Question about Plumb Pak Home
I just installed the Adjustable Ballcock PP830-30L and I have a question about the unit leaking near the supply line. Can you help?
How do i replace flush valve?
To replace the ballcock (flush valve):
  1. turn off water valve at wall
  2. flush2 times
  3. disconnect line from bottom of tank
  4. unscrew nut where line enters tank bottom
  5. remove lift device (Chain) from stopper at bottom inside tank
  6. lift the ballcock up and out of tank.
  7. replace withnew
  8. reverse to install.
mike
Nov 14, 2015 | Kohler K-3453-K4 Memoirs Comfort Height...
Tip
HOW TO CHANGE A BALLCOCK ON COMMODE
HOW TO REPLACE A BALLCOCK ON A WATER CLOSET, COMMODE: FIRST SHUT WATER OFF TO COMMODE. THER WILL BE A WATER SHUTOFF VALVE BETWEEN THE FLOOR AND THE COMMODE ON THE WATER LINE TO YOUR BALLCOCK, TURN WATER OFF, FLUSH COMODE SO YOU CAN CLEAR MOST ALL OF THE WATER OUT OF IT. THEN UNCREW THE NUT FOR THE WATER SUPPLY, THEN UNSREW THE NUT FOR THE BALLCOCK ITSELF, OPEN THE TOP OF THE COMMODE, YOU WILL SEE A FLAPPER ON THE BALLCOCK, REMOVE IT, THEN TAKE THE BALLCOCK OUT, SOME HAVE A ROD AND FLOAT SOME DO NOT, EITHER WAY IF IT DOES WHEN YOU PUT THE BALLCOCK BACK IN THE SAME WAY THE OLD ONE CAME OUT MAKE SURE YOU HAVE THE GASKET ON WHEN YOU STICK THE END OF THE BALLCOCK BACK, TIGHTEN THE NUT, THEN MAKE SURE YOUR WASHER IS IN THE NUT ON THE WATER LINE AND RE CIONNECT WATER LINE, YOU CAN ADUST FLOAT VALVE BY BENDING THE ROD DOWN TO THE AMOUNT OF WATER YOU WILL WANT CONNECT FLAPPER BACK, TO THE NEW BALLCOCK, IF THE BALLCOCK DOES NOT HAVE A FLOAT, YOU CAN ADJUST PER INSTRUCTION, SO AFTER ALL THIS IS DONE AND TUBE IS CONNECTED FROM BALLCOCK TO THE TOP OF IT WITH CLIP, TO DIRECT YOUR FILL WATER, TURN YOUR WATER ON AND ADJUST SOME MORE IF NEED BE, UNTILL YOUR CORRECT AMOUNT OF WATER IS LIKE YOU WANT IT...THIS IS REALLY EASY COMPARED TO PAYING A PLUMBER FOR THIS JOB, AND IT HAS TO BE DONE QUITE OFTEN, LARRY VEAL MASTER PLUMBER TEXAS
on Apr 24, 2010 | Plumbing
Filler valve won't shut off. How do I fix it?
replace ballcock assy. Its cheap and can be done with hand tools. Drain bowl, remove supply line, unscrew old ballcock nut and pull out, reverse to assemble. The conical supply washer needs to go onto supply line tip first , then up into ballcock or itll leak.
Oct 03, 2015 | Home
Eljer Windsor One Piece Toilet help - leaks water into bowl
I would go back with the ballcock kind. However, the flapper will need to be replaced. It is not seating properly. The fluid master is a revised version and a bit more efficient. It should work well also. They both work off buoyancy and shuts off water the same way.
Feb 18, 2013 | Home
I installed a new ballcock assy and float. the toilet fills and shuts off but i can still hear an intermittant water flow. there were no instructions with the new valve so i dont know how to adjust.this is...
Without knowing what type of ballcock assembly you used I can't tell you how to adjust it. However there is one easy thing that you can check. If you have a plastic line going from the ballcock to fill/overflow in tank make sure that the bottom of that line is not below the water in the tank or it can create a siphon and make the water to run a small amount nostop. Hope this helps you. Have a good day and thank you.
Apr 30, 2011 | Home
Toilet fills very slowly
Is wall shut off on all the way? if so ballcock has sediment inside,if fluidmaster unit turn off water and take black top and turn 1/4 and it should come of check for sediment,if not that buy new rubber piece at homedepot and install.You can always put in whole new ballcock 10.00$
Jan 28, 2011 | Toto Home
2002 yukon hard to start, where is the fuel filter and how to replace it.
