Question about Plantronics Discovery 975 (8164001 P) Bluetooth Headset
I charge up my plantronics discovery 975 headset in the fully charged case and the red light blinks, but the headset does not charge and it has been charging for about an hour and a half.
  • 32 Answers
SOURCE: It will not turn on after a full charge
Sounds like you have a bum unit.  Plantronics gives a 1 year warranty with every wireless product, I'd send it back.
Have you made sure that you're turning it on correctly?  You push the call answer button and hold it down for about 3 - 5 seconds before it turns on, until the blue light turns on.  Make sure that you don't hold it longer than that or it will go into pairing mode.
Posted on Apr 28, 2009
SOURCE: plantronics discovery 925 will not stay on after a full charge
I'm having this same exact problem man!!
Posted on Mar 17, 2010
wb91
  • 126 Answers
SOURCE: My plantronics discovery 975 will
It sounds like you're still in pairing mode (and not paired) if the light is flashing white/red. Take a look at the following link on pairing instructions:
Plantronics Discovery 975 Pairing
If it continued to flash white/red and not pair, you may have a defective unit. Contact where you purchased the unit for a replacement or call Plantronics at 1-800-544-4660 x 5538.
Good Luck from Headsets Direct!
Posted on Apr 18, 2011
  • 823 Answers
SOURCE: Im trying to connect my Plantronics Discovery 975
Two things need to happen in order to pair your headset to your phone. The headset needs to be in pairing mode and the phone needs to be able to see and save the headset as a connection. To make this happen you need to change the settings in the phone to first allow the connection and then put it into the seek and find mode. When the phone is in seek and find mode, you put the blue tooth in discovery mode at the same time and you should be able to pair them. To put your bluetooth in pairing mode, press and hold the power button and turn it off. Then press and hold it to turn it on until the light come on. you should see a blue light that is on for a bit and then turns off. Press the power button again and this time do not release until the headset starts blinking red and blue. when its blinking red and blue release the button and sit it down near you. leave it on and blinking until finished. now follow the instructions listed below to turn the bluetooth option on and get your phone in discovery mode:
First select a 16 passcode for remote sim card access.
Press options - then new paired device and the phone will search for bluetooth devices.
if your phone picks up other bluetooth devices before it finds yours, press "more devices" until you see the name of your headset.
when the phone finds your headset - select it and press yes for auto connection.
Then select set as authorized and you are done!
You can find these instructions on this link:
http://www.nokiausa.com/get-support-and-software/product-support/e63-support/guides
Posted on Apr 20, 2011
HDI Headsets
  • 537 Answers
SOURCE: Plantronics Discovery 975 - just stopped working -
Sounds like you have a defective headset. You'll need to return it to your retailer, or call Plantronics at 800-544-4660 x5538 for warranty replacement. If it's past the warranty period check out what's new at the following link: bluetooth headsets.
Good luck from Headsets Direct!
Posted on Sep 01, 2011
Is there a way to replace battery in my discovery 975? It quit taking a charge.
Plantronics Pro battery replacement - YouTube
? 9:15
www.youtube.com/watch?v=TuKcjbiK5XU
Jan 16, 2014 - Uploaded by Eddie the Grouch Replacing the battery on my old Bluetooth earpiece. ... Trying disassembly of the old Discovery was, however, a disaster for me (components ...
Plantronics Discovery 925 - YouTube
? 2:26
www.youtube.com/watch?v=XhyZJA8zzyM
Mar 26, 2009 - Uploaded by TheGadgetGrill
The Gadget Grill takes a look at the Plantronics Discovery 925, a headset that comes with its own ...
Oct 16, 2015 | Cars & Trucks
I have a plantonics headset that does not pair with my I phone 4s, I have pressed the button on it until the light comes up but no results, I have a plantonics 975
Turn on Bluetooth option within your phone - Consult phone instruction booklet
Put phone into pairing mode - Consult phone instruction booklet
Put the 975 headset into pairing mode - With the 975 headset on, press and hold Call Control Button until the headset begins to flash red and white.
Select "Add new device" on your phone.
Select the Plantronics 975 headset when prompted. Enter "0000" as passcode.
Your 975 headset will now have a continuous white light blinking.
Choose "Yes" if your phones asks if you want to bond to the 975 bluetooth headset.
Your phone is now paired with the Plantronics 975 headset and ready for use.
Dec 22, 2012 | Cell Phones
Cant listen to music on my 975
The Plantronics Discovery 975 Bluetooth headset does not supports Advanced Audio Distribution (A2DP) and you need this Bluetooth profile to be able to stream music between two Bluetooth devices. The device you are streaming music from (example: cell phone) to the headset must also support Advanced Audio Distribution (A2DP).
Dec 07, 2011 | Plantronics Discovery 975 (8164001 P)...
Ear peice wont charge from the charging dock
If it is under warranty (1 year) Plantronics will replace the headset and charging base case for you. Package up both the headset and the charging case and include your return address, phone number and a copy of your receipt and send to:
Plantronics ATTN: Service Center 345 Encinal Street Santa Cruz, CA 95060
Good luck from Headsets Direct - 800-914-7996.
Aug 24, 2011 | Plantronics Discovery 975 (8164001 P)...
How to setting plantronics discovery 975
Plantronics Discovery 975 settings:
Not sure exactly what you are specifically asking, however here is a link for the 975 user guide. The 975 user guide will tell you all about the settings and how to put it into pairing mode to connect to your cell phone as well.
http://www.headsetsdirect.com/pdf/discovery975_user_guide_en.pdf
Aug 19, 2011 | Plantronics Discovery 975 (8164001 P)...
Plantronics discovery 975 won't turn off nor pair with phone...
Just to make sure you are turning off the earpiece correctly:
Press the call control button for 4 seconds. It will glows red. Then you will hear 4 descending tones. If this does not work I would suggest taking it back to where you purchased it from and have it replaced, the headset has a one year warranty.
Aug 05, 2011 | Plantronics Discovery 975 (8164001 P)...
My plantronics discovery 975 will not connect to my phone. it is paired. the indicator light is flashing White then Red, any ideas
Apr 18, 2011 | Plantronics Radio Communications
Apr 26, 2009 | Plantronics Discovery 925 Bluetooth...
Plantronics Discovery 975 (8164001 P) Bluetooth Headset Logo
158 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
