 1GB 16GB
Tip
DISSEMBLING AND CHARGER TESTING
LENOVO YOGATABLET 10 HD+
When you use the computer AC Charger to charge the tablet but no power is charged, see the instructions in this topic to check the computer AC Charger. To check the computer AC Charger, do the following:
For more pictures and description check the bellow link. On the search tap type lenovo.
on Mar 07, 2015 | Lenovo Yoga Tablet 10 HD 59411049 - Silver...
If the battery is fully charged when i plug the charger stopped charging or not in Lenovo z560 ?
Welcome to FixYa
When the battery is fully charged and you still have the ac adapter plugged in then the battery would no longer be charged. The computer would then be running on ac adapter power.
hope this helps
Jun 04, 2011 | Lenovo IdeaPad Z560 Notebook
My laptop has stopped charging altogether and won't turn on anymore. I don't know if it's an issue with the charger or the battery. What can I do to try to fix it?
I've seen many problems like this as a computer technician and here's what you can.
Find a replacement charger for your laptop online or a local computer shop. Most times, it's the charger. Laptops chargers usually only last 1-2 years before they start to show signs of failing.
If a new charger doesn't solve it, the problem could be internal, either the power jack inside the laptop or the motherboard.
Have a computer technician check out the laptop if the problem persists.
Also, check the Lenovo website if there has been any recalls on your specific laptop.
Hope this helped.
Apr 18, 2011 | Lenovo IdeaPad Y510 Notebook
Lost power completely. It will not run with the charger. The charging lite does not illuminate when it is plugged in. I checked the charger and it puts out 19vdc. I haven't checked the solder connection in...
Hi scottj313,
Based on the information you've provided there are 2 possible causes for your system not to run with the charger:
1. Your AC Adapter is defective:
-> If the light for the charger is no longer illuminating chances are AC Adapter is defective.
  • You may try using another charger if you have any.
  • Or you may use the charger with the other system (Y410)
2. The DC In is defective:
-> The port as to where you are plugging in your charger might be also defective. And if it is, your system will also not charge. This port is built in to your motherboard.
Now the fact that the system lost it's power completely is because there's no power coming in. Also, the incident prior to this that your system intermittently shuts down is probably caused by a defective AC Adapter. Seems like when it was moved the power stops flowing.
For hardware issues with your machine I recommend you to contact Lenovo's Tech Support. You may contact them at this number1-877-4Lenovo (1-877-453-6686).
Hopeit helps.
Thanks for using Fixya
Jan 13, 2011 | Lenovo 3000 Y410 Notebook
How to get to the charging plug for an ideapad y430?
if you are referring to the dc input plug search on ebay for what you need, if you are referring to the part that goes onto the charger itself you can either try ebay, or contact the manufacturer.
Jun 23, 2010 | Lenovo IdeaPad Y430-3231U Notebook
Camera not working
go to my computer,open the drive that you used to install on, i'm asuming C then go to program files, look for your camera folder,delete it, that deletes it completly, if you have any drive cleaner's ,,run them, couldent hurt!!,,now try to reinstall. if nothing still, maybe a systym restore when the cam worked, good luck
Dec 20, 2009 | Lenovo IdeaPad Y430-3231U Notebook
NOT CHARGING BATTERIES
ok you need to zap the battery, if you have a jump box or a battery charger that has at least a 20 amp or better charge selection, like a engine start feature.
the post of the cordless batter has a center post marked on the sides is a plus or minus sign.
the should also be some vertical slits in the plastic post on the corners, clamp the leads from the jump box or battery charger positive to positive , negative to negative. with the car battery charger you can probably slip one side of the battery clip in the plastic slot the other on the connection blade. plug in the battery charger and let it on for 5 or 6 minutes. if the battery charger has a auto shutoff the light will blink off and on but that is ok .
take the cables off and plug into the battery pack charger now you should get a red charge light and now can charge the battery.
if light does not come on try it in the drill or saw and see if you had any more charge than before if so you might need to repeat the procedure and leave it on the car battery charger a little longer
Jun 08, 2009 | Ryobi 3-piece 18V Drill / Circular Saw /...
Lenovo IdeaPad Y430-3231U Notebook Logo
247 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
rey francis basa
rey francis basa
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
