Question about Intex 2100 Gallons Hours Sand Filter Pump w Leaf Catcher
I bought the intex 2100 gallons sand filter model SF20110 in May 7 it's work find till now the motor don't want to Start and when it does it drags and shut down. I removed the pump from the filter and it does the same I open the blade housing and turn the pump by hand the motor or bearing are dragging you can hear a squeak from it. I bought the unit new from CMS Worldwide through Amazon The pump is support be under warranty I hope some take care of this.
  • 77 Answers
SOURCE: Looking for an intex filter pump
The best solution to this problem not to find a replacement intex pump/filter. I suggest getting a system with a 50 square foot cartridge filter and a 3/4 hp pump such as hayward or pentair offers. You will be amazed at the difference a little quality can make.
Posted on Apr 28, 2009
lonewolf1996
  • 142 Answers
SOURCE: Intex Easy Set 530 Gallon swimming pool filter
You will need to go to the manufacturing web site and get a new seal for the pump.They cost some where around $1.00 to $2.00.
Posted on Jul 03, 2009
SOURCE: can i hook up a intex pump to a sand filter
YES BUT PRICE OF SAND FILTER WILL PROBALLY COST MORE THAN THE POOL ITSELF
Posted on Jul 13, 2009
  • 297 Answers
SOURCE: Where can I get a new motor for an Intex pump model 637 or 12R
first off water should not be getting to the armature area. be carefull with how you are taking care of your pump.
secondly a 1500 gallon pump is very weak I would advise at least 2500 or even the intex 4000
the most important part of pool maintenance is circulation.
if you have time check into electric motor rebuilding in your area
but sometimes that is more expensive than buying new
also if you have a valid receipt and the pump is less than 90 days old call intex and they will send out a new one within 24 hours
good luck
Posted on Jul 27, 2009
  • 990 Answers
SOURCE: Intex Deluxe Saltwater System & Filter Pump
Check to be sure the filter and baskets are clean, as you need proper water presure to have unit run.
Posted on Oct 03, 2009
Not start capacitor
remove take pics of wires before removing match up at electrical supply
May 16, 2013 | Intex 2100 Gallons Hours Sand Filter Pump...
I bought the Intex 2100 gpm sand filter (16") and pump from Amazon for $199. I turned it on about maybe 6 times. When first tried it just made loud grinding sounds no pumping, then would shut off....
these pumps should run 24/7 as they are SMALL,
try contacting Amazon. see if you can get a replacement pump, pump only. also, see my tips and tricks keeping pool from turning green
Jun 06, 2017 | Intex 2100 Gph 95 Hp Sand Filter Pump With...
I've been reading the blogs and have ascertained that the intex filter is too small to properly circulate pool water for optimum salt chlorination. i have a Krystal Clear system model CS8110 and would like...
You have about 8588 gallons of water in your pool ... One inch of water contains about 159 gallons in your pool. You should consider a 6 hour turn over rate. I recommend a high rate sand filter with at a minimum 1.5 sq feet of filter area. You need to move about 24 gallons a minute to achieve the 6 hour turn over rate.
Continue your research with these figures at hand.
Thanks for your interest in FixYa.com. If you found this information helpful, please vote ...
Aug 02, 2010 | Intex Pool & Spa
Hi- I'm a new intex above ground metal frame pool owner. I bought the saltwater chlorinator to go with my pool. I constantly have a problem with the pool filter not getting enough water to flow through...
You've gotta keep that annoying filter pretty darn clean to please the saltwater pump. I have to scrub my filters daily for this reason. What pump do you have? Mine is rated for 4000gph but I see Intex even offers support for pumps with as little as 500gph.
Jun 16, 2010 | Intex 1000 Gallon Swimming Pool Filter...
Pump shuts off after a minute and isn't filtering water
there is something blocking the passage of the water, go through and check all the passages for any kind of blockage
May 26, 2010 | Intex 2100 Gallons Hours Sand Filter Pump...
Intex 2100 Gallons  Hours Sand Filter Pump w Leaf Catcher Logo
704 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
