Question about HP Pavilion dv6000z Notebook
I have replaced several batteries because my charging indicator say it is only charging up to a certain percent. When I disconnect the power cord my notebook shuts down. I was using a 12 cell battery. I only began experiencing this when I started using the 12 cell units. What can be my problem? I am also using a brand new charger. I have an HP Pavilion DV6000 entertainment notebook.
    Guru:
  • 277 Answers
Dont use 12 cell battery
Posted on Sep 12, 2010
I have a cc 500 bat push mower the battery charger was leftout on rain the light dont come on for charger is it fried also does it have a plug that i can plug extenstion cord in or do I n
The charger lead should have been connected to a Residual Current Device, or Earth Leakage Breaker that should have flipped the power off. There should be a reset button on the plug.
Charge the mower for 14 hours before initial use. Charge mower indoors in a dry area out of the weather. DO NOT charge in rain or wet locations. IMPORTANT: Use only the battery charger provided with this mower. Plug the battery charger into the battery first, and then into any standard 110/120 volt household electrical outlet. See Fig. 3-9 for B battery charging location. A C NOTE: If an extension cord is required, use one that is at least wire size 16 AWG. Connect the extension cord to charger before plugging extension cord into electrical outlet. NOTE: You may charge the battery with the battery removed from the mower. IMPORTANT: Always recharge battery fully. It takes 14 hours to recharge a completely discharged battery. A flashing light on the battery charger indicates the battery is less than 80 percent charged; a solid green light indicates the battery is 80 to 100 percent charged. A full charge will be achieved in less than 14 hours if the batteries were only partially discharged. NOTE: It is recommended that the mower be charged once every two months during storage. IMPORTANT: Always disconnect battery charger (or extension cord, if used) from the electrical outlet first, then disconnect battery charger from battery. NOTE: It is recommended that the mower be charged immediately after it has been discharged. Storing batteries in a discharged state could reduce future performance. WARNING: The battery contains corrosive fluid and toxic material - HANDLE WITH CARE. Keep away from children. Do not puncture, disassemble, mutilate, or incinerate. Explosive gases could be vented during charging or discharging. Use in a well ventilated area, away from sources of ignition.
Cub Cadet CC500 BAT Operator Manual Charging The Battery
Cub Cadet CC 500 BAT Review Pros Cons and Verdict
It is a 48 volt battery, so the charger for this is special. contact Cub Cadet direct for a replacement.
Service Parts
Aug 09, 2017 | Cub Cadet Garden
My coolpad 3300a will not come on and there is no led light
If the charger is ok, have the battery checked , if faulty replace it , if fully charged you may have to have the phone repaired .
Sep 03, 2016 | Coolpad Quattro 4G
Charger seems to have both red and green lites flashing at the same time no sequence and both batteries connected read 4.0 VDC, are these chargers repariable or throw aways
Your manual is here. The section on charging states, that green blinking means your battery is fully charged but blinking red means that your charger is faulty. I would say repairable.
1. Plug the female connector of the AC power cord (supplied) to the AC receptacle on the charger and plug in the male connector on the AC power cord into the wall outlet.
2. The On/Off LED indicator is blinking RED, this is abnormal. Unplug AC power cord from the on-board battery charger and wall outlet. Charger may need to be replaced. Contact an Invacare dealer or qualified technician.
3. When the On/Off LED indicator light is Off, charger is Off.
4. When the Charge LED indicator light is YELLOW, the batteries are charging.
5. When the Charge LED indicator light is solid GREEN, the batteries are fully charged (as their condition will allow).
6. When charging is complete, unplug the male connector of the AC power cord from the wall outlet and then unplug the female connector of the AC power cord from the AC receptacle on the charger.
http://www.invacare.com/doc_files/1125085.pdf
Mar 24, 2016 | Invacare Pronto M51 Power Wheelchair
Battery disconnected
I'm a bit confused, the battery is a replacement? And it will not charge? Is that correct? If so, return the battery, some aftermarket batteries don't work well, and COULD be a FIRE hazzard. Have you tried another Cord/Charger with the EXACT same power specs? Always buy a genuine replacement battery, inexpensive batteries are inexpensive for a reason. You can find more info on your HP model here: http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?lang=en&cc=us&prodSeriesId=3832468&prodTypeId=321957
Apr 19, 2013 | HP Mini 1000 Netbook
Battery has been charging to 100%. Suddenly would only charge to 76 percent. Now, after two weeks, will max at 62 percent. Computer is 1 year old. Can battery meter be recalibrated?
