Question about Bissell 3522 PowerForce Bagged Upright Vacuum
After installing belt...broke - Bissell 3522 PowerForce Bagged Upright Vacuum
  • 377 Answers
Sounds like the beater brush is frozen and won't turn. Remove the beater brush and clean off all debris, especially at both ends. You will find a square(?) piece at each end of the beater brush that holds it in place. This need to turn freely. Put a little WD40 on these where the center rod of the beater brush enters the small holders and turn by hand until they turn freely. Once this is done, assemble with new belt, making sure the belt is put on properly.
Posted on Sep 12, 2010
Part belt attaches to is missing
Try here: http://rainbowsystem.com/support/manuals/
Jan 25, 2014 | Electrolux Vacuums
I have a powerclean bissell vaccum and i just got a belt to replace, is pulley the little metal part on the side where belt goes because when i put the belt over the metal part and around rotating brush...
You did not put the belt on its proper place that's why it happen. Replace again the belt and put it not over the metal part. Put a mark where the belt belong so that you'll remember it when you gonna instal the belt. A mark like pen or masking tape will do.
Thanks for asking.
Jul 13, 2011 | Bissell Vacuums
Is there a manual for installing new drive belts on my LG Kompressor - we've had it for less than a month and the belt broke. I ordered 2 replacement belts and the new one doesn't work and the brush won't...
You've probably figured this out, but my luv200R had the same problem. The belt broke, I changed it and it still didn't spin the brushes. Turned out, the roller has bearings on either end and one of the bearings was bad and wasn't letting roller roll. So the pulley would spin against the belt and heat up and break it again. I took the bad roller to Sears where they had a new one sent to my house free of charge since it was less than a year old.
Mar 03, 2011 | LG LUV200R Bagless Upright Vacuum
The belt broke. Is is possible to install a new belt and to get replacement part?
Yes you can bye belts from any electrical store and the don't have to be bran names dysons are very easy to replace!!
Jan 17, 2011 | Vacuums
Old Hoover Convertible Upright U4109 keeps breaking belts. I just replaced the belts twice and both broke within 2 minutes.
Did you make sure the brush that the belt turns is free to move? Sometimes they get bound up and will not turn and as a result, the belts either burn or break. Remove the roller brush, clean the ends and remove any debris, lubricate the ends of the rollers where they are held by the stationary brackets and re-install with belt in correct position. Belt must be installed in the proper manner as well.
Sep 05, 2010 | Hoover Vacuums
Brush not turning and belt not broke
even thought the belt isn't broke it can still be stretched or worn and that will cause the vacuum to not pick up well. you can get replacement belts here:
Replacement Vacuum Belts
Dec 06, 2009 | Vacuums
My enviro vac is being stubborn
First , spin the brush roll by hand and see if it spins freely. Then remove it.
CLEAN OUT ANY HAIR OR THREAD UNDER THE CAPS Inspect the end caps , if one is melted you will need to replace the cap if available or the entire brush roll assembly.
The "metal piece" is the motor shaft. Clean any burned rubber of with fine wet dry sand paper, then install a fresh belt, using the brush for leverage to stretch the belt into place. Rotate the brush again to be sure it is not binding and that the belt is not pinched anywhere.
Buy 2 belts and keep your spare inside the hood of the vac.
Sep 11, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Re place broken belt
make sure there isn't any string or hair binding the brush.if thats not the case i would just try a new belt, could be the wrong size,
May 18, 2009 | Sharp Twin Energy EC-12TWT4 Bagged Upright...
I want to install a belt on the turbo power 2000 upright vacum cleaner , What do I have to do to install it. The old belt broke.
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=564997
Generic problem for all Vacuums
I want to install a
Posted by mcpo on May 02, 2008
I want to install a belt on the turbo power 2000 upright vacuum cleaner , What do I have to do to install it. The old belt broke.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
There are only 2 ways you can install a belt on a Turbo Power 2000, either you can remove the bottom plate and expose the belt, 1st place the belt on the brushroll section of the vacuum then use a belt puller or a screwdriver with a left or right hook @ the end and pull the belt onto the motor pulley, once you get the flat belt onto the motor pulley than you do what is called tracking to straighten belt out so it runs straight, replace the bottom plate. 2nd then remove the top cover by 2 to 4 screws or levers and then remove the top, then follow the procedure listed above. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Don – The Vac Man
Go Ahead. Use Us.
May 02, 2008 | Vacuums
Belts keep breaking
Check the brush roll ends to see if they have melted or frozen. They should turn freely, part #361869-1. Make sure the belt isn't being pinched somewhere.
Apr 15, 2008 | Eureka WhirlWind Litespeed 5844 Upright...
Bissell 3522 PowerForce Bagged Upright Vacuum Logo
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
