When you changed the WEP encryption from 64 bit to a stronger 128 bit encryption the encryption code gets changed and when you changes it back to 64 bit the new 64 bit encryption code will be different to the old 64 bit encryption code, that is why your laptops cannot connect to the router. The laptop wireless card needs to be configured with the new 64 bit encryption code before it can connect to the wireless router.
I suggest you configure the wireless router with WPA or WPA2 encryption, this is a much stronger encryption method than the old WEP encryption.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Locating the WEP or Network key:
To change your Residential Gateway wireless settings:
If the Home page does not open, check to make sure that you have no software firewalls blocking network access.
64-bit hexadecimal keys are exactly 10 characters in length. (For example, 123456789A is a valid string of 10 characters for 64-bit encryption.)
128-bit hexadecimal keys are exactly 26 characters in length. (For example, 456FBCDF123400144445271730 is a valid string of 26 characters for 128-bit encryption.)
64-bit ASCII keys are exactly 5 characters in length. (For example, GMODE is a valid string of 5 characters for 64-bit encryption)
128-bit ASCII keys are exactly 13 characters in length (For example, 2008SUNSSWIN1 is a valid string of 13 characters for 128-bit encryption.)
