Question about Dometic RM2652 Refrigerator
I have a Dometic RM 2652 LP gas/electric its hooked up to 120V but no gas. will it cool if so how long will it take to cool and how cold is it suppost to get it
I just saw where they have a recall on this model Dometic Refrigerator RM 2652. If you go to the www.Dometic.com and find the recall info you can type your Model and Serial Number into the boxes and see if your model is one of the ones recalled. Don't know if this link will work but try it first and it will bring you straight to that box I am talking about on their website. Its http://67.238.126.140/recall.php, if not go to the one above and find the recall information. Hope this helps.
Posted on Sep 15, 2010
Freezer gets cold frig is hot. I replaced theromister.did no good
If your Dometic refrigerator is a tri-power model (12V, 120V, lp gas), check all modes. It is not uncommon for these units to fail to cool adequately in 12V mode, as that mode is only for KEEPING things cold while on the road.
If the failure exists only in 120V mode, replace the 120V heating element. If the failure exists only in lp gas mode, replace the burner and make sure that the jet is clean.
If the refrigerator does not get cold in ANY mode, verify that the door seal is making good contact all the way around and, if it is, you'll need to replace the coil assembly. (They are available on eBay and Amazon at a fairly reasonable price.)
May 20, 2015 | Dometic RM2652 Refrigerator
Our refrigerator works on AC. When switched to lp gas it sometimes come on and works and then goes off. Then we can't get it to work again. Then it will work if we turn on the hot water hea
It seems like a gas pressure problem. Possible blockage or kinked pipe or faulty regulator on the gas bottle. If the fridge runs ok only when you use the gas hot water, that would change the gas flow / pressure. LP gas products are normally around 1.5 to 2.75 kpa pressure. If you have access to a manometer, the gas pressure can be checked. (NB/ You should hold a gas service licence to do this)
Sep 29, 2014 | Dometic RM2852 Refrigerator
Dometic rm 2652 refrigerator will not cool
if voltage to unit remove thermistor let run if ok replace thermistor if not see if chimney hot if not heater element if doesn't work on LP bad control board
Nov 18, 2013 | Dometic RM2652 Refrigerator
Dometic RM 2652 Refrigerator/Freezer is not working. Light works, 110 and propane are fine. Are there steps in trouble-shooting problems with this refrigerator? No visible leak or obvious problem. It's in...
Dometic refrigerator lp gas electronic Model # 3662. Same problem. gas works fine and power is there. as lights on top of frig work.... not even trying to be cold. Same suggestions as 2652? How to bypass thermostat? and will try relay after... thanks.. Bob in Canada<input id="gwProxy" type="hidden" /><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden" /><!-- from fixya rte -->
Aug 02, 2010 | Dometic RM2652 Refrigerator
RM 2652 will not get cold
Check the 5 amp buss fuse behind the frig.
Apr 04, 2010 | Dometic RM2652 Refrigerator
Dometic rm 2652 fridge works on a/c. i get a check light on lp gas, i can light burner with flame, it stays lit
you may need to change the thermocople this cost about 12 dollars this is what make electricity to epen the gas valve thanks from gilles
Feb 25, 2009 | Dometic RM2652 Refrigerator
Dometic RM2652 Refrigerator Logo
422 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
