Question about HP PSC 1600 InkJet Printer
HP PSC 1600----Error message that reads: Error OXCO620004 41:lib_micci2.c Print was working fine---then I installed some more memory in the pc. First time I try to print I get this message... and now I cannot even turn the print off. ???
SOURCE: Machine won't boot up
Solution #1 just worked for ME! But remember only works if yours is "making a peculiar sound and wouldn't boot up" as if the scanner is jammed.
Posted on Jun 30, 2007
SOURCE: The hp psc 1600 is
please check the roller maybe there are dirts stick on it and if found then clean it.
Posted on May 27, 2008
SOURCE: hp 2355 all in one error message
mine HP was acting the same way after a jam. I contacted hp and they told me it was a hardware issue and that I would need to purchase a new printer. I found a KB on thier site for this issue. It involved removing both ink carts and then reseting the printer with the ink carts out. it seemed to work.
Posted on Jul 03, 2008
SOURCE: HP PSC 1200 won't scan with VISTA
Click the following link for solution
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00808543&lc=en&dlc=en&cc=us&product=306888&os=2093&lang=en
Posted on Sep 10, 2008
pineworks
  • 4041 Answers
SOURCE: The error code on my HP PSC 1610 ALL-in-One is
Hi
There there to much to tell you what to do but I found a link for you to see it will tell you what to do just click on the link it will take you there.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458034&lc=en&dlc=he&cc=il&lang=he&rule=6783&product=3655608
Posted on Feb 13, 2010
How to fix OXC1AB0003 error on the P PhotoSmart 2575
Remove the cartridges and do a full reset without them in by removing the wall socket and re-plugging.
More information has been answered in another thread.
Error oxc1ab0003730 Lib micci2 tango
Apr 07, 2015 | HP PhotoSmart 2575 / 2575v / 2575xi InkJet...
My printer will not print. I get error:oxc0620004 411:lib-micci2.0 messages.
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage. Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head. Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Jan 15, 2011 | HP PSC 1610 All-In-One InkJet Printer
My samsung ml-1610 series printer's software is installed but the printer is not installed
my oj 7310 all in one is give me error mesege 0xc0620004 411:lib-micci2.c
Nov 03, 2009 | Samsung ML 1610 Laser Printer
HP scanner will not scan, but will print
reinstall drivers and restart the whole system
May 07, 2009 | HP PSC 2110 Color Printer
Won't print gives error message above power and function push button incorrect color cartridge installed---was working fine yesterday no cartridge was done...
uninstall and reinstall printer and make sure u follow the promp and put the right cartridge in the right spot....black and color....2 different chambers
Apr 19, 2009 | HP PSC 750 All-In-One InkJet Printer
Hp 2355 all in one error message
open the rear access door and clean the rollers with a cloth, dam it with little water and unplug the machine and press and hold the ON button for 1 min and release the button and plug in the power cord, it should resolve the issue.
Regards,  raj_p5983
Jan 21, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Hp psc 1600 series
try to give test page from the printer.without using your computer to print, that will help you to locate where the problem is. in the printer or in your pc settings. thanks.
Nov 08, 2008 | HP PSC 1600 InkJet Printer
Won't print from compter.
dude! follow instructions given int he quick start guide. you need to install driver and software correctly. so every time you switch on your pc and printer, you can see a message in the quick launch menu "HP deskJet F2100 series is ready". now you can use your pc to print.
Jul 24, 2008 | HP PSC 1610 All-In-One InkJet Printer
reset to factory defaults, also check the whole printer for paper jams. A paper jam can often casue smaller pieces to get stuck in gears or rollers. The message about opening and closing the lid is how the printer knows you went in to check it and closeing it triggers it to try again. If thers still a jam it will keep giving the message. The fist jam was caused by something, check and make sure there isnt any pieces of plastic broken off inside. If it has a rear access panel, check there also.
Feb 16, 2008 | HP PSC 2355 All-In-One InkJet Printer
HP PSC 1600 InkJet Printer Logo
95 people viewed this question
Seeker5211
Seeker5211
