Question about Sony Playstation 3 (PS3) Console
Boosting Signal Strength
How can I boost the Wi Fi signal to my PS3 from an existing router? I tried connecting a wireless adapter via USB but the PS3 didn't reconize it.
Greetings,
It is more likely the placement of the router an/or PS3. If possible do not place anything on top of them and make sure there is space around the units.
You can try using a repeater which will amplify your wi-fi signal. A repeater is a small box that will lock onto your wifi and extend the range of your current router. Here are some examples:
http://www.amazon.com/s?ie=UTF8&search-alias=electronics&field-keywords=wireless%20repeater&page=1
You can also try the cheap solutions found in these two videos for boosting antenna strenght:
http://www.youtube.com/watch?v=sUTT8wdN_VA&eurl=http://lifehacker.com/software/lifehacker-top-10/top-10-wi+fi-boosts-tweaks-and-apps-306436.php
http://www.youtube.com/watch?v=LY8Wi7XRXCA
If that helped please rate me well.
-WN
Posted on May 14, 2008
How can i boost my wi-fi
You can buy a 'repeater'. A repeater is a net device that can pick up your wifi signal from one wifi, and using another channel (your computer or other device can automatically change channels) it will also send the same connection without wires. Basically, these are like cell towers in that you can move from one to another seamlessly, if they're built to do so. Some cheaper models will require you to chose the one you want.
The other option is to use the etherport, and run another wireless router by pulling a cable to the part of the house or buisness where you need the signal.
Now, that's the easiest way. However, if your wifi uses an antenna, sometimes, if you can find one, you can get a better antenna, something that is directional, or partly directional, this can at times double or triple your distance. However, unless the antenna has an amplifier, it will merely have the same signal, it will just confine the directions it travels, and this boosts the signal. Most normal antennas transmit 360°, but you can get them with any angle spread, and it will help, even down to 15°, which is a very narrow but strong signal. Add an amplifier, and you increase the output signal.
Hope this helps.
Sep 01, 2015 | Toshiba NB205-N210 Netbook
Tip
Boost wi-fi signals!!!
It is true that a direct cabled connection is probably faster, but that doesn't mean you can't get great Internet connection speeds from a WiFi connection. WiFi is a signal, so it's simply a matter of boosting that signal to extend as far as you need it to, and doing it in a way so you'll still get the same amount of power. There are ways to extend your WiFi signal, and most of them won't cost a penny. Here are my ten ways to boost your wifi signal:
  1. Position The Router - Yes, where you place your router does matter. If your wireless desktop or laptop is in another room, the signal has to go through walls and other interference before it reaches you. You can change the positioning and give everyone equal access. For example, in an open office room setting, instead of placing the router in a corner, try putting it in the middle of the room. It might give better coverage to the entire office. The signal should extend out more evenly. If you're looking for optimal wireless coverage in various parts of your home, position the router in the middle of the house. Moving it up off the floor, to a bookcase or shelf, should also help. If you only have one wireless computer, and it's always in the same place (ie: your office, the kitchen, or the hammock) then it makes more sense to place the router closer to the computer, rather than in the center of the house. But experiment -- I've heard of cases where there was a very weak signal, and the problem was that the router was TOO close to the computer.
  2. Avoid Bad Neighbors - Remember, wifi is a radio signal, so the signals from microwave ovens, cordless phones and even your neighbor's wireless router may interfere. So try to steer clear of those as well.
  3. Extend the Antenna - There are some decent booster antennas out there that you can purchase in addition to your current router to help the signal extend out further. You just plug them directly into the router base and it can give you that boost in the signal that you need. Hawking makes several types of wireless antenna boosters.
  4. Repeaters - This little gizmo just takes in the wireless signal, boosts it up to full strength, and spits it back out again. Place the repeater within range of the router, and near the computer that needs a wireless signal. Linksys and D-link offer wireless repeaters, also called range extenders. If you have an Apple computer, look into the Airport Express as a signal repeater.
  5. Gettin' Geeky - Some DIY geeks have come up with interesting ways to extend or boost your Wi Fi signal. One example is the Pringle Cantenna method. This may seem like a hoax, but the technique appeared in an O'Reilly book titled Building Wireless Community Networks, Nov. 2001. Other techniques, such as the satellite dish using a cellphone are elaborate hoaxes, and I'll admit I fell for this one before a kind reader set me straight.
  6. Upgrade Your Router - If you've owned the same router for several years, it might be good to go pick up a new one if you want to expand your connection. Some of the latest models have a stronger signal. The newer 802.11n routers generally have a stronger broadcast signal, and they'll work even if you have an 802.11B or G adapter in your computer.
  7. Upgrade Your Software - One of the most basic things you can do is to make sure your router software is up to date. To do this, visit the website of the maker of your router, whether it is Linksys, D-Link, or some other brand. Check for your model number and make any updates necessary.
  8. Tweak Your Settings - Your software has special features that you may or may not want. Make sure you read the manual that comes with your router and tweak it to fit your needs. Most modern ones are "just plug it in" though there might be ways to boost signals or to make sure it is sending out signals that are optimized for your computer's wireless adapter. For example, most routers are set to broadcast on channel 6. Try switching the channel to 1 or 11 and see if it makes a difference.
  9. Is Your Wireless Router Secured? - Make sure your neighbor isn't hogging all the juice from YOUR wireless router. Get your network secured only you are using the signal. Tap into your security features and make sure you use secure passwords. See wireless security for help with this.
  10. Find Alternative Firmware - While your router's original software (aka firmware) should be all you need, some routers do not output the signal at the maximum possible strength. You might want to check into alternative firmware, like OpenWRT. But be careful with firmware updates -- if you load the wrong code for your router, you can foul it up with no recourse.
on Jul 20, 2010 | Computers & Internet
Cant get wi fi signal.
