Question about Sony Cyber-Shot DSC-S90 Digital Camera
Sony cybershot dsc-s90
The camera works when turned on in picture review .. but as soon as you turn the dial to a picture taking mode or video mode ... it turns itself off...
also it wont turn on at all when in picture or video mode i press power and it turns on for a split second but the shutter wont extend and then it yurns itself off... its never been dropped and is only a year old
thanks,
Greg
    Sergeant:
    Champion:
  • 231 Answers
Unit in camera mode required ample current from battery source.Make sure your battery is charged properly.If camera using AA batteries .I recommend using higher output rechargable batteries .If unit uses a Sony battery make sure it is good.Otherwise there is a good chance the lens has a problem opening thus shutting down on camera mode
Posted on Jun 24, 2008
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 480 Answers
Hey Gregorious03,
You could try removing the batteries for at least one minute and then reinserting them, or you could try initializing the camera back to the factory settings under the setup menu. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Posted on May 14, 2008
The lens will not retract on my Sony Cybershot DSC-S90 camera.
Hi there i like to inform you that its a lens guide pin problem. It is damaged or out of lens guide line. Thats why its stuck. The solution is only replacing the lens. But before that if you want to take a risk then on the camera and give a twist on the lens. Be careful. not much twist, just little. After that turn off / on the camera. If its working then fine. Other wise only the solution is contact with the service center and replace the lens.i am sure your camera lens position like a below mentioned picture.. before all this try to follow those step for luck.
1. Ensure batteries are fully charged.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine .
Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a
back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec ..
in not done the press both Menu & self time key for 2 - 4 sec.
May 06, 2010 | Sony Cyber-Shot DSC-S90 Digital Camera
Sony Cybershot DSC W70 Will not take picture it will only take video on still picture mode? How do I reset the settings
Did you ever remove the dial and put it back on?
Turn the dial to a different location and try to take pictures. try all the settings untill you get the correct one. Good luck
Jun 09, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Camera turns off after reviewing two pictures
I suspect this a battery problem which has been described by many Sony users. The camera reads the battery charge wrong
and shut downs down.
For what its worth I had this same problem with both rechargeables and alkcalines. Fresh batteries were rejected after just a few shots and were clearly NOT dead. Solution seems to be either use Sony's NP-NH25 cybershot battery which is made of two AA batteries jointed at the hip or use generic rechargeable NiMh batteries with a capacity superior to Sony's battery (>2500mAh).
Dan
Dec 10, 2008 | Sony Cyber-Shot DSC-S90 Digital Camera
Camera that I've had for years wont power on except in Review mode.
  This situation appears when the lens assembly start malffunctioning. Therefore, You have to replace the Lens Block Assy. For this plz contact any nearest Sony Service Centre nearby to u.
Thanks for using fixya!
Take care.
Sep 01, 2008 | Sony Cyber-Shot DSC-S90 Digital Camera
Sony cybershot 4.1 megapixels mpegmovie vx dsc-s90
Your camera has problem in Lens mechanism. If Lens doesn't open properly, camera will not show picture at all. There would be Loading Motor section demaged in Lens mechanism and it needs to be replaced to work camera OK.
Now come to blue screen in playback mode, This model doesn't have internal memory, so you need memory stick/ card to see previously taken pictures.
Jun 21, 2008 | Cameras
I can review, but not take pictures or video
Well, I have the same problem. Looks like the mighty SONY has created a turd and now I need to spend another 300 plus dollars for another one. Thanks Sony!
Oct 13, 2007 | Sony Cyber-Shot DSC-S90 Digital Camera
Sony cybershot dsc-s600
Hi, here is a temporary solution that might work for you as it did for me:
1: turn on the camera in picture/movie review mode
2: turn the screen off (not the camera)
3: change from review picture/movie mode to take picture/movie mode
4: turn the screen back on.
You should now be able to take pictures and record.
Hope this is of some help.
Apr 09, 2007 | Sony Cyber-shot DSC-S600 Digital Camera
Viewing is fine, taking pictures is not
This sounds like what started happening with my camera a few weeks ago. I found that turning the LCD screen off during picture-taking allows me to take pictures. I then have to go into review mode to look at the pictures I took using the LCD screen. Definitely not a great fix. I'm trying to locate a firmware upgrade that may solve it.
Sep 01, 2006 | Sony Cyber-Shot DSC-W1 Digital Camera
Sony Cyber-Shot DSC-S90 Digital Camera Logo
103 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