Pulled from Gateway's website:
Do not interrupt the battery recalibration process. If recalibration is interrupted, you must start the process over again.
  1. Close all open files and programs.
  2. Connect your notebook to AC power and allow the battery to completely charge.
  3. Disconnect the AC power and restart your notebook.Note: If the power cord plug.gif or battery baticon.gif icon does not appear on the taskbar, click the show hidden icons showhidden.gif button. If the icon still does not appear, verify thatAlways show icon on the taskbar is checked on the Power Options Properties Advanced tab.
  4. Completely discharge the battery by doing the following:
    1. From the desktop, right-click on the power icon, then select Adjust Power Properties.
    2. Click the Power Schemes tab.
    3. Click the arrow button to open the Power Schemes list, then click Always On.
    4. Click the Alarms tab.
    5. Click to remove the check mark from the Low battery alarm and Critical battery alarm checkboxes. Let the battery drain until your notebook automatically turns off.
  5. After the battery is completely drained, reconnect your notebook to AC power.
  6. Charge the battery completely until the yellow battery status indicator goes out.
  7. When you are ready to use your notebook again, do the following:
    5. Click to select the Low battery alarm and Critical battery alarm check boxes.
Mar 11, 2011 | Gateway Netbook N450
Dell Inspiron E1505 will not power up - Battery or A/C Power
If you're not ready to take it to a repair shop, there are a few things you can look for yourself. If the power blinks for a quick second before cutting out, which means you most likely have a short. This could be as simple as a faulty power cord, so try moving the cord where it takes the most movement, to see if you can get prolonged power by holding the cord in certain ways (temporarily making the worn wire inside make contact)
If that does nothing, take a look at the mainboard itself. Look for any darkened or discoloured areas, or melted/damaged resistors etc.
May 08, 2009 | Dell Inspiron E1505 Notebook
Battery does not charge and does not provide backup power
change the batterry immediately...it will surely damage ur laptop
Apr 18, 2009 | Computers & Internet
Power problems Inspirion 8600-battery not charging
Most Dell batteries have an LED indicator that allows users to see how much run time and how much overall battery life are available at the touch of a button.
To check battery charge, press the button and the number of lights that appear will tell you charge status. If all lights appear, you have a fully charged battery. Each light that appears accounts for approximately 20% charge.
To check the battery health, press and hold the status button on the battery charge gauge for at least 3 seconds. If no lights appear, the battery is in good condition and approximately more than 80 percent of its original charge capacity remains. Each light represents incremental degradation. If five lights appear, approximately less than 60 percent of the charge capacity remains, and you should consider replacing the battery
if the ac adapter will power the laptop without the battery installed its fine. if the cord is fine and your battery is fine its a mother board issue and it will most likely have to be replaced
Feb 05, 2009 | Dell Computers & Internet
Need help diagnosing dead UPS
Very likely, "would this also explain why none of the indicator leds are working?"...the dead batteries are your problem. you can try this test, since you had it opened: 1.) disconnect internal batteries, label the wires by terminal location. 2.) connect (2) 12 volt car batteries to same exact wires that you just disconnected, noting correct polarity. 3.) power up UPS. if everything ok, then buy 2 replacement batteries for UPS. if not ok, buy new UPS after through search inside UPS reveals no blown fuses or other faults including poor wire connections.
Jun 16, 2007 | Belkin Universal UPS UPS System
HP Pavilion dv6000z Notebook Logo
57 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