FIRST RELIEF FUEL PRESSURE BY REMOVING GAS CAP REMOVE FUEL PUMP RELAY START ENGINE UNTIL IT DIES LACK OF FUEL. FUEL FILTER IS MOUNTED TO THE RIGHT FRAME RAIL.NEAR THE FUEL TANK.YOU NEED A FLARE NUT WRENCH TO LOOSEN FUEL LINE AT FILTER AND A ADJUSTABLE WRENCH HOLD FILTER LARGE NUT WHILE LOOSEN FUEL LINE THIS KEEP FROM TWISTING FUEL LINES WHILE LOOSEN FUEL LINE.BESURE TO GO TO DEALERSHIP AND BUY NEW O - RINGS AT FUEL FILTER LINES.LUBRICATE NEW O- RINGS WITH CLEAN ENGINE OIL.WHEN INSTALLING NEW FUEL FILTER DONT OVER TIGHTEN FUEL LINES CUTTINGTHE O -RINGS AT FUEL FILTER.IF SO THEY WILL LEAK GAS WHEN YOU START UP ENGINE.WHEN DONE CHECK FOR GAS LEAKS WHEN DONE DONT DRIVE UNTIL YOU CHECK FOR LEAKS FIRST.
Aug 16, 2010 | 2002 GMC Yukon XL
Galaxy fridge-water leaking under unit.no shutoff in house.water turned off at street.where/how do i proceed to locate problem?
Thanks for contacting Fixya.com
Check the hose under your fridge that drains condensation and such into a catch tray. Make sure the hose is draining properly.
Blow air through the tube to make sure it is not clogged. A coat hanger wire can be inserted to break up clogs. An alternative method is to use a bicycle pump to force air through the drain hole to remove any obstruction. Vacuum dust bunnies from under the fridge to allow free flow of the air. Most refrigerators periodically blow warm air across the condensation tray. The warm air dries the condensation in the tray.
Clogs are usually caused when dust, moisture and micro-organisms get together in the drain tube. Keep the dust vacuumed from the back and bottom of the fridge. Make sure the drain tube is firmly connected at all points. The drain tube can be flushed with chlorine bleach, rubbing alcohol or other anti-bacterial product. Product selection should be consistent with the tubing material.
I have searched some important instruction through net from a valuable soursse…it might be of your help…
Analyzing the likely source
Instructions
STEP 1: Move the refrigerator out from the wall and look for the location of the leak. STEP 2: Check the side panels and the seals around the door for beads of "sweat." This could indicate a condensation problem. STEP 3: Check the floor. A puddle there could indicate a missing or cracked drip pan, or a leak in the water line that feeds your ice maker. STEP 4: Check for water seeping from the front of the freezer or the refrigerator. This could indicate your defrost drain is plugged or your ice maker is leaking. Fixing a condensation problem
Instructions
STEP 1: Check that the doors shut correctly. Hold each door about halfway open, then let go. If the doors don't shut completely, adjust the screw legs on the front of the refrigerator so the unit tilts back a bit. With adjustable pliers, turn each leg one revolution clockwise. Recheck the doors and, if necessary, repeat the process until they shut securely. STEP 2: Inspect the door gaskets. Look for debris that may keep the doors from shutting. Also check for cracks or gaps in the gaskets that could allow the cold air to seep out. If you find debris, clean the gaskets with warm, soapy water. If you find cracks or gaps, you'll need to replace the gaskets (see How to Fix a Refrigerator That Cools Poorly). STEP 3: If your refrigerator is equipped with a door-frame heater that evaporates condensation, make sure the heater is turned on. The switch should be located with your other refrigerator controls. Fixing a drip-pan problem
Instructions
STEP 1: Pull off the grill that runs along the bottom of your refrigerator. STEP 2: Locate the drip pan, using a flashlight if necessary. The pan should be sitting on top of a set of black condenser coils and directly below a drain tube that carries water from your freezer when it is in defrost mode. STEP 3: Place the drip pan in your sink and fill it with water to test for leaks. If it leaks, order a replacement from your appliance dealer. STEP 4: If the drip pan doesn't leak, clean it with warm, soapy water, then reinstall the pan and the refrigerator grill. Fixing a clogged defrost drain
Instructions
STEP 1: Locate the defrost drain. It should be a round hole or a channel running under the vegetable and fruit bins in the refrigerator or along the floor of the freezer compartment. STEP 2: Inspect the drain for clogs and remove any debris. If necessary, use a small screwdriver to break up debris that's trapped in the drain hole. STEP 3: Fill a meat baster with hot water and force it through the drain to make sure the clog is gone. If the drain is operating properly, the hot water will fill the drip pan. Fixing a leaky ice maker
Instructions
STEP 1: Pull the refrigerator away from the wall and locate the copper water-supply line. It runs from the house water line to the refrigerator water-supply valve. (To get to the supply valve, you may have to use a screwdriver or a nut driver and socket to remove your refrigerator's back access panel.) STEP 2: Inspect the copper supply line, the supply valve, and the plastic supply tube that runs from the other side of the supply valve to the back of the ice maker. STEP 3: If a connection is leaking, tighten it with an adjustable wrench. If either the copper supply line or the plastic supply tube is leaking, you need to replace it. STEP 4: Turn off the water supply. The valve may be under the kitchen sink or connected to a cold-water pipe in your basement. STEP 5: Remove the faulty line and take it to a hardware store to get an exact replacement. STEP 6: Install the new line, tighten the connections with the adjustable wrench and turn the water back on.
