Wireless G and N ????
What is the diffrence??? and how do i know what one i need for my 1 1/2 year old gateway laptop???
  • 66 Answers
G is a little older, but is still pretty much a standard for today and is by no means obsolete. N is the Newest WiFi technology, bleeding edge tech if you will. To determine what you need for your laptop, you need to look at the specifications of your laptop (if it came with a spec sheet) and see if it says "802.11g" or "801.11n" on it under wireless standard. If you do not have a spec sheet, you can google the model number of your laptop, along with the word gateway and the word specifications. The results will usually include some type of system specific specifications from where you can find out what type of wireless your laptop has. If you dont know what N does, you should be fine with G. By the date, it sounds like your laptop will have G standard. The specific difference is the amount of signals, and the total speed. G is 54 MBps and N can goto 248 MBps. However, your cable or DSL connection can only go about 10MBps or less probably, so it doesnt matter if you are going 54,248,or 10000000 MBPS locally on your LAN, since your link to the 'net is only 10 MBps. Long answer short, check the specs but probably go with G.
Posted on May 15, 2008
I've got an old Gateway desktop I need to connect to a wireless router for my job. I just bought a new, much stronger NetGear router and it still won't connect. I no longer have a laptop and I'm DESPERATE...
Unless you've installed a wireless card in your old desktop you will never connect wirelessly.
Desktops don't come equiped to do wireless communications. And an "old Gateway" surely does not have those capabilities.
You have 2 options
1) Purchase and install a wireless card for your Gateway
2) Use it hard wired... Purchase an "Ethernet cable" of sufficient length and plug it into one of the open ports on the back of the router and into the only place it will fit on the back of your computer
Jan 31, 2011 | Gateway Computers & Internet
I have had a variety of problems since 2007 a few months after I puchased this gateway laptop from HSN. Big mistake. Customer service for Gateway is terrible! The battery will not charge, screen fails...
Let's think about this. The computer is 3 years old, probably running Vista. It needs a new battery, not surprising on a 3 year old system. The screen doesn't work for some reason.
A battery & screen will run you $150-200. It may still have a problem.
A new computer with Win7 is $400-500.
I know what I would do.
Sep 21, 2010 | Gateway Computers & Internet
I need help with an old laptop.
well u have to install XP on that machine as u know most wireless devices not supporting windows 98.
and you have to check it in device manager.
Jun 15, 2010 | Computers & Internet
I have a trendnet wireless router tew 432brp, a new hp windows 7 laptop, and old xp laptop and i want to share the connection with my verizon um175 aircard. this has worked for several years with the old...
The router connects computers together . You are using a windows 7 p.c and connecting it to an internet connection via a usb verizon um175 aircard.
I think you need to share the internet connection with the rest of the network and may need to feed the ethernet cable into the feed port of the router. I have not done this before but logically the windows 7 computer would have to act as a gateway to the internet.
http://www.dummies.com/computers/operating-systems/windows-7/how-to-share-an-internet-connection-in-windows-7/
https://www.ibvpn.com/billing/knowledgebase/53/Internet-Connection-Sharing-on-Windows-7.html
Note the default gateway is going to have to be the windows 7 ip address on the other computers
You may need to set the ip address on windows 7 to a static address and then change the dhcp server settings default gateway and also increase the first address to not include the windows 7 ip address or the routers ip address in the lease range for shcp.
Mar 17, 2017 | Trendware TEW-432BRP 54Mbps Wireless...
Cannot connect to internet wireless
Please get to the router configuration console (Router GUI on 192.168.1.1) and click wireless => Try changing the channel number and if reboot the router and test for all 11 channels, incase if there is no diffrence please follow the steps below:
Wireless => Advanced wireless Settings => Change the following:
1) Beacon interval = 50 instead of 100
2) Fragmentation Threshold = 2306 instead of 2346
3) RTS Threshold = 2307 instead of 2347
Nov 18, 2009 | Linksys Wireless-G WRT54G Router
Trying to connect my ps3 to the internet but need wireless route
That won't work because your old sbc wireless router 2wire gateway is also a modem. You need a plain router for Time Warner. Try Linksys router.
Sep 08, 2009 | 2wire (1000-100052-000) 802.11g/b Wireless...
Gateway MX3225 Laptop
All drivers for Gateway MX3225 laptop are here
Aug 02, 2009 | Acer Aspire 4930-6862 Laptop
We have a main pc attached to our broadband via ethernet and 1 other laptop which is also attached to the the internet but wirelss, my son has purchased an acer aspire 7730/7330 series laptop , how do we...
I think you need to specify the gateway address in your new laptop. For that you have to know the gateway address ( i,e. the IP address of your boardband router/ adsl modem.).
First, go to your old laptop, right click on My Network Places, Right click on the wireless lan connection and select properties. Click on Internet Protocol(TCP/IP) and click properties.
Take a note of the Default gateway.
Now come to your new laptop, use the procedure mentioned above to open the Internet Protocol(TCP/IP) Properties box. Type in the Default gateway address which you have noted earlier. Click ok twice. Now see if you can access the internet. If you can't then let me know the IP address configuration of both your old and new laptops.
Nov 26, 2008 | Acer Computers & Internet
Wireless
1) A working WiFi adapter, USB or PCMCIA.
2) A Wireless signal to connect to.
Windows already has built in WiFi software.
Jan 27, 2008 | Gateway 450ROG Notebook
WEP key
what is your router? do you know the gateway of your router?
1. Know what is your gateway by using a pc that is online hardwire to your router
> On that pc- check your gateway by doing ipconfig- your DG is your gateway
2. Then access the configuration page of your router- ex. 192.168.1.1
> Use your browser and type your gateway there.
> It will ask for username and password. You should know that.
3. When your inside your router's configuration page-look for wireless tab, then look for wireless security- you should be able to see there your wep key.
4. Finally type in that wep key on your toshiba laptop. It might ask you to confirm, so type it twice. =)
Jan 22, 2008 | Toshiba (PA3212U) Wireless Adapter
Computers & Internet Logo
David Payne
David Payne