Solution 1.Check wireless connection.
The first step of diagnosis have to any other device connected to the same network, ensure the wireless connection is working fine, or verify the settings of your wireless router to correct it.
2.Check your Keep Wi-Fi on during sleep Settings.
Owing to Wi-Fi sleep policy your Wi-Fi connection may be going to get disconnected every now and then.
Tweak this policy to keep your Wi-Fi connection awake.
[Settings] >>[Wi-Fi]>>[Advanced]>> Check [Always] to keep the Wi-Fi on during sleep.
Save changes and exit all the screens. Your Wi-Fi will never get disconnected again due to this policy.
3.Check signal strength of wireless connection.
The performance of a wireless network connection depends in part on signal strength.
You have to connect the Wireless network where the signal strength is strong.
Check Wireless network signal strength icons in notification bar.
4.Try to turn off/on Wi-Fi on the device.
First to turn off Wi-Fi, [Settings]>>[Wi-Fi] >>[turn Wi-Fi to off].
And then to turn on Wi-Fi, [Settings]>>[Wi-Fi]>>[turn Wi-Fi to on].
5.Try to forget network on the device.
Forgetting wireless networks allow your tablet/phone to reset some settings.
[Settings]>>[Wi-Fi]>>Press & hold your[Net Work Name(SSID)]for 2 seconds.
>>Select[Forget Network]>>Re-Connect your wireless networks if it's disconnected.
6.Try to reboot your device.
7.Make sure your firmware is up-to-date.
>>Select[Settings]>>[About tablet]>>[System Firmware Update]>>[Check Update].
8.Try to reset your device.
Note: once RESET was performed, all data, apps, settings and personal information will be deleted after initialization.
Third-party programs might be the major probability of Tablet/Phone instable, suggested to have a full reset for the device if the situation persists.
[Settings]>>[Backup&reset]>>[Factory data reset]
9.Try to other wireless connections.
If steps above were not able to solve internet connection problem still, please try other wireless connections if available, otherwise contact your networking provider to technical support.
Oct 09, 2014 | Worryfree Gadgets 7inch Zeepad 7.0 Android...
Wi-fi connection gets disconnected frequently and reconnects by itself. Tried to reinstall the wi-fi drivers but no improvement. The same laptop is working perfectly at another wi-fi environment.Tried to...
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls, mirrors, fish tanks and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Apr 01, 2013 | Computers & Internet
I have just got in broadband but my xbox aint picking up my wireless signal upstairs,ive got the wireless adapter for the xbox,its picking up a few neighbours network connections,surely my xbox should be...
It is possible that the Xbox will be unable to pick up the wireless signal being transmitted by your gateway because the signal is too weak.
The connection speed of your internet has nothing to do with the strength of the signal. The best way to test this would be to try to connect to your wireless internet on a laptop while sitting near the xbox. If you cannot, you will know that the signal isn't powerful enough to reach that location.
There are three common options to amplifying your signal if necessary.
1) Purchase a High-gain antenna for your wireless gateway
2) Purchase a wireless repeater
3) Purchase a new router/gateway with a longer range capability. A "Wireless N" enabled router would be optimal for this application.
Apr 12, 2011 | Microsoft Xbox 360 Console
How do i increase wi-fi signal strength
There are only a few ways to increase signal strength ..move closer to the source (the router) , get a bigger antenna or boost the signal...you can boost the signal with foil in the shape of a parabola around the router antenna or make one out of a vegatable strainer that will plug into the laptop(this one works best )especially for picking up your neighbors WIFI
http://www.focus.com/briefs/mobile-wireless/home-made-wifi-antenna/
Dec 27, 2010 | Computers & Internet
How can I boost the signal on my rocketfish bluetooth adapter?
There is no BOOSTER to do it,but you can do it for a router.Depends on your route rmodel there is several router signal boosters online.
Shopping results for wireless router signal boosters z 3 pack Wi-Fi Wireless Antenna / Router Signal Booster
nav_logo29.png 4 reviews - $10.02 - Amazon.com 2 pack Wi-Fi Wireless Antenna / Router Signal Booster
$7.99 - Buy.com 2 Pack Wi-Fi Wireless Antenna / Router Signal Booster
$8 - 2 stores
Dec 23, 2010 | Rocketfish Bluetooth USB Adapter...
My icon says I only have 80% signal strength, is
80% is a good signal strength....but if you want to increase the signal strength, then you need to move the wireless router to a very ventilated area, also the router should be placed atleast 5 feet away from other electronic devices like, modem, ups, microwave ovens,refrigerators etc.... also there should be a line of sight between the router and the wi-fi adapter... but in order to connect to a wireless network 25% of signal strength is enough....
Apr 17, 2010 | Belkin Computers & Internet
Wi-fi help
hey handym4n01,
The built - in wifi adapter of a laptop has only a range of 40 - 50 meters, but you could use a separate wifi adapter, an example of which is an usb wireless adapter where you could customize it. Have you ever heard of a "cantenna", it is just like having an empty can where you'd wrap it with foil and afterwhich you could put the wireless adapter in the middle of the can. An example image is posted below.. The can wrapped with foil helps boost the signal of the wireless adapter.197bc00.jpg
Apr 01, 2008 | HP Compaq Presario V2000 Notebook
Wireless signal strength boost
depending on your router, you can grab high gain antennae for it and you should see a dramatic increase in range...
Mar 14, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
188 people viewed this question
Top Sony Video Game Consoles & Games Experts
Iron
Iron
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