Things You'll Need…
Meat Baster ,Adjustable Pliers ,Adjustable Wrench ,Soap ,Nut Driver And Socket
Replacement Parts …
Flashlight
Screwdriver
Who Can Help
Find Prescreened Appliance - Repair or Service Contractors at ServiceMagic.com
Tips & Warnings
To keep door gaskets clean and supple, wash them twice a year with warm, soapy water, then coat them with a light film of petroleum jelly.
Some refrigerators have an internal defrost drain that is meant to be serviced by a professional. If you can't find your drain, call a pro.
To prevent possible electrical shock, always unplug your refrigerator before working on it.
Put carpet scraps or another soft material under the front legs before pulling your refrigerator away from the wall. Otherwise, the legs could damage the flooring.
Let us know if you have something more to know else please accept the suggestion.
May 31, 2010 | Refrigerators
How to change fuel fillter
2002 Hyundai Sonata 2.4L MFI DOHC 4cyl the Fuel Filter is located uUnder vehicle, driver side, below seating area, driver side of fuel tank, mounted on frame in fuel line.
Hyundai Car 1999-05 - Removal & Installation
NOTE The fuel filter is located underneath the car, near the fuel tank.
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Relieve the fuel system pressure.
  3. Remove or disconnect the following:
    Negative battery cable Fuel supply and pressure lines Fuel filter bracket, if equipped Fuel filter
To install:
Fig. Remove the fuel filter
  1. Install or connect the following:
    Fuel filter and torque the mounting bolts to 18-25 ft. lbs. (25-35 Nm) Fuel filter bracket, if equipped Fuel supply and pressure lines Negative battery cable
  2. Start the engine, check leaks and repair if necessary.
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
To install:
To install:
Hope this help to solve your problem.
Apr 24, 2010 | Hyundai Motor 2002 Sonata
Water leaking from under refrigerator
Instructions
Instructions
Instructions
Instructions
Instructions
STEP 1: Pull the refrigerator away from the wall and locate the copper water-supply line. It runs from the house water line to the refrigerator water-supply valve. (To get to the supply valve, you may have to use a screwdriver or a nut driver and socket to remove your refrigerator's back access panel.) STEP 2: Inspect the copper supply line, the supply valve, and the plastic supply tube that runs from the other side of the supply valve to the back of the ice maker. STEP 3: If a connection is leaking, tighten it with an adjustable wrench. If either the copper supply line or the plastic supply tube is leaking, you need to replace it. STEP 4: Turn off the water supply. The valve may be under the kitchen sink or connected to a cold-water pipe in your basement. STEP 5: Remove the faulty line and take it to a hardware store to get an exact replacement. STEP 6: Install the new line, tighten the connections with the adjustable wrench and turn the water back on. Overall Things You'll Need
Meat Baster
Adjustable Pliers
Adjustable Wrench
Soap
Replacement Parts
Flashlight
Screwdriver
Who Can Help
Overall Tips & Warnings
Aug 05, 2009 | GE Refrigerators
Home Logo
Top Plumb Pak Home Experts
Donni Steen
Tom Chichester
Are you a Plumb Pak Home Expert? Answer questions, earn points and help others
