Wahing machine wont spin - Washing Machines
    Problem Solver:
  • 19 Answers
Several times when ours wouldn't spin, a long skinny nail was the problem.
At first glance it looked like just one of the many drain holes, but once seen upon further investigation, I pulled it out and all was normal again.
L8ers
Posted on Sep 12, 2010
Testimonial: "thankyou certainly worth checking out "
My wahing machine won't spin
There are probably 12 things that would make it not spin...check
the belt. Is it loose or broken?
Regards,
Dennis
Aug 17, 2014 | Whirlpool Washing Machines
Water does not drain automatically wahes and spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 04, 2011 | Washing Machines
All of my washing machine's "FUnction" buttons do
Change the program controler unit /the board if you need to get access to all the programs.
Remove the controller unit and make sure that the connectors are tight. Make sure the water level sensors , the door switch is working.
If there is no result the program controller is a suspect.
Jan 21, 2011 | Samsung SW62ASP Top Load Washer
The lights are coming on but nothin is happening what do i do ?
wahing machine must of filled but then stopped on wash wont spin or rinse lights all on any ideas
Mar 13, 2010 | Hotpoint Aquarius WF220 Front Load Washer
Wahing machine wont spin out with full load .will with small load
I would check to see if you have a kink in your drain hose. The timer allows the same amount of time to drain if it is a full load or a 1/2 load. If the drain hose is kinked it restricts the volume of water being drained leaving water in the tub when doing a full load.
Dec 30, 2009 | GE WBSR3140DW Top Load Washer
Inglis Washing machine not spinning
DID YOU REPLACE THE THRUST BEARING LOCATED UNDER NEATH TRANSMISSION, PLASTIC AND ROUND THAT BELT GOES ONTO ,, THAT SHOULD FIX UR PROBLEM
Nov 29, 2008 | Washing Machines
I have a servis easi logic 1500 washer dryer....i do a lot of loads daily and just all of a sudden my washing machine is not spinning or draining amy water ....it was flowing out of the bottom of the...
HI THIS SOUNDS LIKE IT COULD BE THE CARBON BRUSHES IN THE MOTOR SO YOU NEED TO CHECK THEM OR GET SOMEONE TO DO IT FOR YOU IF THEY ARE LOW (APPROX 5MM LONG OR LESS) THE MACHINE WILL TUMBLE BUT WONT SPIN IF THEY ARE LONGER THAN THAT THOUGH IT COULD WELL BE A CIRCUIT BOARD PROBLEM WHICH UNFORTUNATLEY IS A COMMON PROBLEM WITH THIS BRAND IF THIS IS THE CASE BE PREPARED TO SPEND A LOT OF MONEY ON A REPAIR AS THEY ARE EXPENSIVE!
Jul 30, 2008 | Washing Machines
Bosch classixx 1000 Washing Machine not Spinning?
if it is wahing and not spinning, many times the door switch may be damaged. Check switch, to make sure the wires are not torn out.
Jul 08, 2008 | Bosch Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
