Question about Samsung Computers & Internet
I have P35 laptop, not power on now - Samsung Computers & Internet
  • 2,567 Answers
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced.
Posted on Sep 18, 2010
Black screen on toshiba protege r705-p35
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Oct 15, 2012 | Toshiba Portege R705-P35 Laptop
Toshiba satellite p35-s609 screen darken.
It is almost certainly the LCD inverter which is the cause of your issue. It ism ore common for the inverter to develop a fault than a backlight bulb on the LCD (I used to work in a Toshiba repair centre).
Replacing the inverter should be simple, just make sure the unit is powered off with the battery removed so you don't get an electric shock.
Hope this helps,
www.PuterCare.com
Jul 13, 2010 | Toshiba Satellite P35-S609 Notebook
Toshiba Satellite P35-S609 xp System - hello is there a service manual for this product?
Go to Toshibas website and you can get it off of their website.... Or google "Get Manual for Toshiba P35-S609 Laptop"
Good luck Hope that helps
May 21, 2010 | Toshiba Satellite P35-S609 Notebook
On toshiba satellite P35 series laptop, the DC
If you are good using a soldering iron on a PC board, you can replace the power adapter jack on the motherboard. If not, you should take it to a repair shop and have it taken care of. The cost to have it repaired at a shop should not exceed $50 including the part.
Nov 12, 2009 | Toshiba Satellite A205-S4617 Notebook
Toshiba Satellite P35-S611, power up failure.
Open the processor area located under your laptop. You can detached and re attached the processor, some sort of lose contact on pins. If same problem occur, your processor may burnt out. pm me caligayanstep@yahoo.com i will assist you remotely.
Oct 21, 2009 | Toshiba Satellite P35-S611 Notebook
Satellite P35-S611 has trouble charging
If you have to wiggle the power cord it is most likely the DC jack on the motherboard. It is usually the center pin in the the jack that breaks the solder point and the small tension band inside the jack housing weakens.
Sep 26, 2009 | Toshiba Satellite P35-S611 Notebook
Half of screen flickering
Yes, the probability is that either the circuitry that drives the screen, or the screen itself is on the verge of failing. It is also remotely possible that the backlight is failing. In either case, the likelihood is that a screen replacement is in order. Take it to a computer shop that specializes in Laptop repairs - or call Computer Geeks.
Sep 22, 2009 | Toshiba Satellite P35 PC Notebook
Battery discharges, and will not charge, computer wont run on AC
how long have you had your laptop? the toshiba laptop battery can be normal used in 400-500 cycles, that means normal in 2 years. if the age is over 2 years, the battery declines day by day. get a new one if it is unnormal
Dec 04, 2008 | Toshiba Satellite P35-S609 Notebook
P35 Shuts down
Go into Toshiba Power Saver in Control Panel and set Processing Speed and Cooling Method to midrange. You will not have the problem anymore.
May 26, 2008 | Toshiba Satellite P35-S611 Notebook
Computers & Internet Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
