Question about Refrigerators
I have a brand new French door electrolux refrigerator. It was just delivered today. The water dispenser doesn't give cold water - just room temperature. It's only been plugged in for 8 hrs but I would assume it should be cold and we've already discarded 12 glasses of water, as the manual says.
We have had two different Electrolux French door refrigerators, over the past 2 years and the water never becomes cold. We were told this is because the the storage tank in this particular refrigerator is so small. You just have to drink your water with ice. Unfortunately, we have had recurrent problems with the ice maker as well! Sorry - but these refrigerators are very problematic and I would not recommend them to anyone!!!!!!
Posted on Jan 10, 2011
Ice Maker is not dispensing ice
Since it is brand new, it should be covered under warranty but check a few things first. To make ice, you need to have the water, a cold freezer, and the ice maker must be turned on. Since you say you have ice then the temp and the water supply sound OK. There is a shut off option on ice makers so you can decide not to make ice as on option. Check that the ice maker is turned ON. Also, there is an automatic shut off if the bin fills up with ice so it does not overflow. On mine, it is a bar that will raise up higher as the ice accumulates and that will shut off the icemaker. Check that. Otherwise call GE for warranty service on the icemaker.
Jan 14, 2014 | GE Stainless Steel French Door...
Ice maker not working
my icemaker has a wire overfill sensor which shuts off the icemaker if there is too much ice in the basket. If this wire gets pushed up it will stop making ice until level lowers OR manually lowered.
Feb 08, 2012 | Electrolux EW28BS71IS (278 cu ft) Bottom...
Electrolux side by side door refrigerator. White
This can be pulled out of the door and replaced with new tubing.You may need to remove the front dispenser panel in order to get the tubing out of the dispenser.
Once you do that then you can pull the remove the tubing and replace it with new line.
Jan 01, 2011 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Ice maker not putting out water just hooked up ice maker kit
Are you getting ice? It seems like my brand-new electrolux does not produce cold water unless it is producing ice as well. We had to adjust the auger in the ice tray to start getting ice ... seems like our water is now getting colder.
Jul 05, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
French door model installed yesterday with outside water & ice. the water is not cold from outside dispenser. have freezer set at 0 F and frig at 35 f
theres only so much water that resevoir inside can hold once it empties it must sit to cool or chill. once used then ur just gettin straight water from ur water line from the house...
Jan 28, 2010 | Electrolux Refrigerators
The freezer side is NOT freezing, but the refrigerator side seems to be cooling normally. I tried emptying the freezer compartment and setting the thermostat at maximum cold, but nothing seems to help....
Dear customer,
               We recommend you to do the follwoing checks
  1. Check the temperature setting
  2. Assure that there is enough room for air flow in the refrigerator or freezer
  3. Check for air flow restrictions in vents
  4. Test the temperature control
  5. Clean the condensor coils
  6. Check the door seals
  7. Test the door switch
  8. Test defrost heater
  9. Test defrost timer
  10. Test evaporator fan
  11. Check for a clogged drain tube
  12. Check for refrigerant leak
Click on the highlighted words to know the steps necessary. Thank you..
May 07, 2009 | Electrolux Refrigerators
GE PFSS6SMX french door fridge water dispenser not working
check the fiting where you tapped the water for the uit. If its a saddle valve what happens is the the gasket closes down and restricts the water flow.
Feb 28, 2009 | Whirlpool GD2SHGX Refrigerator
Leaks after it dispenses water
try running 8 cups of water through the dispener. there may just be air in the water tank. after it was installed the people that delivered it should have done this but most of them dont
Nov 21, 2007 | LG LFD22860 Bottom Freezer French Door...
Refrigerators Logo
131 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
